Running Powershell within Python Script
stillirise
Post by stillirise » Thu Nov 12, 2020 7:02 pm
Good day,
This is my first attempt at EventGhost, so please bear with me.
As part of an Unlock Workstation Macro, I have a Session.Unlock Event then a Python Script Action.
In the Python Script action, I have a Powershell script which turns on and off my Windows 10 bluetooth adapter based on time of day.
There is an error thrown, not in the EG log, but a command window pops up really fast then closes, so I can't read it.
2 questions:
1) Is this the right way to invoke my PS script?
2) How can I capture the error that is thrown?
I can successfully run the Powershell on the command line.
Thanks for any help.
import datetime
import time
import subprocess
import sys
timestamp = datetime.datetime.now().time() # Throw away the date information
time.sleep(1)
start = datetime.time(7, 55)
end = datetime.time(12)
subprocess.Popen(["powershell.exe", "C:\\Users\\humble\\bluetooth.ps1 -BluetoothStatus Off"])
Re: Running Powershell within Python Script
Post by Sem;colon » Fri Nov 13, 2020 12:33 pm
Hi stillirise,
Welcome to EventGhost!
There is an action to run a command line command in EventGhost, you can simply configure it -> right click -> copy as python and paste it in your script.
I would also recommend to use the full path to PowerShell.exe, not just PowerShell.exe
stillirise
Post by stillirise » Tue Nov 17, 2020 10:02 pm
Hi Sem;colon,
Thanks for the reply, but I'm not understanding what I should do.
When I Copy as Python from the Run Command action, I get this:
eg.plugins.System.Command(u'd', True, False, u'', True, False, False, False, False)
What does that mean, and where should I paste it exactly?
I included the full path to PowerShell in my script now
import datetime
import time
import subprocess
import sys
time.sleep(1)
subprocess.Popen(["C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\powershell.exe", "C:\\Users\\humble\\bluetooth.ps1 -BluetoothStatus Off"])
Post by Sem;colon » Tue Nov 17, 2020 11:02 pm
Well, you need to paste it in your script instead of the subprocess.popen call.
But make sure you configure and test that action before you copy it!
But to be honest, I think the thing that actually is keeping your script from running is the PowerShell Execution policy.
Try to run this before you run your script (e.g. At EG start)
Set-ExecutionPolicy Bypass -Scope Process
stillirise
Post by stillirise » Wed Nov 18, 2020 11:57 pm
I can run the command from the Windows prompt just fine:
C:\Windows\System32\WindowsPowerShell\v1.0\powershell.exe -command C:\Users\humble\bluetooth.ps1 -BluetoothStatus Off
I can't seem to make it work.
I can run from the command line successfully.
I can run a local python script successfully.
The python script action in EG is causing an error which I can't read because it pops up in a command window then closes but the message starts with "You cannot call a method on a null valued expression".
I tried both of your suggestions, Sem;colon, but no luck.
Thanks for the help anyways.
Post by kgschlosser » Fri Nov 20, 2020 6:11 pm
import datetime
import time
import subprocess
import sys
time.sleep(1)
proc = subprocess.Popen('"C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\powershell.exe" "C:\\Users\\humble\\bluetooth.ps1" -BluetoothStatus Off"')
proc.communicate()
stillirise
Post by stillirise » Wed Nov 25, 2020 12:32 am
Thanks for the reply but the same error is occurring:
I can run the same command on the python command line successfully - it turns off and on my bluetooth:
>>> proc = subprocess.Popen('"C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\powershell.exe" "C:\\Users\\humble\\bluetooth.ps1" -BluetoothStatus Off')
Post by kgschlosser » Mon Nov 30, 2020 12:27 am
let me see the entire traceback
Post by kgschlosser » Mon Nov 30, 2020 12:30 am
that error is actually being generated by powershell and not EventGhost.
send me the power shell script in a PM and let me dink about with seeing what is happening. You will have to zip the script up first.
