Screen Settings
Re: Screen Settings
Post by kgschlosser » Mon Jul 16, 2018 4:19 pm
alright! That error is a good thing. that means that i have located the actual screen buried in the windows API. I am going to be able to change the brightness on your laptop. I am one clever dude. I am using the power settings to do it. You know how with a laptop when you switch over to battery the screen dims.. :D. But I want to also try and see if i can use that handle I got and pump that into the DDC/CI and then we can see where we go from there. Because they have to use the same mechanism i would imagine to dim the screen.
Neytrino-OnLine
Re: Screen Settings
Post by Neytrino-OnLine » Tue Jul 17, 2018 7:39 am
WOW! Want it - want it - want it...
Sin©erely yours, Neytrino.
Re: Screen Settings
Post by kgschlosser » Tue Jul 17, 2018 4:41 pm
I am at 5000 lines of code with this bugger so far and I still have to make all of the EG Actions which is going to be another 2-3 thousand lines.
Possessed
Re: Screen Settings
Post by Possessed » Wed Jul 18, 2018 2:00 am
Will this work if the pc is not the current input displayed on the TV / Monitor?
Re: Screen Settings
Post by kgschlosser » Wed Jul 18, 2018 5:30 am
it should i would imagine. the reason I say this is because I can change the screens inputs. i do not see what the point would be in changing the input and then losing the ability to control the screen. that would be a bit strange if it worked that way. I am going to have to test it to be sure 100%
Neytrino-OnLine
Re: Screen Settings
Post by Neytrino-OnLine » Wed Aug 15, 2018 6:04 am
Any progress with this beautyful project?
Neytrino-OnLine
Re: Screen Settings
Post by Neytrino-OnLine » Tue Aug 25, 2020 4:24 am
So, we wait patiently when everything will be ready and work as properly.
But due to the 2004 update, I was forced to reinstall Windows, and strart to look for some new solution of the my old problem - switching between multt-monitor (3 monitors) configurations with duplication and expansion at the same time (my old solution was - "Actual Multiple Monitors" app, which worked but had some problems and a lot of additional features that I do not need (and also it is not free)). And, I found one, fantastic app - which just works and does what it should do (including: duplication and expansion at the same time). The name is: WS Display Settings, it is free for non-commercial using and support command lines control (so it can be easily integrated with EG).
I hope it helps someone...
