EventGhost_0.5.0-rc6 web server broken or changed?
mkanet
Post by mkanet » Thu Apr 02, 2020 5:54 am
I just upgraded from EventGhost_0.4.1.r1722 to EventGhost_0.5.0-rc6. It looks like something either changed or broke with the web server plugin. After the EG webserver receives an HTTP get command, the respective EG event SHOULD trigger the associated USB-UIRT IR EG action.
If I revert back to EventGhost_0.4.1.r1722, everything starts to work again. If I upgrade, things break again.
Could someone help me get the web server working like it used to without having to reverting back to EventGhost_0.4.1.r1722?
The whole reason why I upgraded is to be able to use my Python 2.7 modules in my EG scripts.
Thanks in advance to help!
Re: EventGhost_0.5.0-rc6 web server broken or changed?
Post by Sem;colon » Thu Apr 02, 2020 7:58 am
I can tell you that the webserver plugin in 0.5 rc6 is working in general. However, there were lots of changes to it since 0.4.1, so we need more information about your problem.
How is your plugin configured? (Picture of the configuration dialogue)
What is the HTTP get command you are using?
Any error messages in the EventGhost log?
Thank you!
