How to Launch a specific web page?
MikeMc601f
Post by MikeMc601f » Fri Jan 09, 2009 4:46 pm
Please help out a newbie. What i want to do is when i press a button on my remote it launches IE and goes to http://www.last.fm/listen/globaltags/hair%20metal
or if I press another button it would go to http://www.last.fm/listen/globaltags/funk
I have figured out how to launch IE but not how to tell it to go to a specific website. Thanks for the help.
Re: How to Launch a specific web page?
Post by Pako » Fri Jan 09, 2009 7:23 pm
Here is one way. Copy & paste it into your config tree:
<EventGhost Version="1487">
    <Folder Name="Open html pages" Expanded="True">
        <Macro Name="last.fm METALL" Expanded="True">
                EventGhost.PythonCommand(u'wx.LaunchDefaultBrowser("http://www.last.fm/listen/globaltags/hair%20metall")')
        <Macro Name="last.fm FUNK" Expanded="True">
                EventGhost.PythonCommand(u'wx.LaunchDefaultBrowser("http://www.last.fm/listen/globaltags/funk")')
MikeMc601f
Post by MikeMc601f » Fri Jan 09, 2009 8:42 pm
Pako, Thanks so much for your reply,
i did as you said and put a simple keybord shorcut in for an event but i get this error:
2:37:21 PM Error in Action: "wx.LaunchDefaultBrowser("http://www.last.fm/listen/globaltags/hair%20metall")"
Any help would be greatly appreciated.
Post by Pako » Fri Jan 09, 2009 9:02 pm
What version of EventGhost you use?
Try the latest *_Setup.exe from here:
http://www.eventghost.org/downloads/
MikeMc601f
Post by MikeMc601f » Fri Jan 09, 2009 10:07 pm
That fixed it, Thanks Pako. A couple more questions if you don't mind:
How do I make it so when I go from "Funk" to "Hair Metal" it changes the current IE window instead of opening a new tab and having 2 songs playing at once? :?
On the website when a station is playing if you dont like a song you can click the |> button. Is there any way to control that?
THanks for all your help.
Post by Pako » Sat Jan 10, 2009 6:15 pm
MikeMc601f wrote:A couple more questions if you don't mind:
I am afraid that no simple way to resolve this, there is not. More could try this python script:
from webbrowser import open as openurl
openurl("http://www.last.fm/listen/globaltags/funk", new = 0)
I do not have IE and I can not try. In Firefox, unfortunately, it does not work.
MikeMc601f wrote:On the website when a station is playing if you dont like a song you can click the |> button. Is there any way to control that?
Also this question holds the previous answer.
CollinR
Post by CollinR » Mon Jan 12, 2009 1:53 pm
wget will allow you to emulate clicking any hyperlink on a webpage.
z3us
Post by z3us » Sun Mar 04, 2018 4:02 pm
How can I launch a URL contained in {eg.event.payload[1]} ? The script doesn´t work with this variable
Edit: done, using the start program action with the path to chrome as executable and the variable in the Command line options field
Post by kgschlosser » Wed Mar 14, 2018 8:31 am
you can also use this script. This would be a better way because if you happen to change your default web browser you are going to have to update all of your EG macros.
But if you use this script it is going to use the default
import webbrowser
webbrowser.open('http://www.microsoft.com')
