Remote Controls
zian
Re: Remote Controls
Post by zian » Tue Apr 22, 2014 7:58 pm
No I have not... yet.
I have been a lil distracted of late.
eventghost.net
Be there or be square.
ControlFreak
Re: Remote Controls
Post by ControlFreak » Mon Apr 28, 2014 8:27 am
query AAAE
While Googling for images, this also popped up as the SL-6399 Media Remote (0040).
Is the remote pictured in 0040 correct, or is this the correct one, or are both compatible with RP-0022.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Mon Apr 28, 2014 8:29 am
about 0001
ASUS PSR-2000
ASUS PSR-2000 variant.png (93.6 KiB) Viewed 8746 times
This variation of it does not have the same button colours for the top row of buttons.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Mon Apr 28, 2014 8:30 am
about 0001
nameless remotes that look like the ASUS PSR-2000
nameless PSR-2000.png (31.81 KiB) Viewed 8746 times
There is a company that manufactures the PSR-2000 in two different forms: 38kHz and 56kHz.
I do not know if these nameless models include a receiver, so I don't know if they will work.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sat May 03, 2014 7:00 am
query AAAF
This looks very similar to 0001, but it is different.
The Mute button for 0001 is between the VOL+- and CH+- buttons.
The Mute button for AAAF is below the VOL+- buttons.
That is all I know about this one so far.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sat May 03, 2014 7:10 am
query AAAG
The Mute button for AAAG is below the VOL+- buttons.
The directional pad is like a little joystick, and it has four extra cursor buttons.
It also seems to have a blaster plugged into the receiver.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Sat May 03, 2014 7:13 am
There is an uncanny similarity between 0001, AAAF, AAAG, and 0034.
(0001 AAAF AAAG 0034)
The general shape is the same.
The number of buttons is the same, except for AAAG.
The layout of the buttons is the same, except for AAAG.
The shape of the buttons is the same.
All have a LED on the top (where the buttons are).
Obviously, AAAG has a different directional pad, and additional cursor buttons.
Obviously, 0034 is a different colour.
The button functions, and labels, are also different from each other.
It is as if they all have the same OEM, although 0034 does not:
  • 0001 Vendor ID: 147A (Formosa Industrial Computing, Inc.)
    0034 Vendor ID: 06B4 (not listed in usb.ids)
Last edited by ControlFreak on Tue Aug 05, 2014 10:40 am, edited 3 times in total.
WharfRat
shaggy79
Re: Remote Controls
Post by shaggy79 » Sun Jul 13, 2014 5:23 pm
Hi there,
I have an internal memory card reader with IR
( http://www.ebay.co.uk/itm/Internal-USB- ... 1c30947a78 )
I know im being vague but what can I do with this, if anything :?:
ControlFreak
Re: Remote Controls
Post by ControlFreak » Wed Jul 16, 2014 9:22 am
about AAAH
Hi shaggy79,
Thanks for your query, I was beginning to think that this topic was a waste of time.
Let us refer to your query as AAAH.
First of all, did it come with a transmitter (the hadheld part with buttons) also?
Some of the remote controls for PCs follow the Microsoft MCE remote control recommendations.
The MCE remotes typically use the RC-6 infrared protocol.
What you can try for AAAH are the following MCE remote control plugins:
plugin 1: RP-0016
plugin 2: RP-0017
plugin 3: RP-0018
I am not saying that they will work, this is just a preliminary suggestion.
If it is MCE compatible, there is a registry hack that allows RP-0018 to respond to other IR remote protocols as well.
Also, I doubt that this device has IR blasting capabilities as well, just reception.
What might be most useful is to perform Procedure 01 and report the results here again.
Sorry for taking so long to reply, but thanks for considering this topic.
WharfRat
shaggy79
Re: Remote Controls
Post by shaggy79 » Fri Jul 18, 2014 6:45 pm
Re: AAAH
Thanks for the reply ControlFreak,
First of all... I found this topic VERY helpful!
It did not come with a remote, just what is in the picture. I've installed it in my PC, and sort of got it working with my TV remote through EG with "Microsoft MCE plugin".
Cheers Paul.
ControlFreak
Re: Remote Controls
Post by ControlFreak » Thu Jul 24, 2014 9:59 am
Re: AAAH
shaggy79...
It's great to know that it works with EventGhost, at least with RP-0016.
This is how I originally envisaged the purpose of the topic.
If you get yourself a Logitech Harmony or a Philips Pronto learning remote, then you could probably set up more buttons than are available on your TV remote.
In particular, with RP-0018, you could even choose different IR protocols.
Anyway, if you can get me the Vendor ID and the Product ID using Procedure 01, I can search for more info about it.
Then I can add AAAH to the list of working remotes.
Thanks for the encouragement... WharfRat/ControlFreak/Marius.
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Thu Aug 07, 2014 2:19 pm
The reorganization of the topic has finally been completed!
WharfRat
Spooner
Re: Remote Controls
Post by Spooner » Sat Aug 09, 2014 5:49 am
I'm quite new to Eventghost but have been using Girder 2.9 and an Igor serial IR receiver for many years however since windows 7 and up Girder is struggling so im trying to move completely to Eventghost however Girder has always worked well with Serial over Bluetooth and the Generic Serial plugin with various bluetooth Arduino Apps on various phones and I recently found this https://play.google.com/store/apps/deta ... e&hl=en_GB for android which works perfect with Girder but Eventghosts Serial addon isnt showing my BT com ports. Can you help please?
ControlFreak
Re: Remote Controls
Post by ControlFreak » Mon Aug 11, 2014 10:50 am
Hi Spooner, and welcome to EventGhost.
I don't know much about serial port adaptors for Bluetooth.
But perhaps I can suggest trying the Bluetooth plugins instead of the serial plugins.
Just wanted to let you know that you are not being ignored...
WharfRat
ControlFreak
Re: Remote Controls
Post by ControlFreak » Fri Aug 15, 2014 11:55 am
remote code: 0057
works: yes
name: Leap Motion Controller
Leap Motion Controller.png (117.2 KiB) Viewed 8229 times
Vendor ID:
Product ID:
alternate names:
variations:
equivalent remotes:
OEM: Leap Motion, Inc
type: non-remote
interface: USB
plugin: RP-0041
requirements:
WWW: http://www.leapmotion.com/
notes: this is a short-range sensor for hand gestures
verified: no
WharfRat
