Disable Exclusive
Disable Exclusive
Post by kgschlosser » Sat Oct 29, 2016 3:05 am
Disable Exclusive plugin.
unzip the file into you eventghost\plugins folder it will make all the necessary files and folders.
restart Eventghost. then add the plugin. it's listed in the "other" section. it works just like the Enable Exclusive. except it will disable the item you select and enable all others.
Have fun.
DisableExclusive.zip
(1.76 KiB) Downloaded 187 times
loveleejohn
Re: Disable Exclusive
Post by loveleejohn » Thu May 11, 2017 1:08 am
I just knew the day would come when I would end up needing this! I'm gonna have to give this a try now. Thanks for the hard work kg! :D
Post by kgschlosser » Thu May 11, 2017 3:45 am
yup. that's what I am here for.
