Can I intercept IR commands with EG?
barnabas1969
Post by barnabas1969 » Sat Feb 04, 2012 3:09 am
I haven't installed Event Ghost yet. I'm using Windows 7 Media Center. I am currently using IRSS (IR Server Suite) to intercept some IR commands to trigger some macros and send some RS-232 commands to my TV and AVR. I am disappointed with IRSS, because the macros don't correctly save or interpret the values of variables, and because the command-line interface has a problem with pauses that are embedded into the macro.
I'm very interested in EG, especially because of the new RCAware plugin and hardware... but I will need to be able to continue to intercept IR commands in order to make it work the way I want. I will also need to continue to send RS-232 commands, because my AVR does not have an HDMI switch in it (which, obviously, means that it is not HDMI-CEC compliant).
I understand that EG can send RS-232 commands, and that it will work with the MCE remote receiver. I just need to confirm that EG will be able to trigger an event/action when it receives specified IR commands.
Please let me know if this is possible.
Thank you.
Re: Can I intercept IR commands with EG?
Post by jonib » Sat Feb 04, 2012 8:52 am
barnabas1969 wrote:I just need to confirm that EG will be able to trigger an event/action when it receives specified IR commands.
You have full control what macro(s) are triggered when Eventghost gets an event.
barnabas1969
Post by barnabas1969 » Sat Feb 04, 2012 10:48 pm
Thanks for the answer, but does that mean that a IR command from an MCE remote will be read as an event? Also, is it better to use a USB-UIRT instead of the MCE receiver?
I think I already know the answers, but I want to get confirmation before I take the leap. IRSS seems to have some bugs... and I can't get any help from the Media Portal folks.
Thanks in advance.
Post by jonib » Sun Feb 05, 2012 5:15 pm
barnabas1969 wrote:but does that mean that a IR command from an MCE remote will be read as an event?
Yes, as long as you use the right plugin and have it configured correctly.
Hopefully somebody else can help with that as I haven't used either.
barnabas1969
Post by barnabas1969 » Mon Feb 06, 2012 12:39 am
Thanks jonib. What IR receiver do you use?
Post by jonib » Mon Feb 06, 2012 9:19 am
barnabas1969 wrote:Thanks jonib. What IR receiver do you use?
The IR receiver built in to my TechnoTrend digital tuner card (using TechnoTrend Ir Bda driver).
mickelin
Post by mickelin » Fri Feb 10, 2012 6:36 pm
I use both usb-uirt and original mce receiver. Both work fine for receiving, but usb-uirt can also be used for transmitting ir. That does not work with mce receiver on xp.
barnabas1969
Post by barnabas1969 » Fri Feb 10, 2012 8:14 pm
mickelin wrote:I use both usb-uirt and original mce receiver. Both work fine for receiving, but usb-uirt can also be used for transmitting ir. That does not work with mce receiver on xp.
Thanks for the info. I currently use two dongles on my machine as well. One is for a cheapie remote I got on Amazon that does Windows commands (mouse pad, close window, alt-tab, etc) and the other is the MCE dongle. If the USB-UIRT will do all of those functions, it would be great to have only one dongle for IR.
Is there a reason why you use both the MCE receiver and the USB-UIRT? Does the USB-UIRT not work to receive the MCE commands?
mickelin
Post by mickelin » Sat Feb 11, 2012 8:24 pm
Sorry, I wasn't clear. They are not in the same pc. I use usb-uirt in two of my pcs, mce oem in a third and a no name mce in a fourth. No need to have more than one in the same pc... Usb-uirt receives all ir signals from all remotes I've tried. It is a great product!
