New version 0.5.0-rc6 is out
Radar73
Re: New version 0.5.0-rc6 is out
Post by Radar73 » Tue Jan 15, 2019 9:53 pm
Yeah it works fine calling the application with -e … I wasn't doing anything complicated with the Eventghost object in vbscript anyways so this works just as well. Is there anyway to prevent the addition of "Main" being added to the event name? For example I sent it eventghost.exe -e "Hello" and it shows up in the log as Main.Hello instead of just Hello.
Post by blaher » Sat Feb 02, 2019 3:42 am
I'm having problems getting this to run on startup. It appears in shell:startup, but even after making it always run as admin, it doesn't. Shortcut works fine when I click when windows has loaded, but .bat files, shortcuts to .bat files, dragging EG from shell:appsfolder to startup...none of them work.
Edit: finally got in running with taskscheduler running a .bat file with highest privileges when a user logs on.
Post by kgschlosser » Sat Feb 02, 2019 7:32 am
I can't remember off hand but I think if you specify an event name with a '.' in it then the Main will go away
like Some.Event
the reason for that logic is this.. the Prefix would be event grouping. and the suffix is what is taking place for that grouping.. so if you have a plugin for your TV.. the event would be TV.Power this lets you know 2 things.. what is generating the event. and what the event is. the '.' is also how you do wild carded events.
say you have an Audio Processor that is connected to EG and it generates events for Mute, Volume, changes in the tone.. things of that nature. and you wanted to have an OSD shown.. you can create a single macro and add an event with the prefix followed by .* this will cause all events from the Audio Processor to run the macro.
So as a rule of thumb.. events should always be prefix.suffix hence the reason why EG is adding the Main
topix
Post by topix » Fri Feb 08, 2019 3:30 pm
Also you have a solution for you problem, i would be interested if it could be something with your config. May i ask you to try again with an empty config tree an then enable the autostart option in EventGhost's settings?
cableghost
Error opening EG Options
Post by cableghost » Sat Mar 09, 2019 5:44 pm
Receive error on trying to access Options...
2:22:43 AM   Traceback (most recent call last) (0.5.0-rc6):
2:22:43 AM     File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 162, in ProcessingTask
2:22:43 AM       self.Configure(*args, **kwargs)
2:22:43 AM     File "C:\Program Files (x86)\EventGhost\eg\Classes\OptionsDialog.py", line 194, in Configure
2:22:43 AM       languageChoice.SetSelection(languageList.index(config.language))
2:22:43 AM   ValueError: 'en_US' is not in list
Tasklet:
# -*- coding: utf-8 -*-
# This file is part of EventGhost.
# Copyright © 2005-2016 EventGhost Project <http://www.eventghost.org/>
# EventGhost is free software: you can redistribute it and/or modify it under
# the terms of the GNU General Public License as published by the Free
# Software Foundation, either version 2 of the License, or (at your option)
# any later version.
# EventGhost is distributed in the hope that it will be useful, but WITHOUT
# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or
# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for
# more details.
# You should have received a copy of the GNU General Public License along
# with EventGhost. If not, see <http://www.gnu.org/licenses/>.
    eg.Tasklet
    A wrapper around stackless.tasklet
    :copyright: 2009 by EventGhost team, see AUTHORS.txt for more details.
    :license: GNU GPL v2, see LICENSE.txt for more details.
import stackless
class Tasklet(stackless.tasklet):
    countTasklets = 0
    def __init__(self, func):
        stackless.tasklet.__init__(self)
        self.bind(func)
        Tasklet.countTasklets += 1
        self.taskId = Tasklet.countTasklets
    @classmethod
    def GetCurrentId(cls):
        try:
            return stackless.getcurrent().taskId
        except AttributeError:
            return 0
OptionsDialog:
# more details.
import os
import wx
from os.path import exists, join
from time import localtime, strftime
from wx.combo import BitmapComboBox
# Local imports
import eg
INDENT_WIDTH = 18
class Text(eg.TranslatableStrings):
    Title = "Options"
    Tab1 = "General"
    CheckPreRelease = "Always notify about new pre-releases"
    CheckUpdate = "Check for EventGhost updates at launch"
    confirmDelete = "Confirm deletion of tree items"
    confirmRestart = (
        "Language changes only take effect after restarting the application."
        "\n\n"
        "Do you want to restart EventGhost now?"
    Datestamp = "Datestamp format for log:"
    DatestampHelp = (
        "For imformation on format codes read Python's strftime "
        "documentation:\n"
        "http://docs.python.org/2/library/datetime.html#strftime-and-strptime-"
        "behavior\n"
        "\nHere you can find examples:\n"
        "http://strftime.org/\n"
    HideOnClose = "Keep running in background when window closed"
    HideOnStartup = "Hide on startup"
    LanguageGroup = "Language"
    limitMemory1 = "Limit memory consumption while minimized to"
    limitMemory2 = "MB"
    propResize = "Resize window proportionally"
    refreshEnv = 'Refresh environment before executing "Run" actions'
    showTrayIcon = "Display EventGhost icon in system tray"
    StartWithWindows = 'Autostart EventGhost for user "%s"' % os.environ["USERNAME"]
    UseAutoloadFile = "Autoload file"
    UseFixedFont = 'Use fixed-size font in the "Log" pane'
class OptionsDialog(eg.TaskletDialog):
    instance = None
    @eg.LogItWithReturn
    def Configure(self, parent=None):
        if OptionsDialog.instance:
            OptionsDialog.instance.Raise()
            return
        OptionsDialog.instance = self
        text = Text
        config = eg.config
        self.useFixedFont = config.useFixedFont
        eg.TaskletDialog.__init__(
            self,
            parent=parent,
            title=text.Title,
        languageNames = eg.Translation.languageNames
        languageList = ["en_EN"]
        for item in os.listdir(eg.languagesDir):
            name, ext = os.path.splitext(item)
            if ext == ".py" and name in languageNames:
                languageList.append(name)
        languageList.sort()
        languageNameList = [languageNames[x] for x in languageList]
        notebook = wx.Notebook(self, -1)
        page1 = eg.Panel(notebook)
        notebook.AddPage(page1, text.Tab1)
        # page 1 controls
        startWithWindowsCtrl = page1.CheckBox(
            exists(join((eg.folderPath.Startup or ""), eg.APP_NAME + ".lnk")),
            text.StartWithWindows
        if eg.folderPath.Startup is None:
            startWithWindowsCtrl.Enable(False)
        checkUpdateCtrl = page1.CheckBox(config.checkUpdate, text.CheckUpdate)
        checkPreReleaseCtrl = page1.CheckBox(config.checkPreRelease, text.CheckPreRelease)
        checkPreReleaseCtrl.Enable(config.checkUpdate)
        def OnCheckUpdateCheckBox(event):
            checkPreReleaseCtrl.Enable(event.IsChecked())
        checkUpdateCtrl.Bind(wx.EVT_CHECKBOX, OnCheckUpdateCheckBox)
        confirmDeleteCtrl = page1.CheckBox(
            config.confirmDelete,
            text.confirmDelete
        showTrayIconCtrl = page1.CheckBox(
            config.showTrayIcon,
            text.showTrayIcon
        hideOnCloseCtrl = page1.CheckBox(
            config.hideOnClose,
            text.HideOnClose
        memoryLimitCtrl = page1.CheckBox(config.limitMemory, text.limitMemory1)
        memoryLimitSpinCtrl = page1.SpinIntCtrl(
            config.limitMemorySize,
            min=4,
            max=999
        def OnMemoryLimitCheckBox(dummyEvent):
            memoryLimitSpinCtrl.Enable(memoryLimitCtrl.IsChecked())
        memoryLimitCtrl.Bind(wx.EVT_CHECKBOX, OnMemoryLimitCheckBox)
        OnMemoryLimitCheckBox(None)
        refreshEnvCtrl = page1.CheckBox(
            config.refreshEnv,
            text.refreshEnv
        propResizeCtrl = page1.CheckBox(
            config.propResize,
            text.propResize
        useFixedFontCtrl = page1.CheckBox(
            config.useFixedFont,
            text.UseFixedFont
        def OnFixedFontBox(evt):
            self.UpdateFont(evt.IsChecked())
        useFixedFontCtrl.Bind(wx.EVT_CHECKBOX, OnFixedFontBox)
        datestampCtrl = page1.TextCtrl(config.datestamp)
        datestampCtrl.SetToolTipString(text.DatestampHelp)
        datestampLabel = page1.StaticText(text.Datestamp)
        datestampLabel.SetToolTipString(text.DatestampHelp)
        datestampSzr = wx.BoxSizer(wx.HORIZONTAL)
        datestampSzr.AddMany((
            (datestampLabel, 0, wx.ALIGN_CENTER_VERTICAL | wx.RIGHT, 5),
            (datestampCtrl, 1, wx.EXPAND)
        def OnDatestampKillFocus(_):
            dt_fmt = datestampCtrl.GetValue()
            try:
                strftime(dt_fmt, localtime())
            except ValueError:
                wx.MessageBox("Invalid format string!", "Error")
                datestampCtrl.SetBackgroundColour("pink")
                datestampCtrl.Refresh()
                wx.CallAfter(datestampCtrl.SetFocus)
                    wx.SystemSettings_GetColour(wx.SYS_COLOUR_WINDOW)
        datestampCtrl.Bind(wx.EVT_KILL_FOCUS, OnDatestampKillFocus)
        languageChoice = BitmapComboBox(page1, style=wx.CB_READONLY)
        for name, code in zip(languageNameList, languageList):
            filename = os.path.join(eg.imagesDir, "flags", "%s.png" % code)
            if os.path.exists(filename):
                image = wx.Image(filename)
                image.Resize((16, 16), (0, 3))
                bmp = image.ConvertToBitmap()
                languageChoice.Append(name, bmp)
                languageChoice.Append(name)
        languageChoice.SetMinSize((150, -1))
        buttonRow = eg.ButtonRow(self, (wx.ID_OK, wx.ID_CANCEL))
        # construction of the layout with sizers
        flags = wx.ALIGN_CENTER_VERTICAL
        memoryLimitSizer = eg.HBoxSizer(
            (memoryLimitCtrl, 0, flags),
            (memoryLimitSpinCtrl, 0, flags),
            (page1.StaticText(text.limitMemory2), 0, flags | wx.LEFT, 2),
        startGroupSizer = wx.GridSizer(cols=1, vgap=2, hgap=2)
        startGroupSizer.AddMany(
                (startWithWindowsCtrl, 0, flags),
                (checkUpdateCtrl, 0, flags),
                (checkPreReleaseCtrl, 0, flags | wx.LEFT, INDENT_WIDTH),
                (confirmDeleteCtrl, 0, flags),
                (showTrayIconCtrl, 0, flags),
                (hideOnCloseCtrl, 0, flags),
                (memoryLimitSizer, 0, flags),
                (refreshEnvCtrl, 0, flags),
                (propResizeCtrl, 0, flags),
                (useFixedFontCtrl, 0, flags),
                (datestampSzr, 0, flags),
        langGroupSizer = page1.VStaticBoxSizer(
            text.LanguageGroup,
            (languageChoice, 0, wx.LEFT | wx.RIGHT, INDENT_WIDTH),
        page1Sizer = eg.VBoxSizer(
            ((15, 7), 1),
            (startGroupSizer, 0, wx.EXPAND | wx.ALL, 5),
            ((15, 7), 1),
            (langGroupSizer, 0, wx.EXPAND | wx.ALL, 5),
        page1.SetSizer(page1Sizer)
        page1.SetAutoLayout(True)
        sizer = eg.VBoxSizer(
            (notebook, 1, wx.EXPAND | wx.TOP | wx.LEFT | wx.RIGHT, 5),
            (buttonRow.sizer, 0, wx.EXPAND),
        self.SetSizerAndFit(sizer)
        self.SetMinSize(self.GetSize())
        notebook.ChangeSelection(0)
        oldLanguage = config.language
        while self.Affirmed():
            config.checkUpdate = checkUpdateCtrl.GetValue()
            config.checkPreRelease = checkPreReleaseCtrl.GetValue()
            config.confirmDelete = confirmDeleteCtrl.GetValue()
            config.showTrayIcon = showTrayIconCtrl.GetValue()
            config.hideOnClose = hideOnCloseCtrl.GetValue()
            config.limitMemory = bool(memoryLimitCtrl.GetValue())
            config.limitMemorySize = memoryLimitSpinCtrl.GetValue()
            config.refreshEnv = refreshEnvCtrl.GetValue()
            config.propResize = propResizeCtrl.GetValue()
            config.useFixedFont = useFixedFontCtrl.GetValue()
            config.datestamp = datestampCtrl.GetValue()
            config.language = languageList[languageChoice.GetSelection()]
            config.Save()
            self.SetResult()
        eg.Utils.UpdateStartupShortcut(startWithWindowsCtrl.GetValue())
        if config.showTrayIcon:
            eg.taskBarIcon.Show()
            eg.taskBarIcon.Hide()
        if eg.mainFrame:
            eg.mainFrame.SetWindowStyleFlag()
            eg.mainFrame.logCtrl.SetDTLogging()
        if config.language != oldLanguage:
            wx.CallAfter(self.ShowLanguageWarning)
        OptionsDialog.instance = None
    @eg.LogItWithReturn
    def OnCancel(self, event):
        self.UpdateFont(self.useFixedFont)
        self.DispatchEvent(event, wx.ID_CANCEL)
    @eg.LogItWithReturn
    def OnClose(self, event):
    def ShowLanguageWarning(self):
        dlg = wx.MessageDialog(
            eg.document.frame,
            Text.confirmRestart,
            wx.YES_NO | wx.ICON_QUESTION
        res = dlg.ShowModal()
        dlg.Destroy()
        if res == wx.ID_YES:
            eg.app.Restart()
    def UpdateFont(self, val):
        font = eg.document.frame.treeCtrl.GetFont()
        if val:
            font = wx.Font(font.GetPointSize(), wx.DEFAULT, wx.NORMAL, wx.NORMAL, False, "Courier New")
        wx.CallAfter(eg.document.frame.logCtrl.SetFont, font)
molitar
Post by molitar » Sun Mar 10, 2019 1:06 am
I am unable to use options menu at all. I can not set it to not close on x.
When I try to use options I get the following error.
Post by kgschlosser » Tue Mar 12, 2019 8:39 pm
@molitar
replace the file
with the one that is attached
OptionsDialog.py
(10.9 KiB) Downloaded 138 times
cableghost
Post by cableghost » Tue Mar 12, 2019 10:32 pm
@molitar
replace the file
I'm still receiving the error mentioned above after shutting EG down, replacing file and restarting.
Post by kgschlosser » Tue Mar 12, 2019 10:53 pm
post the error for me please
Post by kgschlosser » Tue Mar 12, 2019 10:58 pm
this iis the code for the originial OptionsDialog.py
    instance = None
    @eg.LogItWithReturn
            return
        text = Text
        config = eg.config
            self,
            parent=parent,
            title=text.Title,
        languageList = ["en_EN"]                                           <<<<<<<<<<<<<<<<<<< OLD
        languageList.sort()
and this is the same block of code but has been updated for the en_US language
    instance = None
    @eg.LogItWithReturn
            return
        text = Text
        config = eg.config
            self,
            parent=parent,
            title=text.Title,
        languageList = ["en_US"]                                 <<<<<<<<<<<<<<<<<<< NEW
        languageList.sort()
as you can see I made the change. so the same error should not be occurring.
cableghost
Post by cableghost » Tue Mar 12, 2019 11:35 pm
6:34:14 PM   Traceback (most recent call last) (0.5.0-rc6):
6:34:14 PM     File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 162, in ProcessingTask
6:34:14 PM       self.Configure(*args, **kwargs)
6:34:14 PM     File "C:\Program Files (x86)\EventGhost\eg\Classes\OptionsDialog.py", line 194, in Configure
6:34:14 PM       languageChoice.SetSelection(languageList.index(config.language))
6:34:14 PM   ValueError: 'en_US' is not in list
EG 0.5.0-rc6
Post by kgschlosser » Wed Mar 13, 2019 1:10 am
with a text editor like sublime text or notepad++ not notepad and not wordpad open up OptionsDialog.py.
do a search for
if it finds it replace the en_EN with en_US
molitar
Post by molitar » Fri Mar 15, 2019 12:50 am
I found some fatal bugs with this new version. I decided to start off new to see if it would fix the random problems I been having.
Fresh brand new install and added three plugins and none of my events would work with MPC-Home not even volume control or OSD Show. I then took my backup of the entire plugins folder and overwrote EVERY single plugin with the latest 0.4 version and everything worked perfectly! The new plugins break everything!
I have attached a copy of my default.xml that I am using with the 3 added plugins which is Media Player Classic 2.1.3, Taskbar 1.0.0, and DX USB Remote.
Please see if you can figure out why the new plugins break everything to do with Media Player Classic with attached files.
plugins.zip
(85.19 KiB) Downloaded 86 times
default.xml
(73.46 KiB) Downloaded 90 times
Post by kgschlosser » Fri Mar 15, 2019 6:16 pm
are you getting any errors?
Post by kgschlosser » Fri Mar 15, 2019 6:19 pm
So you say that older versions of the plugins work? or an older version of EG?
if it is older versions of the plugins I am goiign to need the older ones as well as the newer ones that do not work. I need to compare the 2 side by side to see what has changed,
