Parsing payload
spyke11
Parsing payload
Post by spyke11 » Sat Jul 20, 2013 11:13 am
i'm novice in python's programmation...
I want to split eg.event.payload but the script return me this error :
AttributeError: AutoRemotePayload instance has no attribute 'split'
i use this script:
p = eg.event.payload
p = p.split(',')
the payload is "params: [u'Test', u'salut']; command(s): ;"
what's wrong , Can you help me please ?
piert
Re: Parsing payload
Post by piert » Sat Jul 20, 2013 2:03 pm
i use this script:
p = p.split(',')
Maybe you need to split your result first by using semicolon as a separator and post back your results.
piert
Re: Parsing payload
Post by piert » Sat Jul 20, 2013 2:27 pm
And by that I mean:
p = p.split(';')
print p[0]
print p[1]
If that works, you might get a result by adding q = p[0] .split(',')
Re: Parsing payload
Post by Sem;colon » Sat Jul 27, 2013 11:47 am
hmm, it looks like your payload is a dictionary with a list - maybe you could try something like:
p=eg.event.payload["params"][0]
if you want to use split try:
p = str(eg.event.payload)
p = p.split(',')
