Parallel Port Pins High/Low
Chaemelion
Post by Chaemelion » Wed Jul 29, 2009 4:31 am
I know there have been a few discussions here about parallel port support, but as far as I can tell, they're all about actually connecting devices to them. I was wondering if it'd be possible in upcoming releases add a function to set/read parallel port pins.
NikoMitDaMacht
Re: Parallel Port Pins High/Low
Post by NikoMitDaMacht » Sun Sep 20, 2009 12:56 pm
Yeah i had the same problem so I decided to code a plugin for that.
It is very fundamental and it is my first piece of code in python after a few minutes reading the docs, so don't be supprised that i am using the bitvector class i downloaded somewhere to do the bitcalculations - quick and dirty.
As LPT "driver" I am using the Inpout32 DLL which you can find here http://logix4u.net/Legacy_Ports/Paralle ... NT/XP.html. Just put it into the folder of your EventGhost executable.
[EDIT]I think i forgot to atach the plugin[/EDIT]
LPT.7z
(17.79 KiB) Downloaded 499 times
sjolof
Post by sjolof » Sun Nov 29, 2009 11:51 pm
Nice plugin!
Could you please explain how to read the pins?
(Want to see if my garagedoor is open or closed)
Prinz
Post by Prinz » Mon Nov 30, 2009 9:52 am
sjolof wrote:Nice plugin!
I think, a event will be generated, if the status of a pin is changed. The event name should be something like "LPT IN CHANGED [I/O status]"
If you want to read the bit, a following command should be added to the plugin (at the end):
class Read(eg.ActionBase):
    name = "Reads the Bits"
    description = "You won't guess what this action does."
    def __call__(self):
        return self.inpout.Inp32(0x379)
After the line 19 following instruction must be inserted:
        self.AddAction(Read)
If haven't checked it, I have only modified the given code in the way, which should work.
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
sjolof
Post by sjolof » Tue Dec 01, 2009 8:46 pm
Prinz wrote:Hi,
Regards
Prinz
I hope I can give it a try in the weekend.
Diabl0570
Post by Diabl0570 » Sat Apr 24, 2010 9:49 pm
i'm using the plugin now for a while,
i tryd to edit this plugin a little this is the part i want to edit:
def ThreadLoop(self, stopThreadEvent):
   while not stopThreadEvent.isSet():
      input = self.inpout.Inp32(0x379)
      if self.oldInput != input:
         self.oldInput = input
         self.TriggerEvent("LPT IN CHANGED " + str(input))
         stopThreadEvent.wait(0.1)
i want it to change in this:
         if input == 63:
           self.TriggerEvent("LPT PIN 63 is on")
i get this error:
Traceback (most recent call last) (1462):
  File "C:\Program Files\EventGhost\eg\Classes\PluginManager.py", line 178, in LoadPluginInfo
  File "C:\Program Files\EventGhost\eg\Classes\PluginInfo.py", line 126, in ImportPlugin
  File "C:\Program Files\EventGhost\plugins\LPT\__init__.py", line 51
    if input == 63:
IndentationError: unexpected indent
i'm new to phyton script so excuse me if it is something stupid
thanks in advanced
Diabl0
topix
Post by topix » Sun Apr 25, 2010 8:01 am
Diabl0570 wrote:i want it to change in this:
         if input == 63:
i get this error:
    if input == 63:
The else-statement must start in the same column as the if-statement it belongs to. In your case i think it must be
         if input == 63:
Diabl0570
Post by Diabl0570 » Sun Apr 25, 2010 3:11 pm
thanks that worked!
bskchaos
Post by bskchaos » Mon Apr 26, 2010 2:32 am
can I use this plugin with a ParallelPort Relay Controller?
Tal56
Post by Tal56 » Tue Dec 28, 2010 9:59 pm
Also interested in doing this with a parallel port relay I saw on Ebay, anyone know if this should work? Thanks
