System plugin missing in latest 0.5 RC6 release
Forum rules
SOME_FUNCTION()
SOME_FUNCTION()
Event:
Main.test.0.1.2.3.4.5.6.7.8
1
2
Rapisho
Post by Rapisho » Sun Jul 07, 2019 4:29 pm
As said in the title eventghost reports an error on start in the log and then the plugin isnt listed in the settings.
Regards
Re: System plugin missing in latest 0.5 RC6 release
Post by kgschlosser » Wed Jul 10, 2019 10:14 pm
I need to see the exact error. and you will not see the system plugin anywhere except in the "Add Action" dialog. It is a core plugin and cannot be added or removed by a user.
I am also going to move this to the beta bug reports forum thread.
