url attribute
url attribute
Post by Pako » Sat Feb 19, 2011 4:22 pm
When registering plugin, a url attribute can be entered (inter alia). See for example:
eg.RegisterPlugin(
    name = "Desktop Remote",
    author = "Bitmonster",
    version = "1.0." + "$LastChangedRevision: 831 $".split()[1],
    canMultiLoad = True,
    url = "http://www.eventghost.net/forum/viewtopic.php?t=513",
    description = "Creates a remote-like desktop window.",
I think that so far this attribute is not used at all. And that's a shame.
So I made a very simple improvement. If the url attribute is defined, in the plugin configuration dialog will appear new line:
Click on the word here and the browser opens the relevant page.
I ask you:
1. Do you think I should incorporate it into the next build?
2. There are probably a more appropriate wording. Can you suggest some?
stottle
Re: url attribute
Post by stottle » Sat Feb 19, 2011 6:15 pm
Looks like a very nice change, and I think your wording is perfect.
Good work!
Brett
