Remote event mapper
lubbbo
Re: Remote event mapper
Post by lubbbo » Sat Oct 29, 2011 12:55 pm
jonib wrote: Step 1: Type name of remote in "Remote control name:", press Add remote. Now select the remote in the "List of remotes" list.
Step 2: Type in the event prefix that your remote plugin uses in "Native remote prefix:" (The part of the remote event that don't change)
Step 3: Press "Add item" then press the button of the remote you want to remap, then type in the remote button name ("Button label"), then type in the desired event suffix to remap to. ("Common event suffix")
Now when ever pressing the remapped button it will create a new event ("Common event prefix").("Remapped event suffix")
It doesn't work for me!
Step 1: If I select the remote in the "List of Remotes" list, the "Native remote prefix:" is disabled and I cannot insert any value ...
Could you help me?
Also an xml template can be useful to configure without GUI ! Thanks a lot.
Post by jonib » Tue Nov 01, 2011 5:25 pm
lubbbo wrote:Could you help me?
Sorry don't know why it gets disabled for you.
I'll attach my remote xml, don't know how useful it is to you.
TechnoTrend.xml.zip
(974 Bytes) Downloaded 311 times
drowhunter
Post by drowhunter » Tue Jul 10, 2012 4:41 pm
1st i love the plugin.
Secondly, I have an issue.
Some of my remotes when i push a button , on press down i get the proper code
and then shortly after a second Unknown.10 code
all i want is the first code, but the second one always overwrites the first one
how can this be fixed?
Post by Pako » Wed Jul 11, 2012 6:40 am
I'm not sure where the problem actually is.
Can you please describe it in more detail ?
At which time the problem occurs? When you "learn" the remote or use?
drowhunter
Post by drowhunter » Thu Jul 12, 2012 1:51 am
when learning it shows the correct code
and the its followed by a second code Unknown
this is just how some remotes are, its like it fires two signals
problem is your plugin only accepts one signal
if i press the button and then quickly cover the ir emitter with my hand then it works
Post by Pako » Thu Jul 12, 2012 7:18 am
I'm very sorry, but I still do not understand where the problem is.
If you (during learning) assign an event to a valid code,
then it (in normal use) not work? You can not just ignore unknown code?
Can you tell us, which type of remote control sends these codes?
If possible, I'd like to try it.
KB_
Post by KB_ » Sun Oct 25, 2015 10:33 am
Hi Pako
Just wanted to thank you for this plugin. Really really useful! :-)
The only improvement I could think of would be to be able to enter the "native event suffix" by hand (no "learning" required). (I ended up doing some of the changes in the xml itself.)
Thanks again for the plugin, it makes my eg setup so much clearer.
KB
