EventGhost plugin as with Tasker App Factory plugin
Postby HenryMast » Sat Jul 08, 2017 7:05 am
Tasker App Factory lets saving Tasker profiles/tasks as stand-alone apps. Is there a plugin that allows Eventghost to save different creations as stand-alone programs?
Henry
HenryMast
Re: EventGhost plugin as with Tasker App Factory plugin
Postby kgschlosser » Sun Jul 09, 2017 11:01 am
heh yeah.. it's called copy and paste. :shock:
but seriously it is.
well if you want a whole second copy of EG. copy the whole EG installation folder to another location
and this next part is going to be the same either way you will simply select the new location instead
but create a shortcut, browse to the eventghost.exe you want to run. and click on next.. when it is done making the shortcut you are going to right click on it. and click on properties
in the Target box you will see "C:\Program Files (x86)\EventGhost\EventGhost.exe" (if you are using EG that is installed in program files)
you are going to want to change the target. be sure to replace YOUR_TREE with the path/name of the configuration tree you wish to open
"C:\Program Files (x86)\EventGhost\EventGhost.exe YOUR_TREE.egtree --multiload"
this will allow you to have 2 copies of eventghost open at the same time with 2 different configuration trees which would be exactly the same as what tasker provides.
Postby m19brandon » Mon Jul 10, 2017 1:52 am
Not related to plugin piece but with two .egtree floating around how do I export my tested folders/macro into my production .egtree?
m19brandon
Postby kgschlosser » Mon Jul 10, 2017 2:22 am
@m19brandon
that's simple.
Copy and paste baby!
LOL
simply copy your tree and past it onto your production tree. do this inside of EG and not in the file it's self.
Postby yokel22 » Mon Jul 10, 2017 11:53 am
Using the multiload switch is pretty useful when doing that kind of copy/pasting between trees. It'll allow you to run as many instances of eg at once as you like. So you can have multiple tree's to copy/paste from/to.
save as .cmd
for x64
START "Starting Multiple EventGhost Mode" "C:\Program Files (x86)\EventGhost\EventGhost.exe" -multiload -m
or i believe this will work for x86.
START "Starting Multiple EventGhost Mode" "C:\Program Files\EventGhost\EventGhost.exe" -multiload -m
Speaking of copy/pasting tree stuff. Kgschlosser, can we get a sub-board for sharing eg xml? I know there's a ton of stuff i would like to setup that other people have likely done already. & it's just a good way to learn eg, by looking at other people's tree's/code.
yokel22
Postby kgschlosser » Mon Jul 10, 2017 3:37 pm
@yokel22 I can set it up for ya but you will have to be the moderator for it. so I would suggest some kind of an outline for how you want the information shared. but also a sticky on how to do it.
if you are willing let me know.
Postby yokel22 » Mon Jul 10, 2017 5:53 pm
That's fine, I can manage one board, you do enough for us already as it is. I was just thinking something like voxcommando's xml exchange as they both use xml that is copy/pasted directly onto the tree. http://voxcommando.com/forum/index.php?board=27.0 . Just a sticky with basic outlines for posting and using shared xml. As i think a lot of folks that are new to eg don't even realize you can paste code directly onto the eg tree & not have to open the xml file and paste it in.
On a side note. I don't have a ton of free time this next month or two. But I can probably get a free day to help with the html/css work you were wanting to do on the site. I'll pm you in case you don't catch this post.
yokel22
Postby kgschlosser » Tue Jul 11, 2017 1:29 pm
Ok cool give me an hour or so to set up the thread for ya. I am not currently home and it's a little bit of a pain from the phone. And I havent screwed around with the admin panel in the mobile version yet
Postby yokel22 » Tue Jul 11, 2017 2:58 pm
No rush, Get to it whenever.
yokel22
Postby kgschlosser » Tue Jul 11, 2017 5:16 pm
I am going to try it from my phone. I got tied up still haven't made it home for any real length of time
Postby m19brandon » Mon Jul 17, 2017 4:03 am
This is great. Thanks, I can share now.
m19brandon
Return to Plugin Support
Who is online
Users browsing this forum: No registered users and 3 guests
cron
