Windows callback function in a plugin
WharfRat
Post by WharfRat » Mon Dec 15, 2014 2:24 pm
I am writing a MIDI plugin.
The Windows Multimedia API sends messages to a callback function.
Currently, my callback function is implemented as a standalone function:
import eg
eg.RegisterPlugin()
from ctypes import *
from ctypes.wintypes import *
# define the prototype for the MIDI Input callback function
MIDIINPUTCALLBACK = WINFUNCTYPE(None, HANDLE, UINT, LPVOID, LPVOID, LPVOID)
def MidiInputCallback (hMidiIn, wMsg, dwInstance, dwParam1, dwParam2):
class MidiInput (eg.PluginBase):
    def __init__ (self):
        self.Callback = MIDIINPUTCALLBACK(MidiInputCallback)
    def Configure (self, device_name=""):
I would prefer to have the callback function defined within the MidiInput class so that I can access the class members.
import eg
eg.RegisterPlugin()
    def Callback (self, ????): # <-- *** this is where I want it ***
Any ideas on how it can be done?
EventGhost 0.4.1.r1640
PHX01RN plugin v3.0.1
WharfRat
Re: Windows callback function in a plugin
Post by WharfRat » Tue Dec 16, 2014 12:50 pm
Perhaps I need to ask a different question in order to accomplish what I need...
How can I access self from within MidiInput.Callback, which is actually MidiInputCallback after self.Callback = MIDIINPUTCALLBACK(MidiInputCallback)?
I hope what I am trying to achieve makes sense to you...
Post by Pako » Tue Dec 16, 2014 1:03 pm
I looked at it, but it is too complicated for me (because I can not test it).
Maybe you can create an analogous (generic but in principle identical) snipet (example), where I will have the opportunity to try it as well.
WharfRat
Post by WharfRat » Tue Dec 16, 2014 1:55 pm
Aah, thanks for the quick reply Pako...
I think I have solved it.
Currently I did not use the dwInstance parameter of the callback for anything, but I think I can pass self as the parameter for that, so that it will be accessible within the callback.
I hope that self is just a pointer, and not a deep copy of the object itself...
I will test it just now to see if it works.
By the way, the plugin will work without real MIDI devices.
I have also tested it with virtual MIDI devices like vmpk (Virtual MIDI Piano Keyboard - from SourceForge) by using a virtual MIDI port (MIDI Yoke).
More details about that will follow when I post the plugin (actually two plugins, MIDI input and MIDI output, plus a possible third one for MIDI file IO)...
These two plugins are much harder than the simple PHX01RN remote control plugin I wrote earlier...
WharfRat
Post by WharfRat » Tue Dec 16, 2014 4:56 pm
Well, I struggled with using self as a parameter for dwInstance, and I couldn't get it to work.
Then I went back to Luse's Learning Python 5th Edition book.
Found something about function attributes on page 564.
This is what I do now:
import eg
eg.RegisterPlugin()
    print MidiInputCallback.parent.some_attribute
        MidiInputCallback.parent = self
The some_attribute in MidiInputCallback is an attribute of the MidiInput class.
WharfRat
Post by WharfRat » Wed Dec 17, 2014 9:21 am
Pako...
Sorry, it took me a while to create a code snippet for you.
(6.27 KiB) Downloaded 163 times
I had to change the example to a MIDI Output Device.
Not everyone has MIDI input devices.
All motherboards have MIDI output devices.
It is as simple as I can make it for our purpose.
When the Open Device macro is executed, something should happen in the callback.
The same applies for the Close Device macro.
The solution I came up with yesterday using function attributes does not seem very elegant.
I think the best solution might be if I can pass self as an argument for dwCallbackInstance in the OpenMidiOutputDevice action.
Post by Pako » Wed Dec 17, 2014 3:35 pm
(6.88 KiB) Downloaded 177 times
If I understand correctly, so the solution is very simple.
WharfRat
Post by WharfRat » Wed Dec 17, 2014 6:20 pm
THANK YOU, THANK YOU, THANK YOU...
Simple?
Yes, but only after I studied it carefully...
I would never have arrived at your solution.
It is exactly what I wanted to achieve, and has tested correctly as well.
Thanks again...
