Eventghost won't start
wysocki
Post by wysocki » Wed Oct 17, 2018 12:33 am
Several times when I restart my computer (Win 7/64), EventGhost won't start. Even if I click the shortcut or do a start/run it won't start. I see it flash for a split second in the processes list but it won't start. Interestingly, there is a task listed under the Applications tab called Eg2MbMessages which is "running" but I see no evidence of it on the desktop. Is that part of EG?
At other times, EG will start, but the status indicator on the taskbar is red, even though the status indicator in EG is green. Related???
jachin99
Re: Eventghost won't start
Post by jachin99 » Wed Oct 17, 2018 1:09 am
Have you installed any plugins that would cause this behavior? Have you tried starting EG from the Program files x86 folder? Have you tried moving your EG tree to a different location to see if something under auto start is causing problems? Which version of EG are you on?
wysocki
Post by wysocki » Wed Oct 17, 2018 1:45 am
The only plugin I've added recently was ScheduGhost. I've removed it but still can't start EG. I tried running the exe from the program files folder as well. Not sure what you mean by moving the EG tree??
I'm running Version WIP-2018.03.02-11.16.00. The Eg2MbMessages app is still running too. Is this a part of EventGhost?
I've been able to get it running on startup after a few computer restarts. But if I exit, I can't get it started again without a computer restart. If I do a file|restart, I get "error occured" message. Here's the tail of my log file:
error: [Errno 10053] An established connection was aborted by the software in your host machine
20:14:54: DEBUG: 0 MessageReceiver: MusicBee.Handler(hwnd=1705536, mesg=74L, wParam=920256L, lParam=162641336)
20:14:55: DEBUG: 0 MessageReceiver: MusicBee.Handler(hwnd=1705536, mesg=74L, wParam=920256L, lParam=162641336)
20:14:59: DEBUG: 0 MessageReceiver: MusicBee.Handler(hwnd=1705536, mesg=74L, wParam=920256L, lParam=162641336)
14:09:07: DEBUG: 1 MainThread: MainFrame.OnClipboardChange(dummyValue=None)
14:30:09: DEBUG: 0 MessageReceiver: MusicBee.Handler(hwnd=1705536, mesg=74L, wParam=920256L, lParam=162641336)
14:30:16: DEBUG: 1 MainThread: App.OnQueryEndSessionVista(event=<wx.CloseEvent>)
14:30:16: DEBUG: 1 MainThread: App.OnQueryEndSessionVista => None
14:30:16: DEBUG: 1 MainThread: App.OnEndSession(dummyEvent=<wx.CloseEvent>)
14:30:16: DEBUG: 1 MainThread: Document.Close()
14:30:16: DEBUG: 1 MainThread: MainFrame.Destroy()
14:30:16: DEBUG: 1 MainThread: LogCtrl.Destroy()
14:30:16: DEBUG: 1 MainThread: TreeCtrl.Destroy()
14:30:16: DEBUG: 1 MainThread: StatusBar.Destroy()
14:30:16: DEBUG: 1 MainThread: StatusBar.__del__()
14:30:16: DEBUG: 1 MainThread: MainFrame.Destroy => True
14:30:16: DEBUG: 1 MainThread: Document.GetExpandState()
14:30:16: DEBUG: 1 MainThread: Document.Close => None
14:30:16: DEBUG: 1 MainThread: MainFrame.Iconize(flag=False)
14:30:16: DEBUG: 1 MainThread: App.OnExit()
14:30:16: DEBUG: 1 MainThread: Calling exit functions
14:30:16: DEBUG: 1 MainThread: <function CloseOSD at 0x07346F30>
14:30:16: DEBUG: 1 MainThread: Calling eg.DeInit()
14:30:16: DEBUG: 1 MainThread: stopping threads
14:30:16: DEBUG: 0 ActionThread: ActionThread.StopSession()
14:30:16: DEBUG: 0 ActionThread: UnloadPlugins()
14:30:16: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Webserver
14:30:16: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\MusicBee
14:30:16: DEBUG: 0 ActionThread: MessageReceiver.Stop()
14:30:16: DEBUG: 0 MessageReceiver: MessageReceiver.__MainLoop => None
14:30:16: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Log Redirector and Filter
14:30:16: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Task
14:30:16: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\CM11A
14:30:16: DEBUG: 0 Thread-9: SerialThread.ReceiveThreadProc => None
14:30:16: DEBUG: 0 SerialReceiveThreadProc: SerialThread.CallbackThreadProc => None
14:30:16: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\USB-UIRT
14:30:19: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\Timer
14:30:19: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\SunTracker
14:30:19: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\FileOperations
14:30:19: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\EventGhost
14:30:19: DEBUG: 0 ActionThread: closing C:\Program Files (x86)\EventGhost\plugins\System
14:30:19: DEBUG: 0 ActionThread: System.__stop__()
14:30:21: DEBUG: 0 ActionThread: System.__stop__ => None
  File "EventGhost.pyw", line 53, in <module>
  File "C:\Program Files (x86)\EventGhost\eg\__init__.py", line 31, in <module>
    import Cli
  File "C:\Program Files (x86)\EventGhost\eg\Cli.py", line 30, in <module>
    import NamedPipe
  File "C:\Program Files (x86)\EventGhost\eg\NamedPipe.py", line 107, in <module>
    is_eg_running = _is_eg_running()
  File "C:\Program Files (x86)\EventGhost\eg\NamedPipe.py", line 104, in _is_eg_running
    raise NamedPipeConnectionError(err)
NameError: global name 'NamedPipeConnectionError' is not defined
Post by kgschlosser » Wed Oct 17, 2018 6:30 am
the Eg2MbMessages process that is a go between for EG and MusicBee. this process is getting orphaned somehow. if you kill that process then EG should start properly.
