Event Ghost Stops Acknowledging New Events
yattayatta
Re: Event Ghost Stops Acknowledging New Events
Post by yattayatta » Tue Jun 14, 2016 10:50 am
Thanks for your offer, but I really think its a problem with the PID/VID of the device that seems to have been customized by the retailer to work with his tv box systems. Unless I can find a way to reset the pid/vid / firmware of the device I dont think I can use it - and as mentioned tools to do that dont detect the device.
Post by kgschlosser » Tue Jun 14, 2016 9:24 pm
what is the hardware ID for the receiver??
i want to check and see if it is what it's supposed to be
Post by kgschlosser » Tue Jun 14, 2016 9:53 pm
ok what version of the tira do you have also?
and have you tried the ftdi drivers??
http://www.ftdichip.com/Drivers/D2XX.htm
that is the most recent for windows 10
if you have the tira-4, and i do not know if it is even out yet.
then there is a possibility it could be this driver
http://www.ftdichip.com/Drivers/VCP.htm
