Event is not Triggered
Post by kgschlosser » Wed Sep 19, 2018 9:44 pm
@ Stefan I apologize for deleting your post. It seems that while i was responding to your initial post you created a new one and deleted the old one. and i did not know this took place. so when i saw the second post i deleted it as a duplicate. Kind of a wierd thing to have happen. I have recreated your second post.
Hi there!
Can you help me with the following script? I want to send a link from a Android device and parse it with a AutoHotKey Script on Windows Server..
It was working before and now I changed Android Device and Upgraded Windows Server 2016 to Windows Server 2019 and I think the Event is not triggered..
Sending the message from Android to PC works, but nothing more happens..
Thank you very much and best regards
Stefan
Re: Event is not Triggered
Post by kgschlosser » Wed Sep 19, 2018 9:48 pm
OK so back to responding to your question..
I am going to need you to send me a copy of your save file. You are going to need to zip it and attach it to a private message to me. I am going to bypass the new user permissions for ya so you will be able to do this.
