TaskMonitorPlus plugin - v0.0.5
Boolean263
Post by Boolean263 » Tue Aug 29, 2017 9:18 pm
Version 0.0.3 is out! Adds the TitleChanged event, and a boatload of useful window management functions from kgschlosser. Also removes the DLL, since it's apparently not needed (thanks again kgschlosser!).
Version 0.0.4 is out! This one just has some under-the-hood tweaks based on feedback from kgschlosser. Mainly, if your window has "" as its title, you'll be able to tell.
Version 0.0.5 is out! This incorporates a fix for the freezing issue topix reported.
Task Monitor Plus is a fork/expansion of the Task Monitor (aka simply Task) plugin that ships with EventGhost. Like the original Task Monitor plugin, Task Monitor Plus generates events when a window opens, closes, flashes, or gains or loses focus. The "Plus" is in the payload: events generated by this plugin come with a payload which gives more details about the window in question. (From v0.0.3 there's also a new event fired when a window's title changes.)
The two most interesting attributes of this payload are `eg.event.payload.title`, which contains the window title, and `eg.event.payload.window_class`, which contains the internal class name for the window. Some programs use different classes for the different types of windows they generate, so this field may be useful for acting only on the windows you want.
The source code for Task Monitor Plus is on github at Boolean263/EventGhost-TaskMonitorPlus. This is also where you'll find full documentation and a complete changelog. I accept feedback and pull requests there, as well as offering support in this thread.
This plugin is based on the 1.0.4 version of the original Task Monitor plugin, which was written by Bitmonster and blackwind. My inspiration to create this fork was to fill in the shortcomings of my older WindowWatcher plugin, which is now deprecated.
TaskMonitorPlus-0.0.5.egplugin
(10.21 KiB) Downloaded 37 times
Reason: Reattached plugin
Boolean263
Re: TaskMonitorPlus plugin - v0.0.2
Post by Boolean263 » Sat Sep 02, 2017 4:05 pm
Version 0.0.2 is a bugfix release. 0.0.1 would spew errors into the EG event log if it tried to show events for windows which had unicode characters in their title. This version "fixes" that by using `repr()` to report the title to the event log.
Neytrino-OnLine
Post by Neytrino-OnLine » Sun Sep 03, 2017 12:36 pm
Hi, so I installed latest version, added to a configuration, and it doesn't generate any events... EG 0.5.0rc4
Sin©erely yours, Neytrino.
Boolean263
Post by Boolean263 » Sun Sep 03, 2017 2:58 pm
Neytrino-OnLine wrote:Hi, so I installed latest version, added to a configuration, and it doesn't generate any events... EG 0.5.0rc4
How did you add it to a configuration? The screenshots in your other post were really handy, could you give a screenshot or two showing what you're doing here?
Neytrino-OnLine
Post by Neytrino-OnLine » Sun Sep 03, 2017 3:59 pm
I didn't think that I have any options (how to make it), but Ok, so:
I have downloaded TaskMonitorPlus-0.0.2-file from the first post, have twice clicked on it,
Then - Ok, then right click on configuration tree / Add plugin...
Then choose plugin, Ok...
And it in a configuration... But there is no any events about windows or tasks...
p.s. EG has been purely installed today...
Boolean263
Post by Boolean263 » Sun Sep 03, 2017 4:31 pm
Neytrino-OnLine wrote:And it in a configuration... But there is no any events about windows or tasks...
Remove Task Monitor Plus from your plugin list, and install the basic Task Monitor that comes with EventGhost. Let me know if you get any events from that one.
Neytrino-OnLine
Post by Neytrino-OnLine » Sun Sep 03, 2017 5:04 pm
Boolean263, there is no any actions with standard plugin...
Boolean263
Post by Boolean263 » Sun Sep 03, 2017 5:43 pm
Neytrino-OnLine wrote:Boolean263, there is no any actions with standard plugin...
If you had gotten events from the standard plugin, then it would have meant I broke something in my plugin. But if you aren't getting events from either one, then it sounds like there's something broken about your overall setup.
My ability to help here will be a bit limited. Maybe kgschlosser or topix can step in? But let's see what I can do.
Let's start with the standard plugin. Keep Task Monitor installed/enabled, and TaskMonitorPlus disabled/removed.
Under the View menu, turn on Log Debug Info (sorry, I don't know what the Russian equivalents would be!), then restart EventGhost. See if any error messages appear about Task Monitor, and we'll work from there.
Neytrino-OnLine
Post by Neytrino-OnLine » Sun Sep 03, 2017 5:58 pm
So, this is start with debug events...
20:50:50: 0 MainThread: PluginManager.ScanAllPlugins :1.4985375174633435
20:50:50: 0 MainThread: SendKeysParser.__init__()
20:50:50: 0 EventGhost.Pipe.Thread: Named Pipe: Creating security descriptor
20:50:50: 0 EventGhost.Pipe.Thread: Named Pipe: Creating pipe
20:50:50: 0 MainThread: Document.ShowFrame()
20:50:50: 0 MainThread: Document.ShowFrame => None
20:50:52: 0 EventThread: EventThread.StartSession(filename=u'P:\\Profiles\\EventGhost\\Rino-HT 4.0.xml')
20:50:52: 0 ActionThread: ActionThread.StartSession(filename=u'P:\\Profiles\\EventGhost\\Rino-HT 4.0.xml')
20:50:52: 0 Thread-1: SessionChangeNotifier.Register()
20:50:52: 0 MouseThread: MouseThread.run()
20:50:52: 0 ActionThread: Document.Load(filePath=u'P:\\Profiles\\EventGhost\\Rino-HT 4.0.xml')
20:50:52: 1 MainThread: OSDFrame.__init__(parent=None)
20:50:52: 0 ActionThread: StartLoad(cls=<class 'eg.Classes.TreeLink.TreeLink'>)
20:50:52: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=1706728, uMsg=536L, wParam=32787L, lParam=6817256)
20:50:52: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=1706728, uMsg=536L, wParam=32787L, lParam=6816712)
20:50:52: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=1706728, uMsg=536L, wParam=32787L, lParam=6817096)
20:50:52: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=1706728, uMsg=536L, wParam=32787L, lParam=6847944)
20:50:52: 0 ActionThread: Document.SetExpandState(expanded=set([0, 128, 387, 4, 7, 12, 143, 22, 23, 132, 27, 423, 424, 42, 46, 50, 54, 440, 58, 62, 67, 76, 80, 87, 217, 105, 109, 113, 120, 124]))
20:50:52: 0 ActionThread: XML loaded in 0.233638 seconds.
20:50:52: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
Autostart
   Run Application: nircmd.exe
   Plugin: Microsoft MCE Remote (Vista+)
      20:50:52: 0 ActionThread: MCE_Vista.__start__()
      20:50:52: 0 Thread-5: MceMessageReceiver.__call__()
   Plugin: Desktop Remote
   Plugin: SchedulGhost
   MCE_Vista: Connected to MceIr pipe, started handling IR events
   Plugin: AudioEndpoint
      Audio Endpoint plugin started.
   Plugin: TrayTip
   Plugin: Task Monitor
20:50:52: 0 ActionThread: ActionThread.StartSession => None
System.PowerProfile.Balanced
MceRemote.Connected
AudioEndpoint.Default.Render.Console.Динамики (Display Audio) [u'{0.0.0.00000000}.{b077439b-ba23-4465-9a29-275021e3ac29}']
AudioEndpoint.Default.Render.Multimedia.Динамики (Display Audio) [u'{0.0.0.00000000}.{b077439b-ba23-4465-9a29-275021e3ac29}']
AudioEndpoint.Default.Render.Communications.Динамики (Display Audio) [u'{0.0.0.00000000}.{b077439b-ba23-4465-9a29-275021e3ac29}']
AudioEndpoint.Default.Capture.Console.Микрофон (Display Audio) [u'{0.0.1.00000000}.{f52b8d20-6bd8-4037-a213-2d6c0fb8605f}']
AudioEndpoint.Default.Capture.Multimedia.Микрофон (Display Audio) [u'{0.0.1.00000000}.{f52b8d20-6bd8-4037-a213-2d6c0fb8605f}']
AudioEndpoint.Default.Capture.Communications.Микрофон (Display Audio) [u'{0.0.1.00000000}.{f52b8d20-6bd8-4037-a213-2d6c0fb8605f}']
Main.OnInit
   Initialization
      Play Sound: P:\Profiles\EventGhost\Speech Off.wav
System.PowerSaving.Off
System.PowerSource.Line
System.Monitor.On
20:50:52: 1 MainThread: MainFrame.OnClose(dummyEvent=<wx.CloseEvent>)
20:50:52: 1 MainThread: MainFrame.Iconize(flag=True)
20:50:52: 1 MainThread: Document.HideFrame()
20:50:52: 1 MainThread: MainFrame.Destroy()
20:50:52: 1 MainThread: LogCtrl.Destroy()
20:50:52: 1 MainThread: TreeCtrl.Destroy()
20:50:52: 1 MainThread: StatusBar.Destroy()
20:50:52: 1 MainThread: StatusBar.__del__()
20:50:52: 1 MainThread: MainFrame.Destroy => True
20:50:52: 1 MainThread: Document.HideFrame => None
20:50:52: 1 MainThread: LogCtrl.__del__()
20:50:52: 1 MainThread: MainFrame.__del__()
20:50:56: 1 MainThread: Document.ShowFrame()
20:50:56: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
20:50:56: 1 MainThread: Document.ShowFrame => None
Boolean263
Post by Boolean263 » Sun Sep 03, 2017 7:18 pm
Everything looks fine there to me. Sorry, I'm out of ideas! @kgschlosser?
Post by kgschlosser » Sun Sep 03, 2017 7:47 pm
you need to enable debugging from the command line.
leave the quotes in place
close EG then open up a command prompt and paste this into it.
"c:\program files (x86)\eventghost\eventghost.exe" -debug
This will start the debugging process right out of the gate so if there is an error we can see it. enabling debugging from the GUI only debugs information after the startup process of EG
Post by kgschlosser » Sun Sep 03, 2017 7:48 pm
I would also like to know what version of EG you are running. as well as your windows version.
Neytrino-OnLine
Post by Neytrino-OnLine » Mon Sep 04, 2017 3:51 am
kgschlosser, Ok...
06:41:28: 0 MainThread: ----------------------------------------
06:41:28: 0 MainThread:         EventGhost started
06:41:28: 0 MainThread: EventGhost Version: 0.5.0-rc4
06:41:28: 0 MainThread: Machine type: AMD64
06:41:28: 0 MainThread: Processor: Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
06:41:28: 0 MainThread: Architecture: ('32bit', 'WindowsPE')
06:41:28: 0 MainThread: Python:  2.7.12 CPython ('default', 'Oct 31 2016 18:42:08') [MSC v.1500 32 bit (Intel)]
06:41:30: 0 MainThread: PluginManager.ScanAllPlugins :1.6338492410462573
06:41:30: 0 MainThread: SendKeysParser.__init__()
06:41:30: 0 EventGhost.Pipe.Thread: Named Pipe: Creating security descriptor
06:41:30: 0 EventGhost.Pipe.Thread: Named Pipe: Creating pipe
06:41:30: 0 MainMessageReceiver: MainMessageReceiver.__MainLoop()
06:41:30: 0 MainMessageReceiver: MainMessageReceiver.Setup()
06:41:30: 0 ActionThread: ActionThread.__MainLoop()
06:41:30: 0 EventThread: EventThread.__MainLoop()
06:41:32: 0 EventThread: EventThread.StartSession(filename=u'P:\\Profiles\\EventGhost\\Rino-HT 4.0.xml')
06:41:32: 0 ActionThread: ActionThread.StartSession(filename=u'P:\\Profiles\\EventGhost\\Rino-HT 4.0.xml')
06:41:32: 1 MainThread: OSDFrame.__init__(parent=None)
06:41:32: 0 Thread-3: SessionChangeNotifier.Register()
06:41:32: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=331174, uMsg=536L, wParam=32787L, lParam=7163112)
06:41:32: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=331174, uMsg=536L, wParam=32787L, lParam=7163592)
06:41:32: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=331174, uMsg=536L, wParam=32787L, lParam=7163368)
06:41:32: 0 MainMessageReceiver: PowerBroadcastNotifier.OnPowerBroadcast(hwnd=331174, uMsg=536L, wParam=32787L, lParam=7131984)
06:41:32: 0 MouseThread: MouseThread.run()
06:41:32: 0 ActionThread: Document.Load(filePath=u'P:\\Profiles\\EventGhost\\Rino-HT 4.0.xml')
06:41:32: 0 ActionThread: StartLoad(cls=<class 'eg.Classes.TreeLink.TreeLink'>)
06:41:32: 0 ActionThread: Document.SetExpandState(expanded=set([0, 128, 387, 4, 7, 12, 143, 22, 23, 132, 27, 423, 424, 42, 46, 50, 54, 440, 58, 62, 67, 76, 80, 87, 217, 105, 109, 113, 120, 124]))
06:41:32: 0 ActionThread: XML loaded in 0.235264 seconds.
Autostart
      06:41:32: 0 ActionThread: MCE_Vista.__start__()
      06:41:32: 0 Thread-5: MceMessageReceiver.__call__()
   Plugin: TrayTip
06:41:33: 0 ActionThread: ActionThread.StartSession => None
MceRemote.Connected
Main.OnInit
   Initialization
System.Monitor.On
06:41:37: 1 MainThread: Document.ShowFrame()
06:41:37: 1 MainThread: Log.GetData()
06:41:37: 1 MainThread: TreeCtrl.OnItemCollapsingEvent(event=<wx.TreeEvent>)
06:41:37: 1 MainThread: Document.ShowFrame => None
Post by kgschlosser » Mon Sep 04, 2017 4:59 am
and when you click on another window when EG is open nothing happens?
Neytrino-OnLine
Post by Neytrino-OnLine » Mon Sep 04, 2017 5:08 am
kgschlosser wrote:and when you click on another window when EG is open nothing happens?
Yes...
