XBMC Event Receiver
Re: XBMC Event Receiver
Post by jonib » Tue Jan 03, 2012 5:36 pm
rickardk wrote:I've got this problem when playing files with "å, ä or ö" in the title (UTF-8). Not sure how to fix it though.
I'll see if I can fix it, but it might take some time.
rickardk
Post by rickardk » Tue Jan 03, 2012 9:34 pm
Great. I don't know how the XBMC Event Server works, but I guess it will just broadcast simple play, stop etc and then the XBMC Event Receiver plugin will use the HTTP API to get what's playing.
Must be the decoding on that read that's not done properly as getcurrentlyplaying will show the same none decoded ascii
Post by jonib » Wed Jan 04, 2012 12:13 am
rickardk wrote:Great. I don't know how the XBMC Event Server works, but I guess it will just broadcast simple play, stop etc and then the XBMC Event Receiver plugin will use the HTTP API to get what's playing.
It just listens for events on a specific network port and displays what it gets.
By default Python just understands simple US-ASCII, so the code needs to use Unicode to handle other encoding's.
Post by jonib » Wed Jan 04, 2012 12:40 am
I have attached a new version of this plugin, it hopefully will handle events with non US characters.
I have done only a quick test and it seems to work.
rickardk
Post by rickardk » Wed Jan 04, 2012 4:10 am
Great. No more problems where the XBMC Event Receiver plugin stops responding.
Thanks a million!!
zootoxin
Post by zootoxin » Sat Mar 03, 2012 9:57 pm
Can somebody please explain to me how to configure this on a windows 7 PC
The event ghost I am using is on the same PC as XBMC
The links in the readme are dead
Please help
Post by jonib » Sat Mar 03, 2012 10:49 pm
zootoxin wrote:The links in the readme are dead
You did change the "xbox" part in the url so it points to where your XBMC is? like localhost or your PCs IP address.
From the readme:
Use the following to control the broadcasting of events (assumes xbox is the address of your xbox
running xbmc and xbmc has its web server turned on):
zootoxin
Post by zootoxin » Sun Mar 04, 2012 9:20 pm
The IP of the address the PC which has Event Ghost and Xbmc is
192.168.1.30
so what now?
There seems to be two areas for IPs and Ports
Post by jonib » Sun Mar 04, 2012 10:26 pm
zootoxin wrote:There seems to be two areas for IPs and Ports
In the Plugin? There you must change the XBMC Host IP and XBMC HTTP Port to match you settings in XBMC.
You might need to change the port in XBMC to something other the 80.
nicobo
Post by nicobo » Sun Apr 01, 2012 2:29 pm
I want to change the volume when I play music (75%) or video (100%). (All my music play louder than my videos and don't want to adjust volume each time).
I need events that trigger when when I play music, or video (from file, movie or TVshows)
When I launch a media I get two events:
<b>Onplaybackstarted;1<b> --> for every media
<b>mediachanged:<li>movietitle:xxxxxxx<b> --> only for tv show or movies not for video file There is no second event for video file
<b>mediachanged:<li>audiotitle:xxxxxxx<b> -->for music.
How can I create two events that trigger when I play music or video. I need to remove the title to always have the same event.
I will xbmc2 wit the api setvolume command to change the volume (works fine).
satheesh.net
Post by satheesh.net » Sat Sep 15, 2012 10:01 am
Hi. I've got the plugin to work correctly and I'm quite pleased with it. I do have a few requests though. The first one is that whenever I play a movie/tv-series I've set the lights to go off and resume if I pause or stop and it does that correctly. My issue is whenever I want to play some music from the library (or use the Spotify plugin, Spoti MC), it still sends the same event:
XBMC-Event.<b>OnPlayBackStarted;1</b>
And the lights go off. But I wish whenever I played music media, there wouldn't be any changes to the lights. But for that to happen, the XBMC Event must send something else than OnPlayBackStarted maybe OnMusicPlayBackStarted or something.
Previously I was using a script via SwitchKing to do the work for me and there it worked right out of the box.
See script here -> http://www.satheesh.net/2012/01/09/xbmc-lights/
Anyone with some tips on how to achieve this?? :roll:
satheesh.net
Post by satheesh.net » Sat Sep 15, 2012 10:25 am
Livin
Post by Livin » Sat Sep 15, 2012 4:54 pm
satheesh.net wrote:Hi. I've got the plugin to work correctly and I'm quite pleased with it. I do have a few requests though. The first one is that whenever I play a movie/tv-series I've set the lights to go off and resume if I pause or stop and it does that correctly. My issue is whenever I want to play some music from the library (or use the Spotify plugin, Spoti MC), it still sends the same event:
This plugin is depreciated... meaning, it uses information from XBMC that is no longer being developed or supported. It might be disabled in the next XBMC release. XBMC has moved to JSON API... take a look at the XBMC2 plugin, it support JSON.
Owel
Post by Owel » Wed May 29, 2013 7:49 pm
Does anybody know if this plugin still works with frodo?
Post by jonib » Wed May 29, 2013 8:11 pm
Owel wrote:Does anybody know if this plugin still works with frodo?
No, Frodo (and later) don't support Broadcast events anymore.
Frodo has JSON-RPC notifications instead, and my XBMC2 plugin has support for that, you need this test version for Frodo and notification support.
