How do I send a PUT and GET Json
Mastiff
Post by Mastiff » Sun Oct 08, 2017 5:05 pm
I want to control a program via it's API (TuneBlade, which sends AirPlay streams to receivers) using PUT requests, and the format is JSON, like this:
http://192.168.0.1:56569/devices/{ID}
“Status”: “Connect”
The ID is the AirPlay ID, which usually contains a name and a MAC address. Can somebody please tell me how I can do that in Python script?
yokel22
Re: How do I send a PUT and GET Json
Post by yokel22 » Mon Oct 09, 2017 12:23 am
You can do it like this from script, but will throw an error on eg 5.0 beta 4(other versions should work fine). I'd suggest you check out boolean123's httpRequest plugin here instead:viewtopic.php?f=9&t=9780
A quick question though, does tuneblade only support system audio, or can it use iTunes too? I'm looking for something that i can just toggle my airplay zones on/off.
import requests
import json
id = 'your id'
url = 'http://192.168.0.1:56569/devices/' + id
payload = { 'Status': 'Connect'  }
headers = {'content-type': 'application/json'}
putRequest = requests.put(url, data=json.dumps(payload), headers=headers)
print putRequest
Mastiff
Post by Mastiff » Mon Oct 09, 2017 7:16 am
Thanks, I'll try that! And no, Tuneblade is a program that sends any audio from the chosen audio card (I use kX Drivers to get three virtual cards from one Soundblaster Audigy) to one or more AirPlay receivers, and it's the stream it sends out that can be stopped in this way, it does not control the receiver as far as I know. But you can look at the FAQ here: http://www.tuneblade.com/support/faqs.html
