xAP Plugin
V_J
Re: xAP Plugin
Post by V_J » Wed Aug 17, 2016 7:31 am
I will just use the code snippet you posted, and copy the eg.result data to a local variable in the script.
I was using multiple actions (scripts) as a test case, I planned to put them together at one point anyway. I suspect the behaviour is normal on a real time system, and assuming that the value of a global stays the same for the duration of the script is a bad way to deal with real time systems. :) Copying it to a local variable and setting all the actions in one script should solve it. I will try it later this week.
V_J
Re: xAP Plugin
Post by V_J » Wed Aug 17, 2016 8:00 pm
I could not get the code snippet to work ("not callable" as error), but I could copy eg.result to a local variable. All things put in one script, using the local variable and it all works without problems.
So no need to fix anything... It just requires proper use. :)
Re: xAP Plugin
Post by kgschlosser » Fri Aug 19, 2016 4:37 pm
That was a proposed solution. Not a current working setup
V_J
Re: xAP Plugin
Post by V_J » Mon Aug 22, 2016 11:14 am
I modified all the scripts that use results from the XAP plugin to first copy the result to a local variable in the script.
I tested it with a number of squeezeboxes playing in parallel and no errors appear in the log of Eventghost. So I don't think it is necessary to change anything to the xap plugin, it just needs to be used correctly. :-)
The integration of the squeezeboxes with my home automation system is taking shape: I have full control over the squeezeboxes and can display info on what is playing (artist, album, elapsed time, ...) on the interface. Now I still need to finalize control of the amplifier (linking its serial control using eventghost to the rest of the system, and that would be the end... :)
Re: xAP Plugin
Post by kgschlosser » Mon Aug 22, 2016 4:03 pm
do you like how the xAP plugin functions? I do need to release another version with mentions of the original creator of the protocol. i was in conversation with him for a while about the working of the hub portion of the protocol. so i could make the plugin act as both client and hub. as well as be able to auto switch between the 2.
I would like to add you name in there as well if at all possible for the beta testing of the plugin if that is ok.
oh one question for you. are you running the beta of EG?? i have not tested to see if the plugin works properly i do not believe that there should be any issues.
and if there is anything else i need to add please let me know.
V_J
Re: xAP Plugin
Post by V_J » Tue Aug 23, 2016 9:53 am
The plugin is perfect: it does just what it is supposed to. The debugging feature is great, as otherwise it really overloads the log. For that reason, I do not use payload but eg.result (not sure if there are any difference because of this).
Feel free to mention me.
I have not tried the beta version of EG, but am not sure I have time in the next few weeks.
It may be interesting to mention in the manual that subsequent xap packets can change eg result, of one was not parsed before that, the data is lost. So best to use a local variable. :)
But perhaps it could also be interesting to ask Pako to add the plugin as standard?
Re: xAP Plugin
Post by kgschlosser » Thu Aug 25, 2016 5:24 am
I know they are steering away from packaging plugins with EG in favor of a plugin repository that would be accessible from right inside of EG. and I would much rather see time spent working on that solution then packaging plugins. ya know?? 8)
there is a lot of really good brain storming going on with EG. so it will be really awesome to see what turns out from it all.
one of the things i decided to spear head is adding the ability for EG to import external python packages in a simplistic manner. i am sooo close to getting it working properly.
but i think i may have to ditch one of the methods as it is becoming a real hassle.
V_J
Re: xAP Plugin
Post by V_J » Mon Jan 09, 2017 8:45 am
Just reinstalled my entire system and noticed that the last version of the xap plugin is not on the first post... :)
It is still working nicely, so not much to report. I'm just getting everything set up for when I go abroad next month, so my girlfriend can use the system without too much hassle... So not starting any new things with it...
Re: xAP Plugin
Post by kgschlosser » Fri Jan 13, 2017 12:06 am
no worries. I don't know why the latest version is not on the front page.. It could be that it was to fix a bug and i didn't want to do a release of it until i knew if it fixed it or not.. and then forgot about it
V_J
Re: xAP Plugin
Post by V_J » Thu Dec 14, 2017 9:27 pm
Hello!
I'm back... and updating my configuration... :) I'm still away from my installation (working abroad), but decided to clean up everything.
I tried the latest Eventghost and the xAP plugin gives this message:
Plugin: xAP
Error starting plugin: xAP
File "C:\Program Files (x86)\EventGhost\eg\Classes\PluginInstanceInfo.py", line 192, in Start
TypeError: __start__() takes at most 8 arguments (9 given)
Any suggestions?
Jörg
Re: xAP Plugin
Post by kgschlosser » Fri Dec 15, 2017 4:57 am
Have you tried creating a new empty save file and then adding the plugin?
Did you copy the save file from you live installation and opened it up in EG 0.5? I am going to have to go back and look at the code. I can't remember how the startup is set up.
What it looks like to me is that your EG 0.5 is not running the same version of the plugin as your live EG. It looks like you could possibly have an older version of the plugin installed in EG 0.5
V_J
Re: xAP Plugin
Post by V_J » Fri Dec 15, 2017 7:23 am
Well, I took the xAP plugin file I had...
I remember some changes were planned to the whole plugin distribution system, so how do I get the correct version of the xAP plugin?
(nice to see the same people here... I've been out of it a bit but am getting back :))
V_J
Re: xAP Plugin
Post by V_J » Fri Dec 15, 2017 10:10 pm
Ok, I think I managed.
I removed it from the config (which generated a lot of error messages), saved the config under a different name, restarted eventghost as adminstrator and added the xap plugin through the menu. It is in the list of enabled plugins, does not show error messages and seems to be working. :)
Re: xAP Plugin
Post by kgschlosser » Sat Dec 16, 2017 10:07 am
sorry i didn't get back to ya in time. but if I remember correctly there is information from the plugin stored in the file %appdata%\eventghost\config.py
so if you copied that file as well then you should be good to go.
V_J
Re: xAP Plugin
Post by V_J » Sat Dec 16, 2017 6:34 pm
No problem... I'm away from my home installation so cannot fully test it, but as far as I can tell now it seems to work. I'm using the time away from my installation to clean up my config and improve things. :)
