[NOT A BUG]EG 0.5 Beta 4 Add Event
Post by kgschlosser » Sun Sep 25, 2016 2:49 am
I am not sure where to put this bug. but since there doesn't seem to be any movement on the GitHub i thought this might be a better place to put it.
and then anyone that wants to have the Add Event Dialog working in EG 0.5 Beta 4 can make this change.
there is a coding error in the Add Event Dialog.
It won't even open the dialog.
I have traced the problem to the EventItem.py file
this code below
 def GetArguments(self):
        return self.name
should be this (or a tuple)
        return [self.name]
the name parameter is set in NewEvent.py
which is a string.
here in the code below.
if label is None:
    name = eg.event.string
    needsConfigure = True
    eventItem = document.EventItem.Create(parent, pos, name=name)
    eventItem.Select()
and then when it goes to configure the item in the NewEvent.py file
if (
    needsConfigure and
    not eg.UndoHandler.Configure(document).Do(item, True)
it passes an instance of it's self to the Configure
which calls the GetArguments
newArgs = ActionThreadFunc(item.GetArguments)()
oldArgs = DeepCopy(newArgs)
and a string is returned from the GetArguments
and then passed to the Creation of the dialog with a *prefix which turns the string into a tuple and the dialog thinks however many characters the last event had is what it is being passed to it for arguments when it only has ability to handle 2
dialog = eg.ConfigDialog.Create(item, *oldArgs)
Re: EG 0.5 Beta 4 Add Event
Post by Sem;colon » Sun Sep 25, 2016 4:03 pm
Hi K,
are you sure you don't use an older version of EventItem.py?
I just had a quick look and I can't reproduce the issue, I guess it has been fixed already.
e.g. in my EventItem.py is
        return (self.name, )
Post by kgschlosser » Mon Sep 26, 2016 12:27 am
ahhhh ok I know what happened.
because of a code inspection and and it thought the returned variable had redundant parenthesis.
