0.5.0-beta: winusbwrapper.dll broken?
Forum rules
Post by topix » Wed Nov 23, 2016 9:59 pm
As in this topic found out, there seems to be a problem with the winusbwrapper.dll.
This dll is not only used in plugin 'PCRemoteController' but also in
  • AsusPr2000
  • AtiRemoteWonder2WinUsb
  • Auvisio
  • Conceptronic
  • LogitechUltraX
  • PHX01RN
  • SmallPcRemote
  • Speedlink6399
  • TechniSatUsb
As i don't have one of those devices i need some help. Is anyone using one (or more) of the plugins and would be willing to test them with the EG beta version?
