SoundMixerEx
dexter98
SoundMixerEx
Post by dexter98 » Thu Feb 28, 2008 3:06 pm
This thread is for support on the SoundMixerEx plugin.
This plugin is an extension of the standard SoundMixer controls in EventGhost and allows you to setup virtually ANY slider and on/off switch (eg mute, digital out on/off) on one or more sound cards.
Multiple controls can be controlled on multiple sound cards through the same plugin. I personally use this plugin to switch on/off the 'digital out only' feature on my Audigy to be able to output (analog) sound, even when pass-through is active (which normally blocks any sound output other than the DD/DTS source).
SoundMixerEx.rar
(4.55 KiB) Downloaded 1024 times
Bartman
Re: SoundMixerEx plugin
Post by Bartman » Sat Mar 01, 2008 2:35 pm
I am currently trying under Vista.
I have some issues:
It seems the names get cut off in the half. (see first image)
All faders seem to get assigned to the first sound card. But if I select one in the tree the action is called "Decreases volume x on sound card 2".
dexter98
Post by dexter98 » Sun Mar 02, 2008 4:06 pm
Hmmm, it seems that each control is seen as a seperate soundcard for some strange reason.
I really have to look into this under Vista and since I currently don't have a machine running it here somewhere, it can take a while before I can take a good look at it.
However, it is promising that the controls are exposed to the original API functions anyway... Maybe it is possible to control only with a few tricks and fixes.
Have you tested it under XP on the same system? And does it run ok under XP?
Post by Bitmonster » Tue Mar 04, 2008 11:32 am
This plugin is now included in the latest beta version.
dexter98
Post by dexter98 » Wed Mar 05, 2008 11:55 pm
Great! What to do with it is currently not Vista compatible?
Bartman
Post by Bartman » Thu Mar 06, 2008 12:11 am
I suspect there is something wrong with the enumeration. It is odd that the action names to not correspond to the names in the tree.
Post by Bitmonster » Thu Mar 06, 2008 12:33 am
Even though MS said, under Vista the SoundMixer API is still supported, there seem do be some differences. For example it is no longer possible to control the master volume. It is mapped to a new application volume.
I guess it would be the best to use the new Vista API for this. It works completely different, but one might be able to let look like the Sound Mixer Ex plugin for Windows XP.
http://msdn2.microsoft.com/en-us/library/ms678715.aspx
http://www.eventghost.org/forum/viewtopic.php?f=4&t=271
dexter98
Post by dexter98 » Thu Mar 06, 2008 1:55 am
I really don't understand what's going wrong, although it's difficult to try to find the problem without having Vista running here.
However, if some sort of legacy API is exposed by Vista in some sort of way, there shouldn't actually be a problem I think using the 'old' API, especially because you select the control manually anyway.
It looks like enumeration works, but the parameters passed to the tree-building function are shifted in some sort of strange way...
If you select a control, does it work?
I've added an updated version of the plugin, which may work better, or, at least, more predicatble...
(18.34 KiB) Downloaded 590 times
topix
Post by topix » Thu Mar 06, 2008 6:04 pm
I tried the plugin on Vista64. When I add a macro i get the following error:
Error while configuring: %s Sound Mixer Ex: No device/control selected
  File "C:\Program Files (x86)\EventGhost\eg\Classes\MainFrame\__init__.py", line 779, in OnCmdNewMacro
    eg.UndoHandler.NewMacro().Do(self.document)
  File "C:\Program Files (x86)\EventGhost\eg\Utils.py", line 223, in Wrapper
    return gr.switch(*args, **kwargs)
  File "C:\Program Files (x86)\EventGhost\eg\Classes\UndoHandler\NewMacro.py", line 66, in Do
    actionObj = eg.UndoHandler.NewAction().Do(document, action)
  File "C:\Program Files (x86)\EventGhost\eg\Classes\UndoHandler\NewAction.py", line 60, in Do
    if not eg.UndoHandler.Configure().Do(item, True):
  File "C:\Program Files (x86)\EventGhost\eg\Classes\UndoHandler\Configure.py", line 53, in Do
    newArgs = gr.switch(*item.GetArgs())
  File "c:\Program Files (x86)\EventGhost\plugins\SoundMixerEx\__init__.py", line 449, in Configure
    treeCtrl = self.plugin.GetTree(panel, ("Switch"), deviceId, controlId)
  File "c:\Program Files (x86)\EventGhost\plugins\SoundMixerEx\__init__.py", line 402, in GetTree
    description = "%s on '%s'" % (description, mixerName)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe4 in position 20: ordinal not in range(128)
dexter98
Post by dexter98 » Thu Mar 06, 2008 9:27 pm
@topix
This error seems to be generated by something else. I'm looking into it.
dexter98
Post by dexter98 » Thu Mar 06, 2008 10:55 pm
Hmmm, ok. Don't really know where this is coming from.
Could it have something to do with 'mixerControl.szName.decode("mbcs")'?
topix
Post by topix » Fri Mar 07, 2008 5:58 pm
Yes, it could :wink: I removed all .decode("mbcs") in the plugin. Now i can add the macros and get the following list:
It doesn't matter which one i use, it will only affect EG. No entry takes affect on the Mastervolume.
dexter98
Post by dexter98 » Fri Mar 07, 2008 6:20 pm
Have you tried it with the new .py file attached just above?
topix
Post by topix » Fri Mar 07, 2008 8:50 pm
oops. I thought the version in EG.1295 were the latest. :oops: With the above version I have less items in the list. Still can only mute the volume for EG, but i think that is because of new API in Vista. :|
dexter98
Post by dexter98 » Sat Mar 08, 2008 10:03 pm
I assume you use 'Use sound fader/slider' in the Add Action part.
