SchedulGhost
loveleejohn
Re: SchedulGhost
Post by loveleejohn » Sun May 14, 2017 5:19 am
I actually tried both of the updates by topix and the behavior persisted which was what led me to try a few other options and I was finally able to get it working. :)
Re: SchedulGhost
Post by kgschlosser » Sun May 14, 2017 7:48 am
that's very strange that it depends on the xml being saved or not.
loveleejohn
Re: SchedulGhost
Post by loveleejohn » Sun May 14, 2017 5:10 pm
Although I have no idea as to why it happens, another interesting "must do first" is that you have to click apply or change the field for the first day of the week in order for the the "Show schedule ghost manager" to be selectable as well. These were all requirements while using the plugin on my windows 10 64bit box. Not sure if that affects things or not...
skribb
Re: SchedulGhost
Post by skribb » Mon May 15, 2017 10:48 pm
kgschlosser wrote:
skribb wrote:According to the schedule manager, that timer supposedly ran 53 minutes ago but the actual macro did not run. This is using topix's bugfixed version.
ok i will let him know. any way you would be able to provide a copy of your tree and also a copy of the scheduleghost.xml file in your %appdata%\eventghost folder. you can PM these to me.
Embarassingly enough it seems that I have done something wrong in the logic of my python script that is triggered by that particular schedule..... :roll:
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
Re: SchedulGhost
Post by kgschlosser » Tue May 16, 2017 12:39 pm
Don't be embarrassed. It happens to all of us. I guarantee if you search posts by me you will find a slew of them where I thought there was a bug and it turned out to be something I did. This is why we question down and try to reproduce the bug consistently. And if we cannot then we may ask for your tree and run it and see what happens to try and reproduce the bug using it. And if it happens then we can investigate it's source.
The end result is it is now working for you. Which is the end game right? So mission accomplished. Doesn't matter how you dig the whole or who digs it. Just as long as it gets dug.
Medy
Re: SchedulGhost
Post by Medy » Wed Sep 12, 2018 3:05 pm
on rc4 eg is throwing an error on sheduleghost. on every startup ..it is still working though.
 Fehler beim Start des Plugins: SchedulGhost
        File "C:\EventGhostNEW\eg\Classes\PluginInstanceInfo.py", line 192, in Start
        File "C:\EventGhostNEW\plugins\SchedulGhost\__init__.py", line 1727, in __start__
          self.data = self.xmlToData()
        File "C:\EventGhostNEW\plugins\SchedulGhost\__init__.py", line 2551, in xmlToData
          xmldoc = miniDom.parse(xmlfile)
        File "xml\dom\minidom.pyc", line 1918, in parse
        File "xml\dom\expatbuilder.pyc", line 924, in parse
        File "xml\dom\expatbuilder.pyc", line 207, in parseFile
      ExpatError: not well-formed (invalid token): line 1, column 0
Re: SchedulGhost
Post by Sem;colon » Wed Sep 12, 2018 3:09 pm
Hi Medy,
looks like a problem with your SchedulGhost .xml file.
Please check if it's still where you configured it it be and try to create a new one worst case.
Medy
Re: SchedulGhost
Post by Medy » Wed Sep 12, 2018 3:17 pm
ok deletet the old one now error is gone. Thx
jachin99
Re: SchedulGhost
Post by jachin99 » Wed Sep 11, 2019 3:50 pm
Anyone have a copy of this laying around?
Re: SchedulGhost
Post by jonib » Wed Sep 11, 2019 5:12 pm
Looks like it's included in EventGhost.
