IP controlled relay board
Peter M
Re: IP controlled relay board
Post by Peter M » Wed May 20, 2020 8:29 am
Here's the latest -
import requests
data = '''\
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
    <s:Body>
        <u:Browse xmlns:u="urn:schemas-upnp-org:service:ContentDirectory:1">
            <ObjectID>Q:0</ObjectID>
            <BrowseFlag>BrowseDirectChildren</BrowseFlag>
            <Filter>dc:title,dc:creator</Filter>
             <StartingIndex>{starting_index}</StartingIndex>
            <RequestedCount>10</RequestedCount>
            <SortCriteria></SortCriteria>
        </u:Browse>
    </s:Body>
</s:Envelope>
starting_index = eg.event.payload.split('=')[-1]
data = data.format(starting_index=starting_index )
headers = {
    'Content-Type': 'text/html; charset=UTF-8',
    'SOAPACTION': 'urn:schemas-upnp-org:service:ContentDirectory:1#Browse',
    'Content-Length': len(data)
response = requests.post('http://192.168.0.32:1400/MediaServer/ContentDirectory/Control', data=data, headers=headers)
from xml.etree import ElementTree
data = response.content
# this function strips namespace information
def strip_namespaces(in_data):
    lines = []
    line = ''
    for char in list(in_data):
        if char == '>':
            line += char
            lines += [line]
            line = ''
            continue
        elif char == '<' and line:
            lines += [line]
            line = ''
        line += char
    if line:
        lines += [line]
    for i, line in enumerate(lines):
        if '<' not in line:
            continue
        while 'xmlns=' in line:
            beg, end = line.split('xmlns=', 1)
            end = end.split('"', 2)[-1].strip()
            line = beg + end
        while 'xmlns:' in line:
            beg, end = line.split('xmlns:', 1)
            xmlns, end = end.split('=', 1)
            line = beg + end
            while xmlns + ':encodingStyle=' in line:
                beg, end = line.split(xmlns + ':encodingStyle=', 1)
                line = beg + end
            lines[i] = line
            for j, lne in enumerate(lines[i:]):
                if '<' not in lne:
                    continue
                lne = lne.replace('<' + xmlns + ':', '<')
                lne = lne.replace('</' + xmlns + ':', '</')
                lines[i + j] = lne
    out_data = ''.join(lines)
    return ''.join(line for line in out_data.split('\n'))
# strip the namespace data here
data = strip_namespaces(data)
# create an xml object from the stripped data
xml = ElementTree.fromstring(data)
# locate the elements that we are looking for
body = xml.find('Body')
browse_response = body.find('BrowseResponse')
result = browse_response.find('Result')
# data is stored in the text area of the result field
data = result.text
# strip the namespaces from the result data
# turn the result data into an xml object
xml = ElementTree.fromstring(data.encode('utf-8'))
track = 1
for item in xml:
    message = 'artist' + str(track) + ':' + item.find('creator').text + ':'
    eg.plugins.BroadcastListener.Broadcast(message, u'', 33339)
    message = 'title' + str(track) + ':' + item.find('title').text + ':'
    if track == 1:
        message = 'artist:' + item.find('creator').text + ':'
        message = message.replace('!', '%21')
        message = message.replace('&', '%26')
        message = message.replace(';', '%3B')
        message = 'album:' + item.find('album').text + ':'
#    print 'res:', item.find('res').text
#    print 'albumArtURI:', item.find('albumArtURI').text
#    print 'class:', item.find('class').text
    track = track + 1
while track < 11:
    message = 'artist' + str(track) + ':  :'
    message = 'title' + str(track) + ':  :'
    track = track + 1
Cheers,
Peter
Post by kgschlosser » Thu May 21, 2020 4:56 am
give this whirly bird a twirl.
import requests
data = '''\
    <s:Body>
        </u:Browse>
    </s:Body>
</s:Envelope>
data = data.format(starting_index=starting_index)
headers = {
    data=data,
    headers=headers
    lines = []
    line = ''
        if char == '>':
            line += char
            lines += [line]
            line = ''
            continue
            lines += [line]
            line = ''
        line += char
    if line:
        lines += [line]
        if '<' not in line:
            continue
            line = beg + end
            line = beg + end
                line = beg + end
            lines[i] = line
                if '<' not in lne:
                    continue
                lines[i + j] = lne
data = result.text
# So i added the xml decleration line which has an encoding attribute.
# I am hoping this is going to solve the issue you are having.
# if it does not this is bacause the encoding that is being used
# by your computer running EG differs from the encoding that is being used by
# your media server. we may have to do some additional encoding and decoding
# to give it a kick in the ass to work, but lets give this a shot first.
data = '<?xml version="1.0" encoding="UTF-8" ?>' + data
# OK so here I subclassed str to build a custom formatter that
# will remove any special characters if needed.
class SpecialFormat(str):
    def format(self, *args, **kwargs):
        if 'replace' in kwargs:
            args = '**??**'.join(str(itm) for itm in args)
            for pattern, value in (
                    ('!', '%21'),
                    ('&', '%26'),
                    (';', '%3B'),
                args = args.replace(pattern, value)
            args = args.split('**??**')
        return str.format(self, *args)
# because you were doing quite a bit of adding strings together
# and also because you had these 3 packate you are sending it
# is more efficient code to declare the packet a single time
# and then plug in the information we need. the {0} and {1}
# mean argument 1 and argument 2 for the method format()
artist = SpecialFormat('artist{0}:{1}:')
title = SpecialFormat('title{0}:{1}:')
album = SpecialFormat('album{0}:{1}:')
# just a code reducing function. I set
# the payload to None because you are not
# sending any payload data.
def send(msg):
    eg.plugins.BroadcastListener.Broadcast(msg, None, 33339)
# reduction of code using a different iteration
# technique to get the track number.
# I also used that new send function along with using format()
# to reduce the amount of code needed here.
for track, item in enumerate(xml, start=1):
    send(artist.format(track, item.find('creator').text))
    send(title.format(track, item.find('title').text))
    if not track:
        send(artist.format('', item.find('creator').text, replace=True))
        send(album.format('', item.find('album').text, replace=True))
for track in range(track, 11):
    send(artist.format(track, '  '))
    send(title.format(track, '  '))
Peter M
Post by Peter M » Fri May 22, 2020 7:43 am
A couple of problems.
1. It's no longer sending artist and album, and instead its sending two artist10 and title10 with the second ones blank -
udp.artist1:k.d. lang:
udp.title1:Season of Hollow Soul:
udp.artist2:k.d. lang:
udp.title2:Constant Craving:
udp.artist3:Kate Bush:
udp.title3:Wuthering Heights:
udp.artist4:Kate Bush:
udp.title4:Feel It:
udp.artist5:Kylie Minogue:
udp.title5:Butterfly:
udp.artist6:Kylie Minogue:
udp.title6:Light Years:
udp.artist7:Kylie Minogue:
udp.title7:The One:
udp.artist8:Leona Lewis:
udp.title8:Run:
udp.artist9:Lighthouse Family:
udp.title9:Free/One:
udp.artist10:Lighthouse Family:
udp.title10:Whatever Gets You Through the Day:
udp.artist10: :
udp.title10: :
2. Accented characters are still tripping it up -
Python script "63", line 117, in <module>
File "xml\etree\ElementTree.pyc", line 963, in XML
File "xml\etree\ElementTree.pyc", line 1245, in feed
UnicodeEncodeError: 'ascii' codec can't encode character u'\xeb' in position 479: ordinal not in range(128)
Cheers,
Peter
Peter M
Post by Peter M » Fri May 22, 2020 8:42 am
When there are less than 10 items in the queue the repeat is always on the last one. Here it's artist5 and title5 -
udp.artist1:Hunters & Collectors:
udp.title1:True Tears of Joy:
udp.artist2:Hunters & Collectors:
udp.title2:Where Do You Go?:
udp.artist3:Hunters & Collectors:
udp.title3:Back in the Hole:
udp.artist4:Hunters & Collectors:
udp.title4:Holy Grail:
udp.artist5:Hunters & Collectors:
udp.title5:Throw Your Arms Around Me:
udp.artist5: :
udp.title5: :
udp.artist6: :
udp.title6: :
udp.artist7: :
udp.title7: :
udp.artist8: :
udp.title8: :
udp.artist9: :
udp.title9: :
udp.artist10: :
udp.title10: :
Peter M
Post by Peter M » Wed May 27, 2020 12:35 pm
I made a couple of minor changes to this section -
    if track ==1:
for track in range(track+1, 11):
and it fixed problem 1.
The accented chars are still a problem.
Cheers,
Peter
Post by kgschlosser » Wed May 27, 2020 9:45 pm
let me see the error you are getting now after the changes have been made. I am wondering if the problem may have moved to a new location.
Peter M
Post by Peter M » Thu May 28, 2020 1:58 pm
Here's the latest code -
import requests
data = '''\
    <s:Body>
        </u:Browse>
    </s:Body>
</s:Envelope>
headers = {
    data=data,
    headers=headers
    lines = []
    line = ''
        if char == '>':
            line += char
            lines += [line]
            line = ''
            continue
            lines += [line]
            line = ''
        line += char
    if line:
        lines += [line]
        if '<' not in line:
            continue
            line = beg + end
            line = beg + end
                line = beg + end
            lines[i] = line
                if '<' not in lne:
                    continue
                lines[i + j] = lne
data = result.text
                    ('!', '%21'),
                    ('&', '%26'),
                    (';', '%3B'),
def send(msg):
    if track ==1:
and here's the error message -
Python script "65", line 117, in <module>
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in position 1775: ordinal not in range(128)
Cheers,
Peter
Post by kgschlosser » Fri May 29, 2020 4:02 am
give this one a shot. for the life of me I can't remember if it needs to be encoded or decoded. But we will soon know.
import requests
data = '''\
            <s:Body>
                </u:Browse>
            </s:Body>
        </s:Envelope>
headers = {
    data=data,
    headers=headers
    lines = []
    line = ''
        if char == '>':
            line += char
            lines += [line]
            line = ''
            continue
            lines += [line]
            line = ''
        line += char
    if line:
        lines += [line]
        if '<' not in line:
            continue
            line = beg + end
            line = beg + end
                line = beg + end
            lines[i] = line
                if '<' not in lne:
                    continue
                lines[i + j] = lne
data = result.text
xml = ElementTree.fromstring(data.decode('utf-8'))
                    ('!', '%21'),
                    ('&', '%26'),
                    (';', '%3B'),
def send(msg):
    if track == 1:
for track in range(track + 1, 11):
Peter M
Post by Peter M » Fri May 29, 2020 5:35 am
OK here's the error message from that one -
Python script "66", line 117, in <module>
File "encodings\utf_8.pyc", line 16, in decode
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in position 1223: ordinal not in range(128)
Cheers,
Peter
Post by kgschlosser » Sat May 30, 2020 12:44 am
next!!!
LOL
import requests
data = '''\
            <s:Body>
                </u:Browse>
            </s:Body>
        </s:Envelope>
headers = {
    data=data,
    headers=headers
    lines = []
    line = ''
        if char == '>':
            line += char
            lines += [line]
            line = ''
            continue
            lines += [line]
            line = ''
        line += char
    if line:
        lines += [line]
        if '<' not in line:
            continue
            line = beg + end
            line = beg + end
                line = beg + end
            lines[i] = line
                if '<' not in lne:
                    continue
                lines[i + j] = lne
data = result.text
                    ('!', '%21'),
                    ('&', '%26'),
                    (';', '%3B'),
def send(msg):
    if track == 1:
Peter M
Post by Peter M » Sat May 30, 2020 5:54 am
Different error -
Python script "67", line 160, in <module>
Python script "67", line 135, in format
UnicodeEncodeError: 'ascii' codec can't encode character u'\xeb' in position 4: ordinal not in range(128)
Cheers,
Peter
Peter M
Post by Peter M » Fri Jun 05, 2020 7:38 am
I decide that this wasn't worth spending any more time on as it applies to such a small subset of my music.
So I've ended up editing out all the accented characters in Artist and Album names.
Thanks again for all your help.
Cheers,
Peter
Post by kgschlosser » Sat Jun 06, 2020 4:38 am
OK cool. unicode problems are a HUGE annoyance with python 2. a lot of the annoyances simmer down in python 3 but some are still there.
