Logitech Harmony Smart Control ... interesting possibilities
Re: Logitech Harmony Smart Control ... interesting possibilities
Post by kgschlosser » Sun Jun 02, 2019 12:30 am
https://community.logitech.com/s/questi ... i-via-xmpp
you need to have a look at this.
Also the sleek XMPP library that is used by the library has many issues with it and is no longer being developed. While I have managed to fix some of the issues there are still more with it. I have been working on the problems in sleekxmpp But that process has now been stalled by the recent web server conundrum
007craft
Post by 007craft » Mon Jan 06, 2020 10:52 pm
can somebody help me get harmonhubcontrol.exe working (since it doesnt look like there will ever be an eventghost plugin)
i compiled it myself sine the previous file linked in this thread is a broken link now.
if i just enter
HarmonyHubControl.exe 192.168.1.136
it just returns nothing and im back to prompt, but any other ip i enter and it will timeout, so it is finding it on he right ip
example:
HarmonyHubControl.exe 192.168.1.137
HARMONY COMMUNICATION LOGIN : FAILURE
ERROR : connectToHarmony : Unable to connect to specified IP Address on specified Port
so now when i enter
HarmonyHubControl.exe myemail mypassword 192.168.1.136 list_activities
it just returns the same communication login failure error.,
Post by kgschlosser » Tue Jan 07, 2020 1:37 am
the problem is that logitech tanked their API.. so it's not going to work.. no matter what you do.
with no means to authenticate with their servers there is not going to be a way to provide control.
