USB-UIRT stops working ... Anyway to send reset?
relgycandy
Re: USB-UIRT stops working ... Anyway to send reset?
Post by relgycandy » Mon Feb 25, 2013 11:31 am
# Copyright (C) 2005 Lars-Peter Voss <bitmonster@eventghost.org>
# EventGhost is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# EventGhost is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with EventGhost; if not, write to the Free Software
# Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
# $LastChangedDate: 2009-07-06 19:09:53 +0200 (Mo, 06 Jul 2009) $
# $LastChangedRevision: 1092 $
# $LastChangedBy: Bitmonster $
"""<rst>
Hardware plugin for the `USB-UIRT <http://www.usbuirt.com/>`_ transceiver.
.. image:: picture.jpg
:align: center
:target: http://www.usbuirt.com/
import eg
eg.RegisterPlugin(
name = "USB-UIRT",
author = "Bitmonster",
version = "1.0." + "$LastChangedRevision: 1092 $".split()[1],
kind = "remote",
canMultiLoad = True,
description = __doc__,
# 'Hardware plugin for the <a href="http://www.usbuirt.com/">'
# 'USB-UIRT</a> transceiver.'
# '\n\n<p>'
# '<a href="http://www.usbuirt.com/"><p>'
# '<center><img src="picture.jpg" alt="USB-UIRT" /></a></center>'
icon = (
"iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAYAAAAf8/9hAAACbklEQVR42mXTa4hMYRzH"
"8f9zzoxmsblMJrzYRHgj140XkiG1Vomd1OwoRVHKreSyRWSRvJHSZktKq0E7LvvCFG/k"
"kh0ZG7UoS1q7G7vjuqsxu2vOeXyfzvPO1Odc5jzP//+cc35HicgQOrEaU3EMO5HAdlxC"
"NRrQjgfoxyrUKTaDeIz1mIwdOIvX2IgPWIt7uIubuIK3OGIKfLeVTYGo7WoK5BFCM7Lo"
"s5O/4g2WYY8poNFmloOxOIBGjMESHMZSTMd1dOOJbXRQ0aKpLLKQk62YhNm4jd04jzW2"
"SNxOvIPLzOswY5QoFqH1CvsQu2yXcTiEEUzBSYTtyswtTLTjnirWP5cS78yoCnwROc35"
"BA6LcPALpkGfL9LC/hyONgYPtV4NxWKD4UKhKyJSW63UzA6tM1x4jz+20zCqcMI+h+Xc"
"3+YY3ceLLFa9iUQpPDAQieZyN44rdarS82r9oLOZnMMMxFhVN4Hxf4g83CdyplckyaBh"
"cwteIR733WIxFM3n59tQmd9e+wodm40LPWw+8sAp9pImZfau8h1Ha8cp99fUuNFsNs2f"
"2xjnsa9n/xmPTDJLIs9IVicRbGFpKap6NA8pKvkqOHHZpxm8xa5gnSmE+0jxOj4RyXZi"
"m+Y4Za+55hZ8lM19E702qm+aE6x7v02eSWDDb5GLz0V+UuQWQdnAdd8kVVFNEzmP1+fy"
"FSUJfSutF1UEUW22H800mlwzbWfRYKVIhsh6I3YFpVGRyFUSRpfkPC4wo8oNAlMM5oh5"
"fn93sTDGKjKTIZZ1lSKjijh534jlK/JuosaxamVVSv7/NXGtJwiI5rt/QdoW/AOsdcg6"
"Kwb6cgAAAABJRU5ErkJggg=="
import wx
from ctypes import (
c_int, c_uint, c_ulong, byref, c_ubyte, c_char_p, c_void_p, POINTER,
WINFUNCTYPE, Structure, GetLastError, create_string_buffer, WinDLL,
string_at,
import datetime
import threading
import os
class Text:
uuInfo = "USB-UIRT Info"
uuProtocol = "Protocol Version: "
uuFirmVersion = "Firmware Version: "
uuFirmDate = "Firmware Date: "
redIndicator = "Red Indicator LED Operation"
blinkRx = "Blink when Receiving IR"
blinkTx = "Blink when Transmitting IR"
notFound = "<not found>"
irReception = "IR Reception"
legacyCodes = "Generate 'legacy' UIRT2-compatible events"
stopCodes = "Pass short repeat codes as enduring events"
class TransmitIR:
name = "Transmit IR"
description = "Transmits an IR code via the USB-UIRT hardware."
irCode = "IR Code:"
learnButton = "Learn an IR Code..."
repeatCount = "Repeat Count:"
infinite = "Infinite"
wait1 = "Wait:"
wait2 = "ms of IR inactivity before transmission"
zone = "Zone:"
zoneChoices = (
"All",
"Ext. Jack R-Pin",
"Ext. Jack L-Pin",
"Internal Emitter",
class LearnDialog:
title = "Learn IR Code"
frequency = "Frequency"
signalQuality = "Signal"
progress = "Learn Progress"
acceptBurstButton = "Accept Burst"
forceRaw = "Force RAW-Mode learning"
helpText = \
"1. Aim remote directly at USB-UIRT\n"\
"approximately 6 inches from USB-UIRT face.\n\n"\
"2. PRESS and HOLD the desired button on\n"\
"your remote until learning is complete..."
INVALID_HANDLE_VALUE = -1
UINT32 = c_uint
class UUINFO(Structure):
_fields_ = (
('fwVersion', c_uint),
('protVersion', c_uint),
('fwDateDay', c_ubyte),
('fwDateMonth', c_ubyte),
('fwDateYear', c_ubyte),
PUUINFO = POINTER(UUINFO)
UUIRTDRV_ERR_NO_DEVICE = 0x20000001
UUIRTDRV_ERR_NO_RESP = 0x20000002
UUIRTDRV_ERR_NO_DLL = 0x20000003
UUIRTDRV_ERR_VERSION = 0x20000004
UUIRTDRV_CFG_LEDRX = 0x0001
UUIRTDRV_CFG_LEDTX = 0x0002
UUIRTDRV_CFG_LEGACYRX = 0x0004
UUIRTDRV_IRFMT_UUIRT = 0x0000
UUIRTDRV_IRFMT_PRONTO = 0x0010
UUIRTDRV_IRFMT_LEARN_FORCERAW = 0x0100
UUIRTDRV_IRFMT_LEARN_FORCESTRUC = 0x0200
UUIRTDRV_IRFMT_LEARN_FORCEFREQ = 0x0400
UUIRTDRV_IRFMT_LEARN_FREQDETECT = 0x0800
UUCALLBACKPROC = WINFUNCTYPE(c_int, POINTER(c_ubyte), c_ulong, c_ulong)
LEARNCALLBACKPROC = WINFUNCTYPE(c_int, c_uint, c_uint, c_ulong, c_void_p)
class USB_UIRT(eg.IrDecoderPlugin):
text = Text
def __init__(self):
eg.IrDecoderPlugin.__init__(self, 50.0)
self.dll = None
self.enabled = False
self.AddAction(TransmitIR)
def __close__(self):
self.irDecoder.Close()
def __start__(
self,
ledRX=True,
ledTX=True,
legacyRX=False,
repeatStopCodes=False,
self.args = (ledRX, ledTX, legacyRX, repeatStopCodes)
self.codeFormat = UUIRTDRV_IRFMT_PRONTO
try:
dll = WinDLL('uuirtdrv')
except:
raise self.Exceptions.DriverNotFound
puDrvVersion = c_uint(0)
if not dll.UUIRTGetDrvInfo(byref(puDrvVersion)):
raise self.Exception("Unable to retrieve uuirtdrv version!")
if puDrvVersion.value != 0x0100:
raise self.Exception("Invalid uuirtdrv version!")
if self.info.evalName[-1].isdigit():
self.deviceStr = "USB-UIRT-%s" % self.info.evalName[-1]
self.deviceStr = "USB-UIRT"
hDrvHandle = dll.UUIRTOpenEx(self.deviceStr, 0, 0, 0)
if hDrvHandle == INVALID_HANDLE_VALUE:
err = GetLastError()
if err == UUIRTDRV_ERR_NO_DLL:
elif err == UUIRTDRV_ERR_NO_DEVICE:
raise self.Exceptions.DeviceNotFound
elif err == UUIRTDRV_ERR_NO_RESP:
raise self.Exceptions.DeviceInitFailed
self.hDrvHandle = hDrvHandle
puuInfo = UUINFO()
if not dll.UUIRTGetUUIRTInfo(hDrvHandle, byref(puuInfo)):
self.firmwareVersion = str(puuInfo.fwVersion >> 8) + '.' + str(puuInfo.fwVersion & 0xFF)
self.protocolVersion = str(puuInfo.protVersion >> 8) + '.' + str(puuInfo.protVersion & 0xFF)
self.firmwareDate = datetime.date(
puuInfo.fwDateYear+2000,
puuInfo.fwDateMonth,
puuInfo.fwDateDay
self.dll = dll
self.receiveProc = UUCALLBACKPROC(self.ReceiveCallback)
res = dll.UUIRTSetRawReceiveCallback(self.hDrvHandle, self.receiveProc, 0)
if not res:
self.dll = None
raise self.Exception("Error calling UUIRTSetRawReceiveCallback")
self.SetConfig(ledRX, ledTX, legacyRX, repeatStopCodes)
self.enabled = True
eg.Bind("System.DeviceRemoved", self.OnDeviceRemoved)
def restartDriver(self):
if self.dll:
self.dll.UUIRTClose(self.hDrvHandle)
os.system("c:\\Program Files\\EventGhost\\devcon disable USB*VID_0403*PID_F850*")
os.system("c:\\Program Files\\EventGhost\\devcon enable USB*VID_0403*PID_F850*")
self.__start__(*self.args)
def __stop__(self):
eg.Unbind("System.DeviceRemoved", self.OnDeviceRemoved)
dll = self.dll
if dll:
self.dll = None
if not dll.UUIRTClose(self.hDrvHandle):
raise self.Exception("Error calling UUIRTClose")
# fix for USB-UIRT driver bug, See OnComputerSuspend for details.
self.hDrvHandle = dll.UUIRTOpenEx(self.deviceStr, 0, 0, 0)
# without the UUIRTSetUUIRTConfig call, the driver seems to need
# much more time to close.
self.SetConfig(*self.args)
dll.UUIRTSetReceiveCallback(self.hDrvHandle, None, 0)
def OnComputerSuspend(self, suspendType):
# The USB-UIRT driver seems to have a bug, that prevents the wake-up
# from standby feature to work, if UUIRTSetRawReceiveCallback was used.
# To workaround the problem, we re-open the device with
# UUIRTSetReceiveCallback just before the system goes into standby and
# later do the reverse once the system comes back from standby.
dll = self.dll
if dll is None:
return
def OnComputerResume(self, suspendType):
dll = self.dll
if dll is None:
return
def OnDeviceRemoved(self, event):
if event.payload[0].split("#")[1] == 'Vid_0403&Pid_f850':
if self.dll:
if not self.dll.UUIRTClose(self.hDrvHandle):
self.dll = None
eg.Bind("System.DeviceAttached", self.OnDeviceAttached)
def OnDeviceAttached(self, event):
if self.enabled:
eg.Unbind("System.DeviceAttached", self.OnDeviceAttached)
def SetConfig(self, ledRX, ledTX, legacyRX, repeatStopCodes=False):
value = 0
if ledRX:
value |= UUIRTDRV_CFG_LEDRX
if ledTX:
value |= UUIRTDRV_CFG_LEDTX
if legacyRX:
value |= UUIRTDRV_CFG_LEGACYRX
if repeatStopCodes:
value |= 16
if not self.dll.UUIRTSetUUIRTConfig(self.hDrvHandle, UINT32(value)):
self.dll = None
raise self.Exception("Error calling UUIRTSetUUIRTConfig")
def ReceiveCallback(self, buf, length, userdata):
# TODO: find a more efficient way to find the terminator
data = []
for i in range(2, 1024):
value = buf
data.append(value)
if value == 255:
break
self.irDecoder.Decode(data, len(data))
return 0
def Configure(
self,
ledRx=True,
ledTx=True,
legacyRx=None,
text = self.text
if self.dll:
protocolVersion = self.protocolVersion
firmwareVersion = self.firmwareVersion
firmwareDate = self.firmwareDate.strftime("%x")
protocolVersion = text.notFound
firmwareVersion = text.notFound
firmwareDate = text.notFound
panel = eg.ConfigPanel()
ledRxCheckBox = panel.CheckBox(ledRx, text.blinkRx)
ledTxCheckBox = panel.CheckBox(ledTx, text.blinkTx)
legacyRxCheckBox = panel.CheckBox(legacyRx, text.legacyCodes)
stopCodesRxCheckBox = panel.CheckBox(repeatStopCodes, text.stopCodes)
infoGroupSizer = wx.StaticBoxSizer(
wx.StaticBox(panel, -1, text.uuInfo),
wx.VERTICAL
infoSizer = wx.FlexGridSizer(3, 2)
infoSizer.AddMany([
(panel.StaticText(text.uuProtocol), 0, wx.EXPAND),
(panel.StaticText(protocolVersion), 0, wx.EXPAND),
(panel.StaticText(text.uuFirmVersion), 0, wx.EXPAND),
(panel.StaticText(firmwareVersion), 0, wx.EXPAND),
(panel.StaticText(text.uuFirmDate), 0, wx.EXPAND),
(panel.StaticText(firmwareDate), 0, wx.EXPAND),
infoGroupSizer.Add(infoSizer, 0, wx.LEFT, 5)
panel.sizer.Add(infoGroupSizer, 0, wx.EXPAND)
panel.sizer.Add((15, 15))
ledGroupSizer = wx.StaticBoxSizer(
wx.StaticBox(panel, -1, text.redIndicator),
wx.VERTICAL
ledGroupSizer.Add(ledRxCheckBox, 0, wx.ALL, 10)
ledGroupSizer.Add(ledTxCheckBox, 0, wx.ALL, 10)
panel.sizer.Add(ledGroupSizer, 0, wx.EXPAND)
receiveGroupSizer = wx.StaticBoxSizer(
wx.StaticBox(panel, -1, text.irReception),
wx.VERTICAL
receiveGroupSizer.Add(legacyRxCheckBox, 0, wx.ALL, 10)
receiveGroupSizer.Add(stopCodesRxCheckBox, 0, wx.ALL, 10)
panel.sizer.Add(receiveGroupSizer, 0, wx.EXPAND)
while panel.Affirmed():
panel.SetResult(
ledRxCheckBox.GetValue(),
ledTxCheckBox.GetValue(),
legacyRxCheckBox.GetValue(),
stopCodesRxCheckBox.GetValue(),
class TransmitIR(eg.ActionClass):
repeatCount = 4
inactivityWaitTime = 0
def __call__(self, code='', repeatCount=4, inactivityWaitTime=0):
if not self.plugin.dll:
raise self.Exceptions.DeviceNotReady
if code.startswith("RESTART"):
self.plugin.restartDriver()
return
if len(code) > 5:
start = 0
if code[0] == "Z":
start = 2
if code[start+3] == "R":
codeFormat = UUIRTDRV_IRFMT_UUIRT
elif code[start+4] == " ":
codeFormat = UUIRTDRV_IRFMT_LEARN_FORCESTRUC
repeatCount = 0
code = ""
tryagain = True
while tryagain:
if not self.plugin.dll.UUIRTTransmitIR(
self.plugin.hDrvHandle, # hHandle
c_char_p(code), # IRCode
codeFormat, # codeFormat
repeatCount, # repeatCount
inactivityWaitTime, # inactivityWaitTime
0, # hEvent
0, # reserved1
0 # reserved2
if tryagain:
tryagain = False
return
def GetLabel(self, code='', repeatCount=4, inactivityWaitTime=0):
return self.name
def Configure(self, code='', repeatCount=None, inactivityWaitTime=None):
text = self.text
if repeatCount is None:
repeatCount = self.repeatCount
if inactivityWaitTime is None:
inactivityWaitTime = self.inactivityWaitTime
if len(code) > 0:
zone = 0
if code[0] == "Z":
zone = int(code[1])
code = code[2:]
zone = 0
editCtrl = panel.TextCtrl(code, style=wx.TE_MULTILINE)
font = editCtrl.GetFont()
font.SetFaceName("Courier New")
editCtrl.SetFont(font)
editCtrl.SetMinSize((-1, 100))
repeatCtrl = eg.SpinIntCtrl(panel, -1, value=repeatCount, min=1, max=127)
repeatCtrl.SetInitialSize((50, -1))
infiniteCtrl = wx.CheckBox(panel, -1, text.infinite)
if repeatCount == 32767:
repeatCtrl.SetValue(4)
repeatCtrl.Enable(False)
infiniteCtrl.SetValue(True)
repeatCtrl.SetValue(repeatCount)
def OnInfiniteCtrl(event):
repeatCtrl.Enable(not infiniteCtrl.GetValue())
event.Skip()
infiniteCtrl.Bind(wx.EVT_CHECKBOX, OnInfiniteCtrl)
waitCtrl = panel.SpinIntCtrl(inactivityWaitTime, 0, 500)
waitCtrl.SetInitialSize((50, -1))
zoneCtrl = panel.Choice(zone, text.zoneChoices)
learnButton = panel.Button(text.learnButton)
if self.plugin.dll is None:
learnButton.Enable(False)
panel.sizer.Add(panel.StaticText(text.irCode))
panel.sizer.Add(editCtrl, 1, wx.EXPAND)
panel.sizer.Add((5, 5))
stFlags = wx.ALIGN_CENTER_VERTICAL|wx.ALIGN_RIGHT
gridSizer = wx.GridBagSizer(5, 5)
gridSizer.Add(panel.StaticText(text.repeatCount), (0, 0), flag=stFlags)
tmpSizer = wx.BoxSizer(wx.HORIZONTAL)
tmpSizer.Add(repeatCtrl)
tmpSizer.Add((5, 5))
tmpSizer.Add(infiniteCtrl, 0, wx.ALIGN_CENTER_VERTICAL)
gridSizer.Add(tmpSizer, (0, 1))
gridSizer.Add(panel.StaticText(text.wait1), (1, 0), flag=stFlags)
tmpSizer.Add(waitCtrl)
tmpSizer.Add(panel.StaticText(text.wait2), 0, wx.ALIGN_CENTER_VERTICAL)
gridSizer.Add(tmpSizer, (1, 1))
gridSizer.Add(panel.StaticText(text.zone), (2, 0), flag=stFlags)
gridSizer.Add(zoneCtrl, (2, 1))
gridSizer.AddGrowableCol(4, 1)
gridSizer.Add(
learnButton,
(0,5),
flag=wx.ALIGN_RIGHT|wx.EXPAND
panel.sizer.Add(gridSizer, 0, wx.EXPAND)
def LearnIR(event):
learnDialog = IRLearnDialog(
None,
self.plugin.dll,
text.LearnDialog
learnDialog.ShowModal()
if learnDialog.code:
editCtrl.SetValue(learnDialog.code)
learnDialog.AbortLearnThreadWait()
learnDialog.Destroy()
learnButton.Bind(wx.EVT_BUTTON, LearnIR)
zone = zoneCtrl.GetValue()
if zone > 0:
code = "Z" + str(zone) + editCtrl.GetValue()
code = editCtrl.GetValue()
if infiniteCtrl.GetValue():
self.__class__.repeatCount = 32767
self.__class__.repeatCount = repeatCtrl.GetValue()
self.__class__.inactivityWaitTime = waitCtrl.GetValue()
panel.SetResult(
code,
self.repeatCount,
class IRLearnDialog(wx.Dialog):
def __init__(self, parent, dll, hDrvHandle, text):
self.dll = dll
self.code = None
wx.Dialog.__init__(
self,
parent,
-1,
text.title,
style=wx.DEFAULT_DIALOG_STYLE|wx.RESIZE_BORDER
staticText = wx.StaticText(self, -1, text.helpText)
sb = wx.StaticBox(self, -1, text.progress)
progressSizer = wx.StaticBoxSizer(sb, wx.VERTICAL)
progressCtrl = wx.Gauge(self, -1, 100, size=(250, 25))
self.progressCtrl = progressCtrl
progressSizer.Add(progressCtrl, 0, wx.ALL|wx.EXPAND, 5)
sb = wx.StaticBox(self, -1, text.signalQuality)
sigQualitySizer = wx.StaticBoxSizer(sb, wx.HORIZONTAL)
sigQualityCtrl = wx.Gauge(
self,
-1,
100,
size=(25, 100),
style=wx.GA_VERTICAL|wx.GA_SMOOTH
self.sigQualityCtrl = sigQualityCtrl
sigQualitySizer.Add(sigQualityCtrl, 0, wx.ALL|wx.EXPAND, 5)
sb = wx.StaticBox(self, -1, text.frequency)
carrierFreqSizer = wx.StaticBoxSizer(sb, wx.HORIZONTAL)
carrierFreqCtrl = wx.StaticText(self, -1, "-", style=wx.ALIGN_CENTER)
self.carrierFreqCtrl = carrierFreqCtrl
carrierFreqSizer.Add(carrierFreqCtrl, 1, wx.EXPAND|wx.ALL, 5)
forceRawCtrl = wx.CheckBox(self, -1, text.forceRaw)
forceRawCtrl.Bind(wx.EVT_CHECKBOX, self.OnRawBox)
self.forceRawCtrl = forceRawCtrl
cancelButton = wx.Button(self, wx.ID_CANCEL, eg.text.General.cancel)
cancelButton.Bind(wx.EVT_BUTTON, self.OnCancel)
cancelButton.SetDefault()
burstButton = wx.Button(self, wx.ID_CANCEL, text.acceptBurstButton)
burstButton.Bind(wx.EVT_BUTTON, self.OnAcceptBurst)
burstButton.Enable(False)
self.burstButton = burstButton
leftSizer = wx.BoxSizer(wx.VERTICAL)
leftSizer.Add(staticText, 0, wx.EXPAND|wx.TOP, 5)
leftSizer.Add((5, 5), 1)
leftSizer.Add(forceRawCtrl)
rightSizer = wx.BoxSizer(wx.VERTICAL)
rightSizer.Add((15, 15))
rightSizer.Add(burstButton, 0, wx.EXPAND|wx.ALIGN_RIGHT)
rightSizer.Add((5, 5))
rightSizer.Add(cancelButton, 0, wx.EXPAND|wx.ALIGN_RIGHT)
rightSizer.Add((0, 0), 1)
rightSizer.Add(carrierFreqSizer, 0, wx.EXPAND)
upperRowSizer = wx.BoxSizer(wx.HORIZONTAL)
upperRowSizer.Add(leftSizer, 1, wx.EXPAND)
upperRowSizer.Add((5, 5))
upperRowSizer.Add(sigQualitySizer, 0, wx.EXPAND)
upperRowSizer.Add(rightSizer, 0, wx.EXPAND)
sizer = wx.BoxSizer(wx.VERTICAL)
sizer.Add(upperRowSizer, 1, wx.EXPAND|wx.ALL, 5)
sizer.Add(progressSizer, 0, wx.EXPAND|wx.ALL, 5)
self.SetSizer(sizer)
self.SetAutoLayout(True)
sizer.Fit(self)
self.SetMinSize(self.GetSize())
self.Bind(wx.EVT_CLOSE, self.OnClose)
self.StartLearnIR()
def SetRawMode(self, flag=True):
if flag:
self.codeFormat = UUIRTDRV_IRFMT_LEARN_FORCERAW
def StartLearnIR(self):
self.learnThreadAbortEvent = threading.Event()
self.bAbortLearn = c_int(0)
self.learnThread = threading.Thread(target=self.LearnThread)
self.learnThread.start()
def AbortLearnThread(self):
self.bAbortLearn.value = True
def AbortLearnThreadWait(self):
self.learnThreadAbortEvent.wait(10)
def AcceptBurst(self):
self.bAbortLearn.value = -1
def LearnThread(self):
learnBuffer = create_string_buffer('\000' * 2048)
self.dll.UUIRTLearnIR(
self.hDrvHandle, # hHandle
self.codeFormat, # codeFormat
learnBuffer, # IRCode buffer
LEARNCALLBACKPROC(self.LearnCallback), # progressProc
0x5a5a5a5a, # userData
byref(self.bAbortLearn), # *pAbort
0, # param1
0, # reserved0
0 # reserved1
if self.bAbortLearn.value != 1:
self.OnLearnSuccess(learnBuffer.value)
self.learnThreadAbortEvent.set()
def LearnCallback(self, progress, sigQuality, carrierFreq, userData):
if progress > 0:
self.burstButton.Enable(True)
self.progressCtrl.SetValue(progress)
self.sigQualityCtrl.SetValue(sigQuality)
self.carrierFreqCtrl.SetLabel(
"%d.%03d kHz" % (carrierFreq / 1000, carrierFreq % 1000)
return 0
def OnLearnSuccess(self, code):
self.code = code
self.Close()
def OnRawBox(self, event):
self.AbortLearnThreadWait()
self.SetRawMode(self.forceRawCtrl.GetValue())
self.burstButton.Enable(False)
self.progressCtrl.SetValue(0)
self.sigQualityCtrl.SetValue(0)
self.StartLearnIR()
def OnAcceptBurst(self, event):
self.AcceptBurst()
def OnClose(self, event):
self.AbortLearnThread()
event.Skip()
def OnCancel(self, event):
self.Close()
[/code]
Note two things in the above code: (1) the new restartDriver method, and (2) the change to TransmitIR::__call__, in which a code starting with "RESTART" triggers the restartDriver method so you can do testing.
I combine the above code with the following code in the EventGhost XML:
<Macro Name="Restart USB-UIRT Loop" Expanded="True">
  <Event Name="Main.OnInit" />
  <Event Name="Main.RestartUSBUIRT" />
  <Action Name="IR Xmit: JUNK">USB_UIRT.TransmitIR(u'Z30000 0048 0001 0011 0017 0163 0017 0061 0017 00a3 0017 00a3 0017 0061 0017 0061 0017 0061 0017 0061 0017 00a3 0017 00a3 0017 00a3 0017 00a3 0017 00a3 0017 00a3 0017 00a3 0017 00a3 0017 00a3 0017 0163', 1, 1)</Action>
  <Action>EventGhost.TriggerEvent(u'RestartUSBUIRT', 60.0)</Action>
This generates a junk IR transmission every 60 seconds. If a problem with the driver is detected, the restartDriver code should be called.
I have only been running the above for a few days, but it seems to have helped.
Good luck![/quote]
Recently all gone well.
____________________________________
wow gold|diablo 3 gold|Path of Exile items|GW2 Gold
relgycandy
Post by relgycandy » Mon Feb 25, 2013 11:32 am
"""<rst>
:align: center
import eg
eg.RegisterPlugin(
name = "USB-UIRT",
kind = "remote",
# '\n\n<p>'
icon = (
import wx
string_at,
import datetime
import threading
import os
class Text:
class TransmitIR:
irCode = "IR Code:"
wait1 = "Wait:"
zone = "Zone:"
zoneChoices = (
"All",
"Ext. Jack R-Pin",
"Ext. Jack L-Pin",
"Internal Emitter",
class LearnDialog:
helpText = \
UINT32 = c_uint
_fields_ = (
text = Text
def __init__(self):
self.dll = None
def __start__(
self,
ledRX=True,
ledTX=True,
legacyRX=False,
try:
except:
puuInfo = UUINFO()
puuInfo.fwDateDay
self.dll = dll
if not res:
self.dll = None
self.enabled = True
if self.dll:
def __stop__(self):
dll = self.dll
if dll:
self.dll = None
dll = self.dll
if dll is None:
return
dll = self.dll
if dll is None:
return
if self.dll:
self.dll = None
if self.enabled:
value = 0
if ledRX:
if ledTX:
if legacyRX:
if repeatStopCodes:
value |= 16
self.dll = None
data = []
value = buf
data.append(value)
if value == 255:
break
return 0
def Configure(
self,
ledRx=True,
ledTx=True,
legacyRx=None,
text = self.text
if self.dll:
wx.VERTICAL
infoSizer.AddMany([
wx.VERTICAL
wx.VERTICAL
panel.SetResult(
repeatCount = 4
return
if len(code) > 5:
start = 0
if code[0] == "Z":
start = 2
repeatCount = 0
code = ""
tryagain = True
while tryagain:
0, # hEvent
0, # reserved1
0 # reserved2
if tryagain:
tryagain = False
return
return self.name
text = self.text
if len(code) > 0:
zone = 0
if code[0] == "Z":
zone = int(code[1])
code = code[2:]
zone = 0
event.Skip()
gridSizer.Add(
learnButton,
(0,5),
def LearnIR(event):
None,
self.plugin.dll,
text.LearnDialog
if zone > 0:
panel.SetResult(
code,
self.repeatCount,
self.dll = dll
self.code = None
wx.Dialog.__init__(
self,
parent,
-1,
text.title,
self,
-1,
100,
size=(25, 100),
sizer.Fit(self)
self.StartLearnIR()
if flag:
0, # param1
0, # reserved0
0 # reserved1
if progress > 0:
return 0
self.code = code
self.Close()
self.StartLearnIR()
self.AcceptBurst()
event.Skip()
self.Close()
[/code]
Good luck![/quote]
aldi13
Post by aldi13 » Thu Jul 24, 2014 5:45 pm
I still have not been able to make this thing work reliably. Anyone figured it out? I bought mine in Dec 2013 and it worked great up until 2 months ago.
  • -I run Win8 x64
    -My computer does not sleep
    -Device usually fails around 4 hours after boot
    -If I quit EG disable/enable in Device Manager the USB-UIRT plugin will not load in EG. Error message changes from Device is not Ready to Failed to load USB-UIRT plugin. So my deacon script does not help.
    -I rerouted all USB cables and tried to keep them away from interference.
    -I added Ferrite Beads to USB Cable and External IR Blaster near the place where they connect to USB-UIRT.
    -I tried disabling power save on all USB device in the device manager.
    -The only thing I can do to get it working when it stops responding is reboot computer or unplug/replug device sometimes works.
SamWest
Post by SamWest » Tue Jul 29, 2014 10:53 am
In case anyone is interested, I was getting a similar 'Device not found' error from the USB-UIRT, except for me, this happened whenever my PC came out of sleep or hibernate.
Manually disabling the USB-UIRT device in Windows Device Manager and restarting EventGhost fixed it, but no other combination of plugin restarting and devcon.exe commands from within EventGhost would work.
My final working solution, tested on Windows 8, was to:
1. Copy devcon.exe (from http://support.microsoft.com/kb/311272) to c:\Program Files\EventGhost\
2. Make sure UAC is off or EventGhost is running as an Administrator
3. Add the following macro to eventghost:
    <Macro Name="On Resume" Expanded="True">
        <Event Name="System.Resume" />
        <Action Name="Restart EventGhost & USB-UIRT">
            System.Execute(u'cmd', u'/c taskkill /f /im "eventghost.exe" && c:\\Progra~1\\EventGhost\\devcon disable USB*VID_0403*PID_F850* && c:\\Progra~1\\EventGhost\\devcon enable USB*VID_0403*PID_F850* && start /MIN /D "c:\\Program Files\\EventGhost" EventGhost.exe', 0, False, 2, u'', False, False)
On a System.Resume (from sleep) event, this just kills the eventghost process, disables and reenables the USB-UIRT device, and starts eventghost again. Not elegant, but it seems to work quite well. I'd be interested if anyone else has come up with a nicer solution to the resume-from-sleep USB-UIRT not responding problem. If not, I thought this might help someone else.
-Sam.
