USB-UIRT "Device not Ready" How to execute Macro on Error
aldi13
Post by aldi13 » Wed Jul 16, 2014 3:11 pm
I consistently have trouble with my USB-UIRT. It's stops responding and I get the following error in the log when I attempt to use the device to transmit an IR command.
"Device not Ready"
How can I use the error in the Log as an event to trigger a Macro? EG does not allow me to drag the error over to a Macro.
If anyone has any ideas on the USB-UIRT plugin I am open to those too.
I have tried moving my USB-UIRT away from other device to avoid interference.
I have added Ferrite Beads to USB & IR Blaster
I have device plugged into Powered USB Hub (My Only Option as I run USB-UIRT over USB Cat 5 Extender)
Thanks in advance
Re: USB-UIRT "Device not Ready" How to execute Macro on Erro
Post by Pako » Wed Jul 16, 2014 4:05 pm
aldi13 wrote:How can I use the error in the Log as an event to trigger a Macro? EG does not allow me to drag the error over to a Macro.
I've never tried it, but theoretically EventGhost Application Control Plugin could help.
aldi13
Post by aldi13 » Wed Jul 16, 2014 5:03 pm
Thanks. Looking forward to testing.
aldi13
Post by aldi13 » Fri Jul 18, 2014 4:31 pm
The plugin works perfectly. Thanks so much for pointing me in the right direction.
Bob
Post by Bob » Tue Feb 10, 2015 8:04 pm
I've got the same problem. Can you post an XML sample of your config to restart EG when USB UIRT "crashed" ?
Thanks in advance,
Bob
aldi13
Post by aldi13 » Tue Feb 10, 2015 8:26 pm
I developed a sequence to restart the USB-UIRT but it never works. I always have to reboot the computer. The Devcon method doesn't seem to work for me. I can post some code later on when I get home.
