C++ Runtime Error
Re: C++ Runtime Error
Will you find time to check on this any further?
- kgschlosser
yes I will. I have a joystick to be able to test with.. problem is I cannot seem to locate it,
great, thx!
If you can implement something like a log output being created while using joystick plugin I can use/test it and send you the log in case that might be of any help..
