SageTV
SageTV
Postby Bitmonster » Wed Apr 02, 2008 4:19 pm
Use this topic to post your questions and comments to the SageTV plugin.
Re: SageTV
Postby CollinR » Fri Apr 04, 2008 3:00 pm
Bitmonster wrote:Version 0.3.6.1353 (04/03/2008)
new: Member eruji added some more actions to the SageTV plugin.
Anyone know what these changes were?
CollinR
Re: SageTV
Postby Bitmonster » Fri Apr 04, 2008 3:33 pm
All actions from "Eject" to "Video Output".
Re: SageTV
Postby CollinR » Fri Apr 04, 2008 6:57 pm
With a couple of variables this could be expanded but I don't know how.
You already have all the commands.
Would it be possible to send the cmdFuncName rather then the value?
The reason I ask is the cmdFuncName will also work through the HTTP interface and the values will not. Combined with wget you can control any client anywhere using HTTP.
Example:
--delete-after http://USER:PASS@192.168.1.3/sage/SageCommand?context=000dfe0c5e6a&command=Power
The context is the MAC address of the client and the command is cmdFuncName for the most part.
CollinR
Re: SageTV
Postby Bitmonster » Fri Apr 04, 2008 7:05 pm
The plugin doesn't know anything about the MAC address. It only sends the command number to SageTVClient.exe.
Re: SageTV
Postby CollinR » Fri Apr 04, 2008 7:26 pm
Correct you would input the MAC where it currently requests SageTV.exe or SageTVClient.exe, the rest should work as I am pretty sure the cmdFuncName should work with the sendmessage it uses for the normal interaction.
I am assuming calling wget would be a similar process as finding the sendmessage utility but runcmd instead.
CollinR
Re: SageTV
Postby Bitmonster » Fri Apr 04, 2008 7:30 pm
I guess I've misunderstood you. You mean the hardware client can be controlled by wget? Is there any documentation about it?
Re: SageTV
Postby CollinR » Fri Apr 04, 2008 7:34 pm
Bitmonster wrote:I guess I've misunderstood you. You mean the hardware client can be controlled by wget? Is there any documentation about it?
I'm pretty sure it's ANY client! Hardware, software, local, remote any except the web interface itself.
I dunno about documentation but I use the chit out of it myself to control hardware clients.
--delete-after http://USER:PASS@192.168.1.3/sage/SageC ... mand=Power
context = MAC
command = cmdFuncName
Obviously you would also need to add in configuring the user/pass/IP/port but that only needs to be done once.
EDIT:
Got you some documentation:
SageTV Forums thread
http://forums.sagetv.com/forums/showthread.php?t=8426
Developer Website
http://tools.assembla.com/sageplugins/w ... ionHistory
Really nice guy, I talked to him about EG project, hopefully someday he may show up.
CollinR
Re: SageTV
Postby Bitmonster » Fri Apr 04, 2008 8:24 pm
Well, I need a list of all commands with the exact spelling for the webserver.
I tried to install SageTV and look into Setup->Commands like it is somewhere recommended to find the names. But since I installed it for the German language, the constants are shown in German. So I've set the language to English and everything shows up in English, except these command names. They stay in German. And that's obvious a bug in SageTV. It is also not clear if the user has set its language to something other, if the command strings should be send in English or the native language and which encoding is expected.
And I don't want to look through a 91 pages thread.
Re: SageTV
Postby CollinR » Fri Apr 04, 2008 8:53 pm
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%1
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%2
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%3
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%4
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%5
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%6
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%7
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%8
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%9
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Num%0
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Skip Bkwd/Page Left
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Skip Fwd/Page Right
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Time Scroll
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Play
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Play/Pause
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Record
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Stop
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Pause
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Back
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=UP
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Guide
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Home
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Recordings
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=TV
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=DVD
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Power
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Power On
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Power Off
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Watched
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Favorite
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Don't Like
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Left
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Select
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Down
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Right
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Info
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Mute
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Mute On
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Mute Off
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Volume UP
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Volume Down
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Previous Channel
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Channel Up/Page Up
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Channel Down/Page Down
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&command=Full Screen
--SageCommand?context=SAGETV_PROCESS_LOCAL_UI&comman=Delete
A few more too and I have no problems maintaining that part!!! (I don't think any language but English is supported)
Also interested in adding events from SageTV so EG will get channel change requests and can handle them however we see fit. Thats a totally different thread though.
It's insane how big some of the SageTV threads get.
CollinR
Re: SageTV
Postby CollinR » Wed Apr 09, 2008 5:53 pm
This is too much/different for this plugin. So if I do it I think it should be seperate anyway as it only works for users that have the Webserver interface.
If I can get channel change requests from SageTV's core I think that should be included.
I'll also try and keep a closer eye on the commands as they are now, I had no clue there were unsupported messages.
CollinR
Re: SageTV Client
Postby scat » Thu Jan 22, 2009 1:52 pm
Thanks Bitmonster :D
I recently set up a SageTV Client and was trying to get my SageTV area of eventghost working with the Sage Client.exe and I kept getting app not found for Sage, I was in the middle of setting all the keyboard keys and disabling the plugin lines and today I was looking at the plugin code and I found the code for the Sageclient.exe and I felt completly stupid for not checking the plugin in event ghost to see if it allows for switching from Sage to Sage Client.
I thank you very much for having it already coded for the Sage Client.exe, but could I make a suggestion, could your list in the add plugin list show (Sage or Sage Client) in the list so others will see it is for both.
Thanks again for a great program
I am still learning the Power of Eventghost!
Scat
scat
Re: SageTV
Postby CollinR » Thu Jan 22, 2009 2:40 pm
On that note I think I will find out if placeshifter can also use these messages!
Wouldn't that be a cool addition.
CollinR
Re: SageTV
Postby reeven » Sun Oct 04, 2009 9:41 am
Salut, i came from Intelliremote forum.
I install latest evenghost with latest win7 service and sagetv default profile.
I mapped ch up/down to my mce remote, i change the channel up and down, but the channel number does not appear in sagetv when i switch them , look at picture when it say: channel 88 ,
If i am at channel 87 and click UP on remote to go to channel 88 then 88 does not appear in sage, instead it appear this lines: ---
http://img219.imageshack.us/img219/5440/73289615.jpg
reeven
Re: SageTV
Postby CollinR » Sun Oct 04, 2009 1:49 pm
Make sure in EventGhost you match the Event (incoming IR in the left pane) to the macro action (SageTV channel UP in the right pane).
CollinR
Next
Return to Plugin Support
Who is online
Users browsing this forum: No registered users and 4 guests
