I can't add a "Show QR Code" action to a macro. When I select it from the Add Action dialog and click OK, I get the following error dump (this is with debugging information enabled):
File "E:\Program Files (x86)\EventGhost\eg\Classes\TaskletDialog.py", line 162, in ProcessingTask
File "E:\Program Files (x86)\EventGhost\eg\Classes\ConfigDialog.py", line 106, in Configure
treeItem.Configure(*args)
File "E:\Program Files (x86)\EventGhost\eg\Classes\ActionItem.py", line 80, in Configure
File "E:\Program Files (x86)\EventGhost\plugins\System\__init__.py", line 1646, in Configure
textWidth = 105
File "E:\Program Files (x86)\EventGhost\eg\Classes\SmartSpinIntCtrl.py", line 61, in __init__
textWidth = textWidth
File "E:\Program Files (x86)\EventGhost\eg\Classes\SmartSpinNumCtrl.py", line 61, in __init__
self.ctrl = self.CreateCtrl(int(not isinstance(value, (int, float))))
File "E:\Program Files (x86)\EventGhost\eg\Classes\SmartSpinNumCtrl.py", line 72, in CreateCtrl
**self.kwargs
File "E:\Program Files (x86)\EventGhost\eg\Classes\SpinNumCtrl.py", line 89, in __init__
numCtrl.SetValue(value) # To avoid bug in NumCtrl
File "wx\lib\masked\numctrl.pyc", line 1281, in SetValue
File "wx\lib\masked\numctrl.pyc", line 1604, in _toGUI
ValueError: value 0 is below minimum value of control
