Post by Sem;colon » Thu Feb 27, 2014 7:19 pm
This is the new official support thread for the "Microsoft MCE Remote - Vista/Win7" plugin ( also working on windows 8 ).
The original creator of this plugin (Brett Stottlemyer) seems to be disappeared from the forum, but his plugin, which you can find here: viewtopic.php?f=2&t=1789, was meanwhile improved by others.
To share the latest modified version in the usual location, the first post, this thread was created.
Change-log:
v1.1.4:
- Bug fixes
v1.1.2:
- Increased buffer size
- Automatically connecting to pipe if not connected and IR code should be transmitted
- Checking if some other device is sending IR commands and wait for it to finish before transmitting IR code
- Plugin is now in the .egplugin format
- Service is not automatically started any more if it's not running (did only work if EG has been executed as admin anyway)
v1.1.1:
- Added some events for Connected/Disconnected
MceRemote_Vista.egplugin
v1.1.4
(130.38 KiB) Downloaded 926 times
MceRemote_Vista.zip
v1.1.2
(113.96 KiB) Downloaded 698 times
MceRemote_Vista.zip
MceRemote_Vista (v1.1.1)
(117.12 KiB) Downloaded 2319 times
MceRemote_Vista.zip
MceRemote_Vista (v1.1.0)
(117.12 KiB) Downloaded 574 times
Post by blaher » Fri Feb 28, 2014 6:54 am
Thanks very much for working on the plug-in, and for starting a new thread so it's easy to find.
tjpearson
Post by tjpearson » Sat Mar 01, 2014 2:34 pm
Yeah, thanks a lot Sem;colon.
Big, big help.
tj :D
someguy1
Post by someguy1 » Sun Mar 02, 2014 2:11 pm
Why doesn't this plugin work with Hama MCE remote? Tried all versions of this, no help.
Post by Sem;colon » Sun Mar 02, 2014 4:20 pm
someguy1 wrote:Why doesn't this plugin work with Hama MCE remote? Tried all versions of this, no help.
I don't know, but the original one from Microsoft is working.
I guess you installed the "AlternateMceIr Service"?
Can anyone else confirm that it's not working with Hama device?
someguy1
Post by someguy1 » Sun Mar 02, 2014 4:28 pm
Yes I installed that service, the x64 version of it since I have a 64 bit W7, restarted, added the plugin to EG. But it didn't work.
I've searched extensively in this forum after any references to Hama, found this post viewtopic.php?f=2&t=1789&start=405 but it seems he wasn't able to get it working either with that old version of the plugin.
Furthermore, with the old plugin after installing the service, it ran automatically after reboot, but this new one doesn't. So after adding the plugin to EG i gotta press install service there, but still won't work.
I get no signal recognition whatsoever from it in EG. Maybe need to uninstall the device's own drivers first somehow?
Post by Sem;colon » Sun Mar 02, 2014 6:46 pm
someguy1 wrote:Furthermore, with the old plugin after installing the service, it ran automatically after reboot
What old plugin?
someguy1
Post by someguy1 » Mon Mar 03, 2014 6:14 am
this one viewtopic.php?f=2&t=1789
Anyways seems this Hama remote or Ortek as it's called in some other models uses keyboard strokes, so there probably isn't any way to get it working with EG.
Post by Sem;colon » Mon Mar 03, 2014 5:20 pm
OK, now I'm confused, you were able to get your remote working with this one viewtopic.php?f=2&t=1789 but not with the one from this thread?
Or what did work with the other plugin that doesn't with this one?
someguy1
Post by someguy1 » Mon Mar 03, 2014 8:41 pm
I didn't say the remote worked with that other plugin, the remote doesn't work with any plugin at all. I just said that the service ran by itself after a reboot on that other plugin, but not this one. However on this one it seems to be running by itself now after a reboot, if I install its service from EG instead of from the plugin folder.
Anyhow this remote will never work with EG, they should put that on their site so people avoid buying it. This is not a real remote, it just sends keyboard strokes.
Post by Sem;colon » Mon Mar 03, 2014 10:48 pm
Ah, OK, thank you.
Yes, I guess that's the reason :)
I can recommend the Original Microsoft MCE Receiver...
As a tip: Look for an receiver with IR blaster, these are usually correct working MCE receivers.
If you want to use your remote, you could try the Keyboard plugin (but this would also create events if you press the key on the keyboard)
someguy1
Post by someguy1 » Tue Mar 04, 2014 6:58 am
I see thanks. Yea I wanted the original MCE receiver too but the only IR remote available in my country was this. And sadly the MCE receiver costs tons of money on Amazon. I also have another Ir remote, the "PC remote controller". It too has lots of problems. The HP IR remotes seem cheap enough on Amazon, any thoughts on those?
Post by Sem;colon » Tue Mar 04, 2014 10:14 pm
I can not guarantee it, but I think the HP one will work...
A good place to find MCE receiver for a reasonable price (directly from China) is ebay.
Post by blaher » Wed Mar 05, 2014 2:15 am
Yeah, the HP ones that look like this: http://www.ebay.com.au/itm/Genuine-HP-U ... 1046824695 work very well.
someguy1
Post by someguy1 » Wed Mar 05, 2014 10:24 am
Thanks guys for your help.
