Dividers/headlines in the Tree view
skribb
Post by skribb » Sun May 21, 2017 11:29 am
... would be a good way to improve the organisation of macros
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
Re: Dividers/headlines in the Tree view
Post by kgschlosser » Sun May 21, 2017 5:46 pm
I have been working on a threaded version of the macros running. And I have been trying to think of a way to organize the actual log. And you have me an idea using the fold panel bar. But the fold panel bar could also be used to do the base elements of the tree. I have not figured out how to put a fold panel bar inside another fold panel bar. So something like nested folders would not work. And there is also no means to add an icon on it either. I remember the speed of it not being all that fantastic either I think that is due to the calculations being done for the position while it is rendering. I would have to look at it again.
But the macro/folder item could handle it's own rendering as well as drag and drop name changes things of that nature. This would be a cool idea because the bars them selves could change color if the macro is running. And could be double clicked to show any log information for that macro. I am still thinking in terms of the threaded events. This idea gave me some inspiration. I will have to work on it again.
skribb
Post by skribb » Sun May 21, 2017 11:10 pm
kgschlosser wrote:I have been working on a threaded version of the macros running. And I have been trying to think of a way to organize the actual log. And you have me an idea using the fold panel bar. But the fold panel bar could also be used to do the base elements of the tree. I have not figured out how to put a fold panel bar inside another fold panel bar. So something like nested folders would not work. And there is also no means to add an icon on it either. I remember the speed of it not being all that fantastic either I think that is due to the calculations being done for the position while it is rendering. I would have to look at it again.
Some questions:
  • what is a fold panel bar?
  • What do you mean by changing colors?
  • Folder nesting is working as of now, do you mean it would stop working with the implementations you were considering?
  • Would it not be possible to have like a dummy (empty) macro with another font color/background color to use as headlines?
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
Post by kgschlosser » Mon May 22, 2017 4:03 am
well there are some things that would have to worked out with it.. but here is an example of what a Fold Panel Bar is.
copy and paste this code into a python script and run the script
Be sure to check the Fold Panel menu at the top there are more setting in there
import wx
from cStringIO import StringIO
import wx.lib.agw.foldpanelbar as fpb
def GetCollapsedIconData():
    return (
        '\x89PNG\r\n\x1a\n\x00\x00\x00\rIHDR\x00\x00\x00\x10\x00\x00\x00\x10\x08\x06'
        '\x00\x00\x00\x1f\xf3\xffa\x00\x00\x00\x04sBIT\x08\x08\x08\x08|\x08d\x88\x00'
        '\x00\x01\x8eIDAT8\x8d\xa5\x93-n\xe4@\x10\x85?g\x03\n6lh)\xc4\xd2\x12\xc3\x81'
        '\xd6\xa2I\x90\x154\xb9\x81\x8f1G\xc8\x11\x16\x86\xcd\xa0\x99F\xb3A\x91\xa1'
        '\xc9J&\x96L"5lX\xcc\x0bl\xf7v\xb2\x7fZ\xa5\x98\xebU\xbdz\xf5\\\x9deW\x9f\xf8'
        'H\\\xbfO|{y\x9dT\x15P\x04\x01\x01UPUD\x84\xdb/7YZ\x9f\xa5\n\xce\x97aRU\x8a'
        '\xdc`\xacA\x00\x04P\xf0!0\xf6\x81\xa0\xf0p\xff9\xfb\x85\xe0|\x19&T)K\x8b\x18'
        '\xf9\xa3\xe4\xbe\xf3\x8c^#\xc9\xd5\n\xa8*\xc5?\x9a\x01\x8a\xd2b\r\x1cN\xc3'
        '\x14\t\xce\x97a\xb2F0Ks\xd58\xaa\xc6\xc5\xa6\xf7\xdfya\xe7\xbdR\x13M2\xf9'
        '\xf9qKQ\x1fi\xf6-\x00~T\xfac\x1dq#\x82,\xe5q\x05\x91D\xba@\xefj\xba1\xf0\xdc'
        'zzW\xcff&\xb8,\x89\xa8@Q\xd6\xaaf\xdfRm,\xee\xb1BDxr#\xae\xf5|\xddo\xd6\xe2H'
        '\x18\x15\x84\xa0q@]\xe54\x8d\xa3\xedf\x05M\xe3\xd8Uy\xc4\x15\x8d\xf5\xd7\x8b'
        '~\x82\x0fh\x0e"\xb0\xad,\xee\xb8c\xbb\x18\xe7\x8e;6\xa5\x89\x04\xde\xff\x1c'
        '\x16\xef\xe0p\xfa>\x19\x11\xca\x8d\x8d\xe0\x93\x1b\x01\xd8m\xf3(;x\xa5\xef='
        '\xb7w\xf3\x1d$\x7f\xc1\xe0\xbd\xa7\xeb\xa0(,"Kc\x12\xc1+\xfd\xe8\tI\xee\xed)'
        '\xbf\xbcN\xc1{D\x04k\x05#\x12\xfd\xf2a\xde[\x81\x87\xbb\xdf\x9cr\x1a\x87\xd3'
        '0)\xba>\x83\xd5\xb97o\xe0\xaf\x04\xff\x13?\x00\xd2\xfb\xa9`z\xac\x80w\x00'
        '\x00\x00\x00IEND\xaeB`\x82'
def GetCollapsedIconBitmap():
    return wx.BitmapFromImage(GetCollapsedIconImage())
def GetCollapsedIconImage():
    import cStringIO
    stream = cStringIO.StringIO(GetCollapsedIconData())
    return wx.ImageFromStream(stream)
def GetExpandedIconData():
    return (
        '\x00\x01\x9fIDAT8\x8d\x95\x93\xa1\x8e\xdc0\x14EO\xb2\xc4\xd0\xd2\x12\xb7(mI'
        '\xa4%V\xd1lQT4[4-\x9a\xfe\xc1\xc2|\xc6\xc2~BY\x83:A3E\xd3\xa0*\xa4\xd2\x90H!'
        '\x95\x0c\r\r\x1fK\x81g\xb2\x99\x84\xb4\x0fY\xd6\xbb\xc7\xf7>=\'Iz\xc3\xbcv'
        '\xfbn\xb8\x9c\x15 \xe7\xf3\xc7\x0fw\xc9\xbc7\x99\x03\x0e\xfbn0\x99F+\x85R'
        '\x80RH\x10\x82\x08\xde\x05\x1ef\x90+\xc0\xe1\xd8\ryn\xd0Z-\\A\xb4\xd2\xf7'
        '\x9e\xfbwoF\xc8\x088\x1c\xbbae\xb3\xe8y&\x9a\xdf\xf5\xbd\xe7\xfem\x84\xa4'
        '\x97\xccYf\x16\x8d\xdb\xb2a]\xfeX\x18\xc9s\xc3\xe1\x18\xe7\x94\x12cb\xcc\xb5'
        '\xfa\xb1l8\xf5\x01\xe7\x84\xc7\xb2Y@\xb2\xcc0\x02\xb4\x9a\x88%\xbe\xdc\xb4'
        '\x9e\xb6Zs\xaa74\xadg[6\x88<\xb7]\xc6\x14\x1dL\x86\xe6\x83\xa0\x81\xba\xda'
        '\x10\x02x/\xd4\xd5\x06\r\x840!\x9c\x1fM\x92\xf4\x86\x9f\xbf\xfe\x0c\xd6\x9ae'
        '\xd6u\x8d \xf4\xf5\x165\x9b\x8f\x04\xe1\xc5\xcb\xdb$\x05\x90\xa97@\x04lQas'
        '\xcd*7\x14\xdb\x9aY\xcb\xb8\\\xe9E\x10|\xbc\xf2^\xb0E\x85\xc95_\x9f\n\xaa/'
        '\x05\x10\x81\xce\xc9\xa8\xf6><G\xd8\xed\xbbA)X\xd9\x0c\x01\x9a\xc6Q\x14\xd9h'
        '[\x04\xda\xd6c\xadFkE\xf0\xc2\xab\xd7\xb7\xc9\x08\x00\xf8\xf6\xbd\x1b\x8cQ'
        '\xd8|\xb9\x0f\xd3\x9a\x8a\xc7\x08\x00\x9f?\xdd%\xde\x07\xda\x93\xc3{\x19C'
        '\x8a\x9c\x03\x0b8\x17\xe8\x9d\xbf\x02.>\x13\xc0n\xff{PJ\xc5\xfdP\x11""<\xbc'
        '\xff\x87\xdf\xf8\xbf\xf5\x17FF\xaf\x8f\x8b\xd3\xe6K\x00\x00\x00\x00IEND\xaeB'
        '`\x82'
def GetExpandedIconBitmap():
    return wx.BitmapFromImage(GetExpandedIconImage())
def GetExpandedIconImage():
    stream = StringIO(GetExpandedIconData())
class FoldPanelBar(wx.Frame):
    def __init__(self):
        wx.Frame.__init__(
            self,
            eg.document.frame,
            -1,
            size=(700, 650),
            style=wx.DEFAULT_FRAME_STYLE
        self._flags = 0
        self._pnl = None
        self.SetMenuBar(self.CreateMenuBar())
        self.Bind(wx.EVT_SCROLL, self.OnSlideColour)
        self.ReCreateFoldPanel(0)
    def OnQuit(self, event):
        self.Destroy()
    def ReCreateFoldPanel(self, fpb_flags):
        # delete earlier panel
        self.DestroyChildren()
        # recreate the foldpanelbar
        self._pnl = fpb.FoldPanelBar(
            self,
            -1,
            wx.DefaultPosition,
            wx.Size(-1, -1),
            agwStyle=fpb_flags
        Images = wx.ImageList(16, 16)
        Images.Add(GetExpandedIconBitmap())
        Images.Add(GetCollapsedIconBitmap())
        item = self._pnl.AddFoldPanel(
            "Caption Colours",
            collapsed=False,
            foldIcons=Images
        self._pnl.AddFoldPanelWindow(item,
            wx.StaticText(item, -1, "Set Caption Bar Color #1"),
            fpb.FPB_ALIGN_WIDTH, 5, 20)
        # RED colour spin control
        self._rslider1 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._rslider1,
            2,
            20
        # GREEN colour spin control
        self._gslider1 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._gslider1,
            0,
            20
        # BLUE colour spin control
        self._bslider1 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._bslider1,
            0,
            20
        self._pnl.AddFoldPanelSeparator(item)
            item,
            wx.StaticText(item, -1, "Set Caption Bar Color #2"),
            5,
            20
        self._rslider2 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._rslider2,
            2,
            20
        self._gslider2 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._gslider2,
            0,
            20
        self._bslider2 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._bslider2,
            0,
            20
            item,
            wx.StaticText(item, -1, "Set the Font Color"),
            5,
            20
        self._rslider3 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._rslider3,
            2,
            20
        self._gslider3 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._gslider3,
            0,
            20
        self._bslider3 = wx.Slider(item, -1, 0, 0, 255)
            item,
            self._bslider3,
            0,
            20
        button1 = wx.Button(item, wx.ID_ANY, "Apply To All")
        button1.Bind(wx.EVT_BUTTON, self.OnExpandMe)
        self._pnl.AddFoldPanelWindow(item, button1)
        # read back current gradients and set the sliders
        # for the colour which is now taken as default
        style = self._pnl.GetCaptionStyle(item)
        col = style.GetFirstColour()
        self._rslider1.SetValue(col.Red())
        self._gslider1.SetValue(col.Green())
        self._bslider1.SetValue(col.Blue())
        col = style.GetSecondColour()
        self._rslider2.SetValue(col.Red())
        self._gslider2.SetValue(col.Green())
        self._bslider2.SetValue(col.Blue())
        font_col = style.GetCaptionColour()
        self._rslider3.SetValue(font_col.Red())
        self._gslider3.SetValue(font_col.Green())
        self._bslider3.SetValue(font_col.Blue())
        # put down some caption styles from which the user can
        # select to show how the current or all caption bars will look like
        item = self._pnl.AddFoldPanel("Caption Style", False, foldIcons=Images)
        self.ID_USE_VGRADIENT = wx.NewId()
        self.ID_USE_HGRADIENT = wx.NewId()
        self.ID_USE_SINGLE = wx.NewId()
        self.ID_USE_RECTANGLE = wx.NewId()
        self.ID_USE_FILLED_RECTANGLE = wx.NewId()
        currStyle = wx.RadioButton(
            item,
            self.ID_USE_VGRADIENT,
            "&Vertical Gradient"
            item,
            currStyle,
            fpb.FPB_DEFAULT_SPACING,
            10
        currStyle.SetValue(True)
        radio1 = wx.RadioButton(
            item,
            self.ID_USE_HGRADIENT,
            "&Horizontal Gradient"
        radio2 = wx.RadioButton(item, self.ID_USE_SINGLE, "&Single Colour")
        radio3 = wx.RadioButton(item, self.ID_USE_RECTANGLE, "&Rectangle Box")
        radio4 = wx.RadioButton(
            item,
            self.ID_USE_FILLED_RECTANGLE,
            "&Filled Rectangle Box"
        currStyle.Bind(wx.EVT_RADIOBUTTON, self.OnStyleChange)
        radio1.Bind(wx.EVT_RADIOBUTTON, self.OnStyleChange)
        radio2.Bind(wx.EVT_RADIOBUTTON, self.OnStyleChange)
        radio3.Bind(wx.EVT_RADIOBUTTON, self.OnStyleChange)
        radio4.Bind(wx.EVT_RADIOBUTTON, self.OnStyleChange)
            item,
            radio1,
            10
            item,
            radio2,
            10
            item,
            radio3,
            10
            item,
            radio4,
            10
        self._single = wx.CheckBox(item, -1, "&Only This Caption")
            item,
            self._single,
            10
        # one more panel to finish it
        cs = fpb.CaptionBarStyle()
        cs.SetCaptionStyle(fpb.CAPTIONBAR_RECTANGLE)
            "Misc Stuff",
            collapsed=True,
            foldIcons=Images,
            cbstyle=cs
        button2 = wx.Button(item, wx.NewId(), "Collapse All")
        self._pnl.AddFoldPanelWindow(item, button2)
            item,
            wx.StaticText(item, -1, "Enter Some Comments"),
            5,
            20
            item,
            wx.TextCtrl(item, -1, "Comments"),
            10
        button2.Bind(wx.EVT_BUTTON, self.OnCollapseMe)
        self.radiocontrols = [currStyle, radio1, radio2, radio3, radio4]
        self.Refresh()
    def OnCreateBottomStyle(self, event):
        # recreate with style collapse to bottom, which means
        # all panels that are collapsed are placed at the bottom,
        # or normal
        if event.IsChecked():
            self.GetMenuBar().Check(self._singlestyle, False)
            self.GetMenuBar().Check(self._exclusivestyle, False)
            self._flags = self._flags & ~fpb.FPB_SINGLE_FOLD
            self._flags = self._flags & ~fpb.FPB_EXCLUSIVE_FOLD
            self._flags = self._flags | fpb.FPB_COLLAPSE_TO_BOTTOM
            self._flags = self._flags & ~fpb.FPB_COLLAPSE_TO_BOTTOM
        self.ReCreateFoldPanel(self._flags)
    def OnCreateNormalStyle(self, event):
        # recreate with style where only one panel at the time is
        # allowed to be opened
            self.GetMenuBar().Check(self._bottomstyle, False)
            self._flags = self._flags | fpb.FPB_SINGLE_FOLD
    def OnCreateExclusiveStyle(self, event):
        # allowed to be opened and the others are collapsed to bottom
            self._flags = self._flags | fpb.FPB_EXCLUSIVE_FOLD
    def OnCollapseMe(self, event):
        for i in range(0, self._pnl.GetCount()):
            item = self._pnl.GetFoldPanel(i)
            self._pnl.Collapse(item)
    def OnExpandMe(self, event):
        col1 = wx.Colour(
            self._rslider1.GetValue(),
            self._gslider1.GetValue(),
            self._bslider1.GetValue()
        col2 = wx.Colour(
            self._rslider2.GetValue(),
            self._gslider2.GetValue(),
            self._bslider2.GetValue()
        col3 = wx.Colour(
            self._rslider3.GetValue(),
            self._gslider3.GetValue(),
            self._bslider3.GetValue()
        style = fpb.CaptionBarStyle()
        style.SetFirstColour(col1)
        style.SetSecondColour(col2)
        style.SetCaptionColour(col3)
        counter = 0
        for items in self.radiocontrols:
            if items.GetValue():
                break
            counter = counter + 1
        if counter == 0:
            mystyle = fpb.CAPTIONBAR_GRADIENT_V
        elif counter == 1:
            mystyle = fpb.CAPTIONBAR_GRADIENT_H
        elif counter == 2:
            mystyle = fpb.CAPTIONBAR_SINGLE
        elif counter == 3:
            mystyle = fpb.CAPTIONBAR_RECTANGLE
            mystyle = fpb.CAPTIONBAR_FILLED_RECTANGLE
        style.SetCaptionStyle(mystyle)
        self._pnl.ApplyCaptionStyleAll(style)
    def OnSlideColour(self, event):
        col1 = wx.Colour(
        col2 = wx.Colour(
        col3 = wx.Colour(
        counter = 0
                break
        if counter == 0:
        elif counter == 1:
        elif counter == 2:
        elif counter == 3:
        item = self._pnl.GetFoldPanel(0)
        self._pnl.ApplyCaptionStyle(item, style)
    def OnStyleChange(self, event):
        eventid = event.GetId()
        if eventid == self.ID_USE_HGRADIENT:
            style.SetCaptionStyle(fpb.CAPTIONBAR_GRADIENT_H)
        elif eventid == self.ID_USE_VGRADIENT:
            style.SetCaptionStyle(fpb.CAPTIONBAR_GRADIENT_V)
        elif eventid == self.ID_USE_SINGLE:
            style.SetCaptionStyle(fpb.CAPTIONBAR_SINGLE)
        elif eventid == self.ID_USE_RECTANGLE:
            style.SetCaptionStyle(fpb.CAPTIONBAR_RECTANGLE)
        elif eventid == self.ID_USE_FILLED_RECTANGLE:
            style.SetCaptionStyle(fpb.CAPTIONBAR_FILLED_RECTANGLE)
            raise "ERROR: Undefined Style Selected For CaptionBar: " + repr(
                eventid
        col1 = wx.Colour(
        col2 = wx.Colour(
        col3 = wx.Colour(
        if self._single.GetValue():
            item = self._pnl.GetFoldPanel(1)
    def CreateMenuBar(self, with_window=False):
        # Make a menubar
        file_menu = wx.Menu()
        FPBTEST_QUIT = wx.NewId()
        FPBTEST_REFRESH = wx.NewId()
        FPB_BOTTOM_FOLD = wx.NewId()
        FPB_SINGLE_FOLD = wx.NewId()
        FPB_EXCLUSIVE_FOLD = wx.NewId()
        file_menu.Append(FPBTEST_QUIT, "&Exit")
        option_menu = None
        if with_window:
            # Dummy option
            option_menu = wx.Menu()
            option_menu.Append(FPBTEST_REFRESH, "&Refresh picture")
        # make fold panel menu
        fpb_menu = wx.Menu()
        fpb_menu.AppendCheckItem(FPB_BOTTOM_FOLD,
            "Create with &fpb.FPB_COLLAPSE_TO_BOTTOM")
        # Now Implemented!
        fpb_menu.AppendCheckItem(FPB_SINGLE_FOLD,
            "Create with &fpb.FPB_SINGLE_FOLD")
        # Now Implemented!
        fpb_menu.AppendCheckItem(FPB_EXCLUSIVE_FOLD,
            "Create with &fpb.FPB_EXCLUSIVE_FOLD")
        menu_bar = wx.MenuBar()
        menu_bar.Append(file_menu, "&File")
        menu_bar.Append(fpb_menu, "&FoldPanel")
        if option_menu:
            menu_bar.Append(option_menu, "&Options")
        self.Bind(wx.EVT_MENU, self.OnQuit, id=FPBTEST_QUIT)
        self.Bind(wx.EVT_MENU, self.OnCreateBottomStyle, id=FPB_BOTTOM_FOLD)
        self.Bind(wx.EVT_MENU, self.OnCreateNormalStyle, id=FPB_SINGLE_FOLD)
        self.Bind(wx.EVT_MENU, self.OnCreateExclusiveStyle,
            id=FPB_EXCLUSIVE_FOLD)
        self._bottomstyle = FPB_BOTTOM_FOLD
        self._singlestyle = FPB_SINGLE_FOLD
        self._exclusivestyle = FPB_EXCLUSIVE_FOLD
        return menu_bar
eg.globals.FoldPanelBar = FoldPanelBar()
eg.globals.FoldPanelBar.CenterOnParent()
eg.globals.FoldPanelBar.Show()
eg.globals.FoldPanelBar.Raise()
