New version 4.0.1.r1706 is out
Post by Pako » Sat Oct 03, 2015 12:06 pm
As always - I please developers to use this topic to report on any changes that should be included in the next version.
News in version r1706:
Plugin Speech
  • added event after speaking finished
  • {DATE} context is working properly
  • added option for selection of output device
  • added option for selection of date and time format
Sem;colon's modification to eg/WinApi/SendKeys.py
  • Improved Error handling (previously it was possible that it crashes if a Key could not be parsed correctly)
  • Added the parameter "mode" which specifies if the button(s) should be pressed, released or both (Default)
Plugin Webserver - Filandre's change
  • websockets support for old browsers (Hixie-76 protocol, especially for early iPad) and also support for IE10/11
OpenSSL update Pako
blackwind
Re: New version 4.0.1.r1706 is out
Post by blackwind » Fri Oct 09, 2015 12:24 am
Added "Disable WOW64 filesystem redirection" to "Windows Command".
Command.py
(8.27 KiB) Downloaded 319 times
/bw
pearbear
Post by pearbear » Sat Oct 10, 2015 2:32 am
Please consider updating the Network Event Receiver plugin with the patched version attached in my post: viewtopic.php?f=4&t=6979
This fixes the security vulnerability of the same cookie being sent for every received event.
Thanks so much for everyone's work on this excellent software!
Post by Sem;colon » Sun Oct 18, 2015 9:35 am
My modifications or the next version:
SchedulGhost: viewtopic.php?f=9&t=2740&p=37532#p37532
