Hi.
Thx for your work. Where can I download the last version? The link appear to be broken.
AudioEndpoint
- kgschlosser
Re: AudioEndpoint
There is another plugin that is still in testing that is a spin off of this plugin. It does work but you may encounter some problems with it. I am going to create a new topic for it and post it in the next day or so.
- kgschlosser
Re: AudioEndpoint
Here you go..
viewtopic.php?p=53499#p53499
Re: AudioEndpoint
Hi, does anyone have any of the last two versions (v2.3.3 or-v2.3.2) as the links for those are broken? I have the CoreAudio plugin but it would be great to try the later versions of AudioEndpoint too.
Thanks.
Thanks.
Re: AudioEndpoint
Hi chipd33,
the latest version I found in my backup is 2.3.2.
2.3.3 must still exist though, probably on an old PC I'm not using anymore.
anyways, please find 2.3.2 attached!
Edit: Depending in what functionally you need, you can also try v1.4, I guess that's still the most stable version
- AudioEndpoint.zip
- v2.3.2
- (48.37 KiB) Downloaded 58 times
Re: AudioEndpoint
Hi Sem;colon,
thanks so much , will also try v1.4 if that is your advice.
Much appreciated.
Chip
Much appreciated.
Chip
