AutoRemote EventGhost plugin:EG->Android and Android->EG
Re: AutoRemote EventGhost plugin:EG->Android and Android->EG
Post by Pako » Mon Jan 07, 2013 4:06 pm
Sorry, I incorrectly tried.
I still have to continue.
joaomgcd
Post by joaomgcd » Mon Jan 07, 2013 5:27 pm
Thank you very much.
I appreciate it.
Post by Pako » Mon Jan 07, 2013 7:56 pm
I finally found out, where the next (and main) problem.
The module "pickle" can not handle the class "AutoRemoteDevice" (which is stored in the argument "devices").
It can be solved in different ways.
The easiest way is to use an ordinary class tuple or dictionary.
Post by Pako » Tue Jan 08, 2013 7:44 am
Here is one possible way that required minimum modifications.
(28.16 KiB) Downloaded 320 times
Post by Pako » Tue Jan 08, 2013 12:08 pm
Sorry, now I fixed a small bug. :oops:
(28.16 KiB) Downloaded 379 times
joaomgcd
Post by joaomgcd » Tue Jan 08, 2013 2:38 pm
Pako, I have to say, AWESOME!! :mrgreen:
Your latest version works as expected, thanks so much.
Any idea why pickler doesn't correctly support the AutoRemoteDevice class?
Anyway, now I want to keep backwards compatibility with the previous version so I changed
self.devices = [AutoRemoteDevice(*i) for i in devices]
to
if len(devices) > 0:
            if(isinstance(devices[0], AutoRemoteDevice)):
                self.devices = devices
But there's just one problem: if a user doesn't open and save the AutoRemote plugin configuration at least once after using this version, they will still get the error because EventGhost still wouldn't use the tuple instead of the AutoRemoteDevice object.
Any way to force EventGhost to save the plugin's configuration without the user manually going into the plugin settings dialog and clicking "Ok"?
Again, thank you very much for your support. :D
Post by Pako » Tue Jan 08, 2013 5:11 pm
joaomgcd wrote:Any idea why pickler doesn't correctly support the AutoRemoteDevice class?
I do not know.
You've read the documentation?
joaomgcd wrote: But there's just one problem: if a user doesn't open and save the AutoRemote plugin configuration at least once after using this version, they will still get the error because EventGhost still wouldn't use the tuple instead of the AutoRemoteDevice object.
You can do it (simply) like this:
                trItem = self.info.treeItem
                args = list(trItem.GetArguments())
                args[3] = [AutoRemoteDevice(*i) for i in devices]
                eg.actionThread.Func(trItem.SetArguments)(args)
                eg.document.SetIsDirty()
                eg.document.Save()
        self.port = port
        self.publicIp = publicIp
        self.dname = dname
        self.server = MyServer(RequestHandler, port)
        self.server.Start()
    def __stop__(self):
        self.server.Stop()
Or a little more complicated as follows:
                wx.CallAfter(self.SaveConfig)
        self.port = port
        self.dname = dname
        self.server.Start()
    def SaveConfig(self):
        from eg.Classes.Document import SaveChangesDialog
        dialog = SaveChangesDialog(eg.document.frame)
        result = dialog.ShowModal()
        dialog.Destroy()
        if result == wx.ID_YES:
            eg.document.Save()
    def __stop__(self):
        self.server.Stop()
Note: untested
Post by krambriw » Tue Jan 08, 2013 5:39 pm
Dear Pako,
This is absolutely a wonderful solution and information, very useful generally indeed. I will remember this for future.
Once again, thank you
Very best regards, Walter
joaomgcd
Post by joaomgcd » Tue Jan 08, 2013 5:56 pm
Thanks again Pako.
Unfortunately EventGhost hangs at
and eventually times out with this error:
      Traceback (most recent call last) (1582):
        File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 326, in __DoOneEvent
          self.HandleAction(action)
        File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 289, in HandleAction
          action()
        File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 62, in __call__
        File "C:\Program Files\EventGhost\eg\Classes\EventThread.py", line 142, in StartSession
          actionThread.Func(actionThread.StartSession, 120)(filename)
        File "C:\Program Files\EventGhost\eg\Classes\ThreadWorker.py", line 214, in Wrapper
          raise Exception("Timeout while calling %s" % func.__name__)
      Exception: Timeout while calling StartSession
Any ideas?
Post by Pako » Wed Jan 09, 2013 8:26 am
Ah, so we have to do it a little differently.
And anyway there was another bug ...
Automatic method:
                wx.CallAfter(self.SaveConfig, devices)
        self.port = port
        self.dname = dname
        self.server.Start()
    def SaveConfig(self, devices):
        args[3] = [(i.name, i.url, i.key) for i in self.devices]
        eg.document.Save()
    def __stop__(self):
        self.server.Stop()
Interactive method:
        self.port = port
        self.dname = dname
        self.server.Start()
        dialog = eg.Classes.Document.SaveChangesDialog(eg.document.frame)
        dialog.Destroy()
            eg.document.Save()
    def __stop__(self):
        self.server.Stop()
joaomgcd
Post by joaomgcd » Wed Jan 09, 2013 10:54 am
Awesome, that did it!! :mrgreen:
Brilliant! thank you you very much.
The other bug you mentioned I was able to figure out myself as well but thanks for fixing it nonetheless. :)
Awesome, awesome support, thanks!
By the way, how do I apply to be part of the "official" EventGhost plugins? Or is that not open right now?
Thanks again!
Post by Pako » Wed Jan 09, 2013 12:06 pm
joaomgcd wrote:By the way, how do I apply to be part of the "official" EventGhost plugins? Or is that not open right now?
B is correct.
Author program (Bitmonster) just before he left the project, worked on major change.
You can read about it here.
I think there is no doubt that it is not appropriate to continually add new plugins to the program.
So we are looking for a person (or team) who could implement this idea. New plugins will not be added.
BTW: If I do (in the future) Android phone I buy, I'll try AutoRemote. I get a discount? :wink:
joaomgcd
Post by joaomgcd » Wed Jan 09, 2013 12:11 pm
Better than that, you'll get all my apps for free. :)
Nelsun
Post by Nelsun » Wed Jan 09, 2013 12:47 pm
Thanks for help getting this sorted Pako :D I'd say it's worth getting yourself an Android phone (a Nexus 4 if you can) just because of what it + AutoRemote + EventGhost can all achieve together. I cannot imagine not using any of them on a regular basis every single day 8)
Post by Pako » Wed Jan 09, 2013 1:03 pm
joaomgcd wrote:Better than that, you'll get all my apps for free. :)
This is amazing!
And how do I do it, when it will current? (You can use PM ...)
