Script or command line
vali_ics
Post by vali_ics » Wed May 20, 2015 10:38 am
I should use a script or a direct command line for this macro:
I have a input dialog text to input what i want to search on google chrome.
Now i can get it to work but i don't know if it's okay like this or should i use a Python Script ?
https://www.google.ro/#q="{((eg.event.string).partition('.')[2]).replace(' ', '+')}"
var = eg.event.string
var = var.partition('.')[2]
InputFinish = var.replace(' ','+')
And 1 more question, if i make a script like the above one, i should use a eg.globals.NameVariable to acces it on another macro ?
Thanks.
