why is this wxpython script crashing EG?
Navi
Post by Navi » Sat Apr 05, 2014 8:41 am
Pasted this really simple code into an EG Python script:
import wx
app = wx.PySimpleApp()
choices = ["Alpha", "Baker", "Charlie", "Delta"]
dialog = wx.SingleChoiceDialog(None, "Pick A Word", "Choices",choices)
if dialog.ShowModal() == wx.ID_OK:
    print "You selected: %s\n" % dialog.GetStringSelection()
dialog.Destroy()
in an attempt to open a multple choice dialog. The dialog opens, for a moment, and then EG crashes...any experts know WHY?
Re: why is this wxpython script crashing EG?
Post by Pako » Sat Apr 05, 2014 11:19 am
Navi wrote:The dialog opens, for a moment, and then EG crashes...any experts know WHY?
Unfortunately, I'm not an expert and I can not explain exactly why this is so.
But I know how it can be modified to make it work:
import wx
def CreateDialog():
    dialog.Destroy()
wx.CallAfter(CreateDialog)
Navi
Post by Navi » Sun Apr 06, 2014 12:24 am
Pako wrote:But I know how it can be modified to make it work:
EDIT: what the heck, I just tried it again and it's working now. SO BIZARRE.
EDIT2: okay so I've noticed, if you make ANY CHANGES to the code above, and press TEST, EG will error like I quoted below. If you hit OK and OPEN THE SCRIPT BACK UP in EG, it'll work fine. How crazy is that?! But, it works!!!!
Thanks! That's exactly what I need...but for some reason when I run that script I get the following error from EG:
Traceback (most recent call last) (1640):
  File "wx\_core.pyc", line 14660, in <lambda>
  File "33", line 6, in CreateDialog
AttributeError: 'NoneType' object has no attribute 'SingleChoiceDialog'
