LG TV via LAN
mrdavisma
Re: LG TV via LAN
Post by mrdavisma » Tue Feb 03, 2015 6:23 pm
Hi Sem;colon
Thanks for your input on this. After comparing the lgcommander script and this one I had noticed there where some lines missing in the handleCommand. I had been attempting to add them myself but ended up with syntax errors aplenty lol ( I think I will have to buy python for noobs to read on my lunch breaks at work! )
Anyway the downside is after adding your corrected code I am still not getting a response. As before the script is returning a session ID so we know it is communicating with the tv but nothing happen after that, no action on tv nor an error in eg
With my limited experience I even tried changing the handlecommand to be the same as requested here
http://developer.lgappstv.com/TV_HELP/i ... yInput.htm
<envelope>
    <api type="command">
        <name>HandleKeyInput</name>
        <value>Value key code of remote Controller</value>
    </api>
</envelope>
but again no errors nor any action. At least when there were errors I had something to google lol
If you have anymore ideas it would be great but i also understand that as you dont have a tv to test this on it is not easy.
Mark
Re: LG TV via LAN
Post by Sem;colon » Tue Feb 03, 2015 8:59 pm
hmm, pls try this:
    import httplib
    import xml.etree.ElementTree as etree
    import socket
    import re
    lgtv = {}
    dialogMsg =""
    headers = {"Content-Type": "application/atom+xml"}
    lgtv["pairingKey"] = "939781"
    #lgtv["ipaddress"] = "192.168.0.5"
    lgtv["port"] = 8080
    command="26"
    def getip():
        strngtoXmit =   'M-SEARCH * HTTP/1.1' + '\r\n' + \
                        'HOST: 239.255.255.250:1900'  + '\r\n' + \
                        'MAN: "ssdp:discover"'  + '\r\n' + \
                        'MX: 2'  + '\r\n' + \
                        'ST: urn:schemas-upnp-org:device:MediaRenderer:1'  + '\r\n' +  '\r\n'
        bytestoXmit = strngtoXmit.encode()
        sock = socket.socket( socket.AF_INET, socket.SOCK_DGRAM )
        sock.settimeout(3)
        found = False
        gotstr = 'notyet'
        i = 0
        ipaddress = None
        sock.sendto( bytestoXmit,  ('239.255.255.250', 1900 ) )
        while not found and i <= 5 and gotstr == 'notyet':
            try:
                gotbytes, addressport = sock.recvfrom(512)
                gotstr = gotbytes.decode()
            except:
                i += 1
                sock.sendto( bytestoXmit, ( '239.255.255.250', 1900 ) )
            if re.search('LG', gotstr):
                ipaddress, _ = addressport
                found = True
                gotstr = 'notyet'
            i += 1
        sock.close()
        if not found :
            print "Lg TV not found"
        return ipaddress
    def displayKey():
        conn = httplib.HTTPConnection( lgtv["ipaddress"], port=lgtv["port"])
        reqKey = "<!--?xml version=\"1.0\" encoding=\"utf-8\"?--><auth><type>AuthKeyReq</type></auth>"
        conn.request("POST", "/roap/api/auth", reqKey, headers=headers)
        httpResponse = conn.getresponse()
        if httpResponse.reason != "OK" :
            print "LG TV: Network error"
        return httpResponse.reason
    def getSessionid():
        pairCmd = "<!--?xml version=\"1.0\" encoding=\"utf-8\"?--><auth><type>AuthReq</type><value>" + lgtv["pairingKey"] + "</value></auth>"
        conn.request("POST", "/roap/api/auth", pairCmd, headers=headers)
        tree = etree.XML(httpResponse.read())
        return tree.find('session').text
    def getPairingKey():
        displayKey()
    def handleCommand(cmdcode):
        cmdText = "<!--?xml version=\"1.0\" encoding=\"utf-8\"?--><command><name>HandleKeyInput</name><value>"+cmdcode+"</value></command>"
        conn.request("POST", "/roap/api/command", cmdText, headers=headers)
    #main()
    lgtv["ipaddress"] = getip()
    print "LG TV IP: "+lgtv["ipaddress"]
    theSessionid = getSessionid()
    while theSessionid == "Unauthorized" :
        getPairingKey()
    if len(theSessionid) < 8 :
        print "LG TV: Could not get Session Id: " + theSessionid
    lgtv["session"] = theSessionid
    result = command
    handleCommand(result)
mrdavisma
Re: LG TV via LAN
Post by mrdavisma » Wed Feb 04, 2015 5:05 am
That's it!
Wow you swapped a couple of words around on the cmdText line and suddenly it all works! Thank you very much Sem;colon for taking the time to look into this and get it working. I had looked for sometime for a way to do this but only ever found dead ends.
I have decided it it finally time to have ago at learning python, I enjoy reading through trying to work out what does what in a script but I would like to be able to have a go at being able to right it now.
If I get any good maybe I will be able to turn this into a plug-in lol
Thank You
Mark
Re: LG TV via LAN
Post by Sem;colon » Wed Feb 04, 2015 11:00 am
You're welcome!
It's quite simple to trun this script into a plugin, so that would be a nice beginner work I guess :)
mrdavisma
Re: LG TV via LAN
Post by mrdavisma » Thu Feb 12, 2015 12:08 pm
Well just an update. I guess I wont be turning this into a plug in for the simple reason, there is one available already!!!! and it works very well
viewtopic.php?f=10&t=6144
After weeks of searching for a solution I never once found this thread. I just happened to chance upon it today while browsing the forum.
I am guessing the forums are not getting indexed very well by google as even doing a search for the thread title + eventghost does not bring up the thread!
Mark
nosehook
Re: LG TV via LAN
Post by nosehook » Wed Jul 29, 2015 7:53 pm
I have a Panasocnic viera at home that I have connected to my LAN at home. Would this script work too or do I need something else?
tricky1024
Re: LG TV via LAN
Post by tricky1024 » Sun Dec 06, 2015 6:48 pm
Has anyone tried to control a 2015 WEBOS LG TV?, I need to turn off the TV over WIFI as CEC does not support this feature.
I have tried this script but looks like WEBOS is different, I have looked at: https://github.com/msloth/lgtv.js but am no programmer.
Any help would be great.
Jefman
Re: LG TV via LAN
Post by Jefman » Tue Aug 16, 2016 3:25 pm
I also have a LG of 2015 model (DTV55UF772V) I have tried above python script but get the following when pressing apply:
Python Script
Error compiling script.
IndentationError: unexpected indent (4, line 1)
IndentationError: unexpected indent (5, line 1)
When trying the plugin here:
I get this long error message :
Error in Action: "LG-TV 2012 IP: Send Key From List: 4 - Number 2"
return self(*args)
File "C:\Program Files (x86)\EventGhost\plugins\LG-2012-IP\__init__.py", line 245, in __call__
sendCommand(keyCode)
File "C:\Program Files (x86)\EventGhost\plugins\LG-2012-IP\__init__.py", line 214, in sendCommand
File "C:\Program Files (x86)\EventGhost\plugins\LG-2012-IP\__init__.py", line 191, in getSessionid
File "httplib.pyc", line 910, in request
File "httplib.pyc", line 947, in _send_request
File "httplib.pyc", line 904, in endheaders
File "httplib.pyc", line 776, in _send_output
File "httplib.pyc", line 735, in send
File "httplib.pyc", line 716, in connect
File "socket.pyc", line 514, in create_connection
error: [Errno 10061] No connection could be made because the target machine actively refused it
It seems to me that this has todo with pairing....
Any ideas ?
