Application Observer
Post by Pako » Thu Sep 23, 2010 4:59 pm
I do not like to use Task plugin, because it generates too many events.
That's why I create greatly simplified replacement - Application Observer plugin.
He generates events only when you start and end application. And that's only for those applications that you choose.
I do not know if someone is interested, but maybe yes.
Plugin Application Observer - version 0.0.4
Added 2011-06-19
(9.34 KiB) Downloaded 720 times
Plugin Application Observer - version 0.0.2
(9.84 KiB) Downloaded 423 times
Livin
Re: Application Observer
Post by Livin » Mon Oct 11, 2010 9:41 pm
Can you give an examples of usage?
I'd like to understand how this differs vs triggering Macros based on the following...
Task.Created
Task.NewWindow
Task.ClosedWindow
Task.Activated
Task.Deactivated
thx
Post by Pako » Tue Oct 12, 2010 7:01 am
Here is an example of the contents of the log,
if I added plugins Task Create/Switch Events and Application observer to the configuration.
Then I opened a text file in notepad and again I closed it.
I think it is clear that correlations:
Application.Launched.XXX corresponds Task.Created.XXX and
Application.Terminated.XXX corresponds Task.Destroyed.XXX
BTW: what about the testing function Window: Move Absolute?
I see that you're doing a very thorough test.
Livin
Post by Livin » Wed Oct 13, 2010 4:39 am
work and my 1 yr old have been keeping me too busy to really test too much. I have added move absolute but not enabled it yet... maybe tomorrow or this weekend.
I still don't understand how Application Observer provides anything beyond using native triggers?
how is Application.Launched more useful than Task.Created?
Post by Pako » Wed Oct 13, 2010 5:37 am
Livin wrote:how is Application.Launched more useful than Task.Created?
Here's something else entirely. I never claimed that it was more useful.
Pako wrote:I do not like to use Task plugin, because it generates too many events.
Note: Because I am constantly experimenting with EventGhost, I do not use the option Log only activated and assigned events.
I do not need events like Task.NewWindow, Task.ClosedWindow, Task.Activated, Task.Deactivated.
Livin
Post by Livin » Wed Oct 13, 2010 5:48 am
gotcha... I also keep that option unchecked but I use the Task Plugin since it is useful to see what state an app is in and base Macros on them.
schindi77
Post by schindi77 » Sun Dec 05, 2010 10:09 am
Hi Pako!
I´m want to use your plugin to control a program called DSynchronize.exe.
It´s proper configured, but I don´t get any event after starting/closing the program.
Do you have any idea what the problem could be?
The "task create/switch events" plugin also doesn´t recognize the program at all....
If I add "c:\windows\notepad.exe" it´s also NOT recognized by your plugin, but recognized by the "task create/switch events" plugin.
Strange thing....
btw: I´m using Win7 HP 32bit....
Post by Pako » Sun Dec 05, 2010 2:19 pm
schindi77 wrote:If I add "c:\windows\notepad.exe" it´s also NOT recognized by your plugin, but recognized by the "task create/switch events" plugin.
Strange thing....
I thought the only one reason for this behavior:
Applications you want to observe, you must insert without a path. Thus, only "notepad.exe".
Look at the picture in the introductory article of this topic.
