Core Audio Plugin
nYce
Re: Core Audio Plugin
Post by nYce » Mon Feb 17, 2020 5:10 pm
kgschlosser wrote:
Thu Feb 06, 2020 5:12 pm
OK cool jonib. I never really looked to see if that functionality was available. I will add the ability if it is able to be done.
I believe there is a memory leak in Core Audio as well if there is anyone that can confirm this it would be helpful. It is a tricky mess working with these com interfaces and holding reference to them. It looks like it is with the thread loop I have running to detect audio output I have to check it.
I am also going to check into the error you are having nYce and I wil get that cleaned up as well.
Thank you very much for looking into it!
Pheggas
Post by Pheggas » Sat Feb 22, 2020 11:24 am
Windows Version: {10}
Windows Build: {1809}
Description of problem: I just installed and added your plugin, after that clicked Add Macro and (on first try it crashed but on second:) didn't respond for a few seconds but then wrote error below. Plugin didn't show in Macro window.
Error (if any):
[ code ]
Exception in thread CoreAudio.AudioCheckThread:
File "C:\ProgramData\EventGhost\plugins\CoreAudio\__init__.py", line 224, in run
_format_name(device),
File "C:\ProgramData\EventGhost\plugins\CoreAudio\__init__.py", line 162, in _format_name
name = obj.name.decode('utf-8')
File "encodings\utf_8.pyc", line 16, in decode
UnicodeEncodeError: 'ascii' codec can't encode character u'\xae' in position 9: ordinal not in range(128)
[ /code ]
EventGhost 0.5.0-rc6
Post by kgschlosser » Sat Feb 22, 2020 11:10 pm
I am aware of the problem with the decoding of the device names. It has to do with the language that is set in Windows. There are several issues I am working on solving that error being one of them.
As far as the plugin not showing up in the Macro window, that is normal behavior. If you click on the System plugin and then on the Audio folder you will see the actions added there. The Core Audio plugin is an extension of the System plugin specifically the audio handling portion of it.
nYce
Post by nYce » Mon Mar 09, 2020 10:51 pm
Any Update on this? :)
Post by kgschlosser » Mon Mar 09, 2020 11:22 pm
I am trying to solve a memory leak in the plugin. I am not sure why there is one I have been tinkering about with it trying to locate where the problem is.
nYce
Post by nYce » Thu Mar 12, 2020 9:20 am
If you need any help, or want me to run any tests, feel free to ask!
nYce
Post by nYce » Wed Apr 01, 2020 1:08 am
I'm sorry for asking again. Is there any chance to see an update in the near future or should i probably look for alternatives, since this plugin seems to be not working in my setup?
I understand, if you got way more important things to do! Just let me know if there is anything i can do or if its just not going to work.
LG Jay :)
Medy
Post by Medy » Wed Apr 01, 2020 4:22 am
LG Jay :)
Have you tried the old audioendpoint plugin.
The Download for version 2.2.1 still works ..
viewtopic.php?f=9&t=6213&hilit=audio#p31678
Im also using this version without any issues on windows 10.
You can switch default commucncaiont device etc...
Doing this alot to switch back and forth in discord from headphones back to speakers ....
As well as switching my mic input from headset to desk mic.
Im switching both "Console" and "Communications" for it to work properly
Its one of my favourite tasks eventghost does for me ;)...
