Media Player Classic view modes not working
molitar
Post by molitar » Sun Mar 10, 2019 3:56 am
Windows 10 build 1809 and EventGhost 0.5.0 RC6 and view modes will not work. view minimal, normal, and compact none are functional in EventGhost from the plugin actions.
topix
Re: Media Player Classic view modes not working
Post by topix » Sun Mar 10, 2019 11:06 am
Which version of the plugin are you using? The latest is 2.13.
Which edition (HC or BE) and version of MPC do you have? I've tested it with MPC-BE x64 1.5.2 and MPC-HC x64 1.7.13, both are working.
molitar
Post by molitar » Sun Mar 10, 2019 6:15 pm
Hello using 1.7.13 and when I try to do the modes maximize or minimal it will not change. If I use the hot key 1, 2, or 3 it works fine but when I use the action in EventGhost nothing happens. I was using 2.12 so I will try that 2.13 as the one that was listed in the repository only showed up to 2.12.
Ok tried 2.13 and it helps a bit now it will maximize but not go into minimal mode. Maybe something wrong with this script for the new EventGhost version.
from eg.WinApi.Dynamic import GetWindowLong, ShowWindow, SW_RESTORE, SW_MAXIMIZE, SW_MINIMIZE
from win32gui import SetWindowPos
from ctypes import windll
# Check that we have a window to try to maximize/restore
# Use Find Window action before this script!
if eg.globals.WindowsState != "Fullscreen":
if len(result) > 0:
# Check if WS_MAXIMIZE bit is set
if(GetWindowLong(result[0], -16) & 0x01000000):
eg.plugins.EventGhost.ShowOSD('Maximized ' + eg.WinApi.GetWindowText(eg.result[0]), None, (255, 255, 255), (0, 0, 0), 0, (0, 0), 0, 3.0, None)
ShowWindow(result[0], SW_RESTORE)
eg.plugins.MediaPlayerClassic.ViewNormal()
#Script Unhide Taskbar
eg.plugins.Taskbar.SetAutohideOff()
print "Modal Status was maximized"
#Script Hide Taskbar
eg.plugins.Taskbar.SetAutohideOn()
ShowWindow(result[0], SW_MAXIMIZE)
eg.plugins.MediaPlayerClassic.ViewMinimal()
print "Modal status was normal"
The part in Red does not seem to be triggering for some reason at all. Also is there a cleaner easier method to check window status then the GetWindowLong method I am using?
Thanks.
BTW is the MPC-BE stilling being developed as I read that MPC-Home Cinema is not and if so where is the site to keep up on it? Home page? Github? Opensource?
topix
Post by topix » Sun Mar 10, 2019 7:51 pm
Looks like something with your script is wrong. Where comes the variables eg.globals.WindowsState and result from? Is your script correct indented? (Would have been better to paste it here in a code block)
This edited version worked for me:
#if eg.globals.WindowsState != "Fullscreen":
    #if len(result) > 0:
    #eg.plugins.Taskbar.SetAutohideOff()
    #eg.plugins.Taskbar.SetAutohideOn()
The GetWindowLong method is okay for now, but you gave me an idea and i will add some actions to the window plugin in the next version.
MPC-Be seems to have active development: https://sourceforge.net/projects/mpcbe/files/MPC-BE/
while MPC-HC has not lot commits: https://github.com/mpc-hc/mpc-hc
molitar
Post by molitar » Sun Mar 10, 2019 9:48 pm
Ok thanks that result is from a windows state script that is run first. So it's a global value.
from win32gui import GetWindowPlacement
#SW_SHOWNORMAL = 1
#SW_SHOWMINIMIZED = 2
#SW_SHOWMAXIMIZED = 3
FindWin = eg.WindowMatcher(None, None, u'MediaPlayerClassicW' , None, None, None, True, 0.0, 0)
hwnd = FindWin()
def GetWindowStatus(hwnd):
    showList  = ("None", "Normal", "Minimized", "Maximized")
    placement = GetWindowPlacement(hwnd)
    #unrem the below line to display the placement values that you need for the if placement[4] line
    print placement
    if placement[4] == (-3840, 0, 0, 2160):
        return "Fullscreen"
        return showList[placement[1]]
eg.globals.WindowsState = GetWindowStatus(hwnd[0])
print "Windows State = " + eg.globals.WindowsState
Toggle works better but I still am not getting MPC to show up in viewminimal so let me try that BE version and see if it's a problem with mpc-hc.
molitar
Post by molitar » Sun Mar 10, 2019 10:18 pm
Ok I switched my profile to MPC-BE 64bit and it is working perfectly now I just had to move one line up to get a proper restore.
Just had to move the ViewNormal before the SW-RESTORE or it would not restore properly. So what happens now is the taskbar hides itself, the window maximizes, and ViewMinimal is called giving a full screen view on primary monitor. I do this as sometimes I run two displays and I have full screen set to my HDTV or the other more common reason is I am letting company play the PS4 on the HDTV and will watch a video on full screen on the monitor.
Thanks for the help Topix!
molitar
Post by molitar » Tue Mar 12, 2019 11:34 pm
I found a fatal flaw with MPC-BE whenever I do a jump the video stops playing. I could find no setting to change this fatal flaw as if I missed something and do a jump backward I then have to press play again which is really stupid. Is there some fix for this?
topix
Post by topix » Tue Mar 19, 2019 5:24 pm
hmm, strange, it's not happening here on my test machine. :?: I can jump backward (small/medium/large/keyframe/n seconds) and the video continues to play.
molitar
Post by molitar » Tue Mar 19, 2019 5:39 pm
What version are you running?
topix
Post by topix » Tue Mar 19, 2019 5:51 pm
molitar
Post by molitar » Tue Mar 19, 2019 6:45 pm
Ok I was using MPC-BE 1.5.3 and MPC-HC 1.7.9.190. I will try the newer version of MPC-HC and see if that makes any difference.
