Get and send previous logs
Foune
Post by Foune » Mon Sep 04, 2017 7:38 am
I'm debugging "complex" scenarios based on presence detection in my home.
I need a script that collects the 50 previous log entries and send them to a specific email address.
Is it possible ?
Re: Get and send previous logs
Post by kgschlosser » Mon Sep 04, 2017 8:23 am
Oh come on now...
LOL
Of course it is..
and what log are you trying to send? an EG log?
Post by kgschlosser » Mon Sep 04, 2017 9:38 am
You will want to trigger this script. which will set the last 50 log entries into eg.result. which can then be used in conjunction with the E-Mail plugin by Pako to send the e-mail. you will need to put {eg.result} into the body section of the send e-mail action.
from time import strftime, localtime
ICONS = {
    eg.Icons.EVENT_ICON: 'EVENT: ',
    eg.Icons.NOTICE_ICON: 'NOTICE: ',
    eg.Icons.INFO_ICON: 'INFO: ',
    eg.Icons.MACRO_ICON: 'MACRO: ',
    eg.Icons.ACTION_ICON: 'ACTION: ',
    eg.Icons.PLUGIN_ICON: 'PLUGIN: ',
    eg.Icons.AUTOSTART_ICON: 'AUTOSTART: '
PLUGIN_ICONS = list(plugin.info.icon for plugin in eg.pluginList)
capture = 50
if len(eg.log.data) < 50:
    capture  = len(eg.log.data)
results = []
for i in range(len(eg.log.data) - capture, len(eg.log.data)):
    results += [eg.log.data[i]]
for i, result in enumerate(results):
    line, icon, wRef, when, indent = result
    if eg.config.eg.Classes.MainFrame.logTime:
        when = strftime(" %H:%M:%S   ", localtime(when))
        when = ' '
    if icon in ICONS:
        entry_type = ICONS[icon]
    elif icon == eg.Icons.ERROR_ICON:
        entry_type = 'ERROR: '
        if len(line) > 7:
            if when !=  ' ' and line[:8] == when[1:9]:
                entry_type = 'DEBUG: '
                digits = line[:8].split(':')
                if len(digits) == 3:
                    for digit in digits:
                        if len(digit) < 2 or not digit.isdigit():
                            break
    elif icon in PLUGIN_ICONS or line.startswith('Plugin:'):
        entry_type =  'PLUGIN: '
        entry_type =  'ACTION: '
    if eg.config.eg.Classes.MainFrame.indentLog:
        line =  entry_type + when + ' ' * indent + line
         line = entry_type + when + line
    results[i] = line
eg.result = '\n'.join(results)
I have tested this and it does work. now there are so many variables to detecting the type of log entry so I don't know if I have them all covered. but I can code in the ability to send mime attachments and convert the icon to be able to send it in the e-mail. I can also format the whole output to look like a screen shot of the log if you like. This would require you to have viewing of HTML turned on in your e-mail client/web provider. I think that would be the only way to have it properly format the data with the viewing of the icons. But this script will prepend ACTION: or DEBUG: MACRO: those kinds of things for the various types of log entries.
Post by kgschlosser » Mon Sep 04, 2017 9:44 am
It also takes into account of the log times are set and if you have indenting turned on as well as if you have debugging turned on.
topix
Post by topix » Mon Sep 04, 2017 6:09 pm
There's also a log redirect plugin: viewtopic.php?f=9&t=2852&hilit=log+sender#p16393
Post by kgschlosser » Mon Sep 04, 2017 7:09 pm
I have never used the log redirect plugin how does it handle dealing with the icons and log times?. also does it convert the log into pure text with markers for what the actual log entries are?
Post by kgschlosser » Mon Sep 04, 2017 7:17 pm
ok i took a look at it. it does handle converting the log to text but it needs to be updated to handle the debugging message. because the debugging messages use the error icon it will think they are errors. and it has no action to return a reformatted version of the log. it will only write it to a file. either way it is a really neat plugin that could be expanded upon greatly and updated to work with the debugging message and also an action to return the currently stored log entries.
Foune
Post by Foune » Wed Sep 20, 2017 8:59 am
Thank you for your help, kgschlosser . i'll try your script and give a feedback.
Eventghost is becoming critical in my setup nowadays :
- Light
- Heating
These features are (or will soon be) dependant of my eventghost setup. In some rooms, no eventghost, no light. I have virtualized my home automation machine in order to make periodic snapshots and facilitate the recovery in case of crash.
Your script will be precious to improve my scripts behaviour.
Additionnally, I'll try to find how to generate/send this log when an exception/error is triggered.
