New version 0.5.0-rc4 is out
- kgschlosser
Re: New version 0.5.0-rc4 is out
you can set disable actions from the various session events that take place as well. these events should take place when using Microsoft RDP and you start a remote session.
as an example if you start an RDP session you will get
System.RemoteConnect
and if hat session is a console session you will also get this event
System.ConsoleConnect
and when the session disconnects
System.RemoteDisconnect
and if that session was a console session
System.ConsoleDisconnect
other session events. don't know what may or may not get triggered here
System.SessionLogon
System.SessionLogoff
System.SessionLock
System.SessionUnlock
System.SessionRemoteControl
System.SessionLogon
System.SessionLock
Hi Team
Hit an error with an older plugin when upgrading. It is for the Raspberry Pi and came from
http://eventghost.net/forum/viewtopic.p ... +pi+plugin
It is not critical to my systems but was nice to have
I used SSH to reboot one of my Pi's via SSH when the Raspberry Pi plugin reported overheating or excessive memory usage.
I have restarted EG and deleted and reloaded the plugin without success.
Here is a copy of the error that is generated at plugin activation time. Plugin is then marked as UNKNOWN.
- @Tameion
21:31:10 Error loading plugin file: C:\Program Files (x86)\EventGhost\plugins\RaspberryPi
21:31:10 Traceback (most recent call last) (0.5.0-rc4):
21:31:10 File "C:\Program Files (x86)\EventGhost\plugins\RaspberryPi\__init__.py", line 82, in <module>
21:31:10 import paramiko
21:31:10 ImportError: No module named paramiko
21:31:10 Error compiling script.
21:31:10 Traceback (most recent call last):
21:31:10 SyntaxError: EOL while scanning string literal (31, line 1)
21:31:10 File "wx\_core.pyc", line 16766, in <lambda>
21:31:10 File "C:\Program Files (x86)\EventGhost\eg\Core.py", line 205, in Notify
21:31:10 listener(value)
21:31:10 File "C:\Program Files (x86)\EventGhost\eg\Classes\MainFrame\TreeCtrl.py", line 801, in OnNodeSelected
21:31:10 path = node.GetPath()
21:31:10 File "C:\Program Files (x86)\EventGhost\eg\Classes\TreeItem.py", line 284, in GetPath
21:31:10 path.append(parent.childs.index(item))
21:31:10 ValueError: tuple.index(x): x not in tuple
- kgschlosser
This is not a huge issue. There are 2 ways that this can be handled. First way is. On the computer where EG is installed you can install python 2.7.9 once installed open a command window and navigate to the python directory/scripts once in the scripts folder type in. "Pip install paramiko" without the quotes. This will install the necessary packages. You will have to leave Python installed or you can locate the installed packages in the Python directory/libs/site-packages folder and copy them to EventGhost/lib27/site-packages this will allow you to remove python if you wanted to.
EG 0.5 has been set up to load packages from it's internal site-packages folder but it also goes and looks to see if python is installed and will load from there as well if it is installed.
Or o can zip up the packages and send em to ya.
The decision is yours
Thanks for such a quick and clear reply.
I have followed your instructions carefully but have hit another error.
No rush with the reply. It is 2:15am here in New Zealand and I gotta get some sleep. Will look again in the morning.
@Tameion
02:15:36 Traceback (most recent call last) (0.5.0-rc4):
02:15:36 File "C:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 162, in ProcessingTask
02:15:36 self.Configure(*args, **kwargs)
02:15:36 File "C:\Program Files (x86)\EventGhost\eg\Classes\ConfigDialog.py", line 106, in Configure
02:15:36 treeItem.Configure(*args)
02:15:36 File "C:\Program Files (x86)\EventGhost\eg\Classes\ActionItem.py", line 80, in Configure
02:15:36 return self.executable.Configure(*args)
02:15:36 File "C:\Program Files (x86)\EventGhost\plugins\RaspberryPi\__init__.py", line 1523, in Configure
02:15:36 bottomSizer.Add(prefLbl,0,wx.TOP,3)
02:15:36 File "wx\_core.pyc", line 14457, in Add
02:15:36 PyAssertionError: C++ assertion "Assert failure" failed at ..\..\src\common\sizer.cpp(1401) in wxGridSizer::DoInsert(): too many items (5 > 2*2) in grid sizer (maybe you should omit the number of either rows or columns?)
@Tameion
- kgschlosser
ok so the first error is now gone. when we started work on EG 0.5 we needed to do some upgrading. and one of those things was a package or module called wx. wx is responsible for communicating with windows to draw all of the graphics and GUI related bits. wx is very problematic and if there was an easy way to go about changing it to something else we would in a heartbeat. but because the original author wanted to use wx it has locked us to using it. but with every new release of wx comes changes for things that weren't broken. but weren't correct. and now are correct but the code for things like plugins has been written to use the incorrect way. I will fix this plugin no worries there. But you will have to upgrade it to the new version when I am done. It will be a nice double click a single file install so no worries there. and you won't even have to restart EG. But since I am now going to have to remedy this problem by releasing a new version of the plugin I will include the needed paramiko and subsequent modules with it. so you can uninstall python if you like as it will not be needed once i make these changes
- kgschlosser
here ya go on that RPi plugin
viewtopic.php?p=48563#p48563
I disabled the audioendpoint plugin setting my audio defaults, and I haven't had a crash in ages now, so I'm fairly confident it was that plugin causing the issues.blaher wrote: ↑Sat Aug 26, 2017 4:09 amI came up with a workaround to avoid setting the audio endpoint before it's ready, because I have a feeling that this is what is causing the majority of the problems. I think the RDP is affecting the keyboard plug-in logging, so I might just use a batch file to restart EventGhost after the session is logged on locally.
http://i.imgur.com/B0AN21t.jpg
We'll see how we go.Cheers, I'll try disabling the keyboard plugin when an RDP session is in effect.topix wrote:Maybe as a workaround disable those macros that wouldn't work
- kgschlosser
Tis what I told ya
Audio changes cannot be performed on anything but the default audio device (this is because windows will properly select the device)
Monitor actions like powering off the monitors
cannot be done in an RDP session (all programs that create a remote session with another computer).
I am sure there are probably other devices that would cause issues as well. But a good rule of thumb is if you go into the device manager while in an RDP session and you no longer see the device then you cannot perform actions on it while in an RDP session. The device should be visible if you login locally.
So here is a possible solution. if you log into the computer locally then login from a remote session under a different username. This can be done by clicking the proper link below to "enable" this feature.
WindowsXP -7
Windows10
if You have EG running for the one user that is running locally. You will get an event that will be generated in EG when the second user logs in. Now i do not know how EG will respond if you have EG running in 2 different sessions. But here is what I would do.
if you are running EG 0.5 make a script and in that script put this code
place that script as the top most item in your Autostart group. What this is going to do is it will check for the logged in user name and trigger an event if the user matches of not a different one gets triggered.
make 2 macros one for each of the events. in one macro add the disable event then add the action disable for each of the plugins and one for each of the root folders/macros in your tree.
and the opposite for the Enable event. reverse the process of the disable event.
This is going to allow you to open the tree from the RDP session that is logged in with a different username and allow you to edit the tree file without having EG crash on ya. you will have to do 2 things to get EG to start right. place your save file outside of a specific username. it cannot be saved anywhere in the c:\users folder. and in the remote session you will want to start EG with the -multiload command line switch.
if you set up the network event receiver and sender plugin i can tell you how to get EG to reload the save file on the local logged in user. If ya want. but this will allow you to get the thing running so you can edit the tree.
WindowsXP -7
Windows10
if eg.WinApi.User.Name() == 'ENTER YOUR USERNAME HERE':
eg.TriggerEvent(prefix='RDP', suffix='Disable.All')
eg.TriggerEvent(prefix='RDP', suffix='Enable.All')
- kgschlosser
I made some modifications to some of the core files and sent them upstream to be added to EG. But i will post them here so you can use them. it will help in setting up the disabling features. I want to go a little further with it and add an extra method to the plugins that can be used to disable a specific plugin if the logged in user is on a remote session. so this can all be done in the back end of EG without the need to have the user do this kind of work. we are going to see more and more people using remote sessions. so the only way to deal with it is to either completely rewrite EG to run as a service with a web GUI front end or to make some changes in it how it sits now to deal with it until we get around to rewriting it.
- AutostartItem.py
- replace AutostartItem.py in the eg/Classes folder with this one.
- (3.41 KiB) Downloaded 142 times
- ActionThread.py
- replace ActionThread.py in the eg/Classes folder with this one.
- (4.56 KiB) Downloaded 132 times
I've been getting regular crashes now, even with audioendpoint disabled.
Seems to be the culprit.
File "_ctypes/callbacks.c", line 315, in 'calling callback function'
File "C:\Program Files (x86)\EventGhost\eg\Classes\MessageReceiver.py", line 127, in WindowProc
res = handler(hwnd, mesg, wParam, lParam)
File "C:\Program Files (x86)\EventGhost\plugins\Task\__init__.py", line 128, in MyWndProc
self.WindowGotFocusProc(None, None, lParam, None)
File "C:\Program Files (x86)\EventGhost\plugins\Task\__init__.py", line 158, in WindowGotFocusProc
ident = self.CheckWindow(hwnd)
File "C:\Program Files (x86)\EventGhost\plugins\Task\__init__.py", line 112, in CheckWindow
name = splitext(GetProcessName(pid))[0]
WindowsError: [Error 8] Not enough storage is available to process this command: 'CreateToolhelp32Snapshot'
- Log - Copy.rar
- (18.89 KiB) Downloaded 130 times
- kgschlosser
You can try increasing your IRPStackSize. this is going to require you to edit your registry.
Click Start, click Run, type regedit, and then click OK.
Locate and then click the following registry subkey: If the IRPStackSize entry is not present in this subkey, follow these steps:
Click Edit, point to New, and then click DWORD Value.
Type IRPStackSize, and then press ENTER.
Note Type IRPStackSize exactly as it appears. The value name is case sensitive.
Click IRPStackSize, click Edit, and then click Modify.
In the Data Value box, type a larger value, and then click OK.
Values can be
0x1
0x2
0x3
0x4
0x5
0x6
0x7
0x8
0x9
0xA
0xB
0xC
Change it one step at a time until the problem goes away. if it does not let me know.
Values can be
0x1
0x2
0x3
0x4
0x5
0x6
0x7
0x8
0x9
0xA
0xB
0xC
I'm up to the max and it's still crashing. I think I'll put it back to the default and see if it helps.
Here's an updated log.
- Log - Copy (3).rar
- (10.79 KiB) Downloaded 123 times
- kgschlosser
I am going to suggest you run some kind of a memory check on your computer.
I am thinking there is something wrong there. Or one of the voltages on your mainboard. Do you overclock your computer at all?
The reason why I am asking this is because of the number of really strange errors that don't seem to have any kind of a common denominator. The problems are coming from all different parts of EG that aren't related in a manner that would cause these errors. Maybe you have some HDD corruption or possibly window system files are corrupted.
MCE Remote Vista plugin
WindowsError: [Error 1072] The specified service has been marked for deletion.
this one from eg.document. this one doesn't even know what went wrong.
wxError1: Can't create window of class wxWindowNR (error 0: unknown error 0)
this one from Task Monitor
this one from the Main GUI control of EG
PyAssertionError: C++ assertion "image.IsOk()" failed at ..\..\src\msw\bitmap.cpp(922) in wxBitmap::CreateFromImage(): invalid image
this one is from eg.Scheduler.
error: can't start new thread
run these few tests for me.
first check you HDD for any errors. use the builtin windows checker. don't fix any bad sectors as that portion could take forever. when that is done report the results from it. then run this from the command line. this could take a really long time to run. so you may want to do it before you go to sleep. run CMD with admin privileges. then key in this command
this is going to test all of the windows OS files for any problems. and if there are any issues it will make an attempt to repair them. it may or may not be able to. running this will consume a pretty good sized chunk of resources. so close all running programs..
once that is done you will want to key this into that same command window. running this command is going to parse the output log files from the scan and save that information to a file named sfcdetails.txt on your desktop. zip up that file and attach it to a PM to me. I need to look at it to see what it has found and what it was able to fix and not fix.
I am going to ask some really dumb questions. don't get mad at me. sometimes things get forgotten or overlooked.
Have you rebooted the computer?
Have you done a power cycle of the computer? (shutdown, unplug for 30 seconds, power it back up)
Have you tried disabling one plugin at a time?
Have you tried running EG with a blank config tree?
I am not sure what you are changing or doing to your tree that keeps on causing the plugin manager to restart. but it happens right after some program gets run from EG. I have seen this 7 times and this appears before and after some of the errors. Not sure what it is.
sfc /scannow
findstr /c:"[SR]" %windir%\logs\cbs\cbs.log > %USERPROFILE%\Desktop\sfcdetails.txt
20:20:24: 1 MainThread: creating named pipe
20:20:24: 1 MainThread: calling ConnectNamedPipe
20:20:24: 1 MainThread: starting subprocess
20:20:24: 1 MainThread: waiting for subprocess to connect
20:20:24: 1 MainThread: got connect event
20:20:24: 1 MainThread: sending startup message
20:20:24: 0 MainThread: PluginManager.ScanAllPlugins :0.132135220365641
No, no overclocking. No instability in any other programs, even CPU/GPU intensive ones like games.kgschlosser wrote: ↑Thu Dec 21, 2017 5:02 amI am going to suggest you run some kind of a memory check on your computer.
This one is explainable: I was getting double presses in Kodi, i.e. the service had failed to disable the native Win key presses, so after trying to uninstall from the EG plugin without success, I went to the plugin directory, and ran the uninstall, rebooted, ran install, rebooted. It's now back to working properly.MCE Remote Vista plugin
No errors on any drive.this one from eg.document. this one doesn't even know what went wrong.
Have you rebooted the computer?then run this from the command line. this could take a really long time to run. so you may want to do it before you go to sleep. run CMD with admin privileges. then key in this commandthis is going to test all of the windows OS files for any problems. and if there are any issues it will make an attempt to repair them. it may or may not be able to. running this will consume a pretty good sized chunk of resources. so close all running programs..Code: Select all
sfc /scannow
once that is done you will want to key this into that same command window. running this command is going to parse the output log files from the scan and save that information to a file named sfcdetails.txt on your desktop. zip up that file and attach it to a PM to me. I need to look at it to see what it has found and what it was able to fix and not fix.I am going to ask some really dumb questions. don't get mad at me. sometimes things get forgotten or overlooked.Code: Select all
yes
yes
No, I use EG for home automation so it needs to be up.Have you tried disabling one plugin at a time?
Is it when I kill EG with task manager, and have to restart it, perhaps?I am not sure what you are changing or doing to your tree that keeps on causing the plugin manager to restart. but it happens right after some program gets run from EG. I have seen this 7 times and this appears before and after some of the errors. Not sure what it is.
20:20:24: 1 MainThread: creating named pipe 20:20:24: 1 MainThread: calling ConnectNamedPipe 20:20:24: 1 MainThread: starting subprocess 20:20:24: 1 MainThread: waiting for subprocess to connect 20:20:24: 1 MainThread: got connect event 20:20:24: 1 MainThread: sending startup message 20:20:24: 0 MainThread: PluginManager.ScanAllPlugins :0.132135220365641
- kgschlosser
I am going to suggest running the sfc/scannow
and since you are having an issue with your production EG. I would suggest systematically shutting down one plugin at a time for a day or 2 each and see if it is possibly a single plugin causing the problem. I know this sucks But unless we can isolate exactly what is causing it my hands are tied.
