GOM Player
CHeitkamp
GOM Player
Post by CHeitkamp » Fri May 16, 2008 8:02 pm
I attached my first version of a plugin for controlling GOMPlayer.
Its partitially based on the MediaPlayerClassic plugin...
It's already fully functional, but i'll add more actions soon.
GOMPlayer/__init__.py
(5.63 KiB) Downloaded 683 times
Re: GOMPlayer PlugIn
Post by Bitmonster » Fri May 16, 2008 8:10 pm
Do you have a SourceForge user account? Then I can add you to the project members, so you can directly update your plugins through SVN.
I have added you to the "Plugin Developer" board group, so you can now start support threads in the Plugin forum. I move this thread there now.
CHeitkamp
Post by CHeitkamp » Fri May 16, 2008 8:54 pm
Bitmonster wrote:Do you have a SourceForge user account? Then I can add you to the project members, so you can directly update your plugins through SVN.
Thanks - my SF username is CHeitkamp.
Branko84
Full Screen Streched (Keep Ratio) in GomPlayer
Post by Branko84 » Fri Feb 10, 2012 5:40 am
Hi! Can you please add Full Screen Streched (Keep Ratio) in GomPlayer (shortcut CTRL + ALT + Enter).
This option is very useful, for now there is only Full Screen Streched (CTRL + Enter).
Branko84
Re: GOM Player
Post by Branko84 » Sat Feb 11, 2012 11:25 am
OK, i will wait new version of Gom setup file because
I don't know what to do with this *.py file.
Sorry and thanks!
Somateri
Re: Full Screen Streched (Keep Ratio) in GomPlayer
Post by Somateri » Fri Oct 05, 2012 7:59 am
Branko84 wrote:Hi! Can you please add Full Screen Streched (Keep Ratio) in GomPlayer (shortcut CTRL + ALT + Enter).
not sure why its useful
only want my nickname in plugin commentsxD
fix my english if something wrong:
Only works with last actived window GOM player.
(may be need add somehow if more than 1 instance GOM)
Pause and minimize to taskbar/restores the window.
install:
close eventghost
go to %programfiles%/eventghost/plugins/GomPlayer or where installed(usually path C:\Program Files\EventGhost\plugins\GOMPlayer)
backup(copy files to any another dir) and delete all files in this folder(should be __init__.py and __init__.pyc)
download atach(__init__.py) and put in this folder
run eventghost
1st time see python GOT OWNED BY SPACES/TABS
hope never will see python again
ok expect this addon
Features new version:
  • - added Fullscreen Stretched (Keep ratio)
    - added separately Pause and Play
    - added Mute
    - updated description BossKey
    - updated description plugin
last version plugin for GomPlayer
(6.73 KiB) Downloaded 317 times
useless_beta.zip
useless beta(DONT DOWNLOAD IT unless u know something about python)
(3.28 KiB) Downloaded 299 times
Branko84
Re: GOM Player
Post by Branko84 » Wed Oct 31, 2012 5:29 pm
I have downloaded the newest version of GomPlayer (ver. 2.1.43) and I still don't have any result. Under View modes there are still just Fullscreen Stretched and Fullscreen. There is no Full screen Stretched (Keep Ratio)?
Somateri
Re: GOM Player
Post by Somateri » Wed Oct 31, 2012 6:20 pm
how this will help update the plugin in EventGhost?xD
u can get this updated plugin only here(its not allready in last build EventGhost)
so u should install it manually
im says how do it in previous post
if u allready installed u do something wrong
screen:
ps
btw new version Gom player can break totally plugin
but for now last version(V 2.1.43 - 2012/07/31)
and its work fine
Branko84
Re: GOM Player
Post by Branko84 » Thu Nov 01, 2012 1:57 pm
Yes, I have downloaded attached *.py file. I have erased all files in GOMPlayer directory (two of them) (C:\Program Files\EventGhost\plugins\GOMPlayer).
When I again start EventGhost there is also *.pyc file which is autogenerated!
Thank you for all advices you posted on this Forum!
Branko84
Re: GOM Player
Post by Branko84 » Thu Nov 01, 2012 2:13 pm
OK! OK! OK!!!
Thank U Somateri! There was my mistake! I have saved My remote settings.xml file with older version of *.py file (I did this because it was easier for me to load settings, than to set commands all over again after formating a hard disk). All I needed to do (in order to get ...(Keep Ratio) option) was to (now with your *.py file) add again GOM Plug in from the EventGhost menu!
Thanks, again!
