Google Play Desktop Music Player shuffle 'Button"
zian
Post by zian » Mon Nov 13, 2017 3:22 pm
I just downloaded this desktop music player that works via my Google tunes.
I would like the application to resume/start playback on startup.
That might be easier. Maybe command line. I Googled and couldn't find any.
The attached image shows a shuffle "button" in the upper right. On startup when it is not playing I can click that button and it starts to play. How do I click that button via EG? Send message? Python? Find window didn't work for me. I know how to raise window and move curse click etc... but those are cheap tricks. Don't seem smart or consistent for me. Windows move and such.
The real coding & EG tricks are all Greek to me.
I like to have it just shuffle all. Play/shuffle on startup works for me.
keyboard shortcuts...
https://sites.google.com/a/umich.edu/go ... ws-and-mac
This program does offer an api / updated json file. Also greek to me ;)
https://github.com/MarshallOfSound/Goog ... aster/docs
Any ideas or suggestions?
Thanks Shuffle All ;)
eventghost.net
Be there or be square.
jachin99
Re: Google Play Desktop Music Player shuffle 'Button"
Post by jachin99 » Mon Nov 13, 2017 8:10 pm
If you can't get this working, there is also a desktop mini player for google play music. There probably aren't very many windows to choose from if you wanted to send that keyboard shortcuts or screen clicks http://www.makeuseof.com/tag/google-pla ... op-player/ You might even find the window with the mini player, and then implement that click or keystroke in the full blown desktop player?
eirik226
Post by eirik226 » Mon Nov 13, 2017 10:08 pm
As far as I can tell this is possible with the API - just don't have time to look into it right now.
cvben
Post by cvben » Thu Feb 08, 2018 6:57 pm
Zian,
First, thanks for the heads up on the program as it is pretty nice actually. I messed around a bit with the api and found it to be a headache, at least from the point of view of an extremely low skill coder.
Next, I believe those keyboard shortcuts from the now dead link are not for the desktop app you are using. From what I recall google once upon a time either had a beta desktop music app they made, which is now discontinued, or someone else designed such an app and these keys re for that program; either way unhelpful unfortunately.
Now to the meat of it:
What I learned was that you have to establish a kind of "handshake" through websocket. See HERE
Process breakdown:
1) you send a json message saying which tells the program you want to connect
  "namespace": "connect",
  "method": "connect",
  "arguments": ["EventGhost"]
2) you get a response from the program, which you could use to trigger a function to extract the code or prompt a gui input to use in step 3
  "channel": "connect",
  "payload": "CODE_REQUIRED"
3) the program gives you a 4 digit code in its UI which you have to send back to it in json
  "arguments": ["Name of Device / App", "0000"] # where 0000 = the code
4) this then it gives you a permanent access key. This key must then be used to call the websocket to establish a connection
  "arguments": ["EventGhost", "Your_Given_Key"]
5) you are the FINALLY able to then send commands in the form of json
6) these commands might look something like:
(an example I think I understand)
  "namespace": "playback",
  "method": "setShuffle",
  "arguments": [ALL_SHUFFLE]
or
(no example given, and no argument value ... so... who knows
  "method": "toggleShuffle",
For what its worth HERE is a working example from home-assistant.io
Caveats with above link:
1) Based around python 3
2) uses modules outside of EG core.
cvben
Post by cvben » Thu Feb 08, 2018 7:02 pm
Further considerations:
This found and brought window to front for me just fine:
    <Macro Name="Python Script" XML_Guid="{54968E9B-05A3-4720-B9E6-62F70901B952}" Expanded="True">
        <Action XML_Guid="{551746A7-9644-4EF1-8C07-2DB8973C59CF}">
            Window.FindWindow(u'Google Play Music Desktop Player.exe', u'Google Play Music Desktop Player', u'Chrome_WidgetWin_1', u'Chrome Legacy Window', u'Chrome_RenderWidgetHostHWND', 1, False, 0.0, 0)
        <Action XML_Guid="{7DC7BDBB-B7CF-4F82-BE81-A51C4075BB07}">
            Window.BringToFront()
