Hey there,
I have 2 profiles for Vivaldi (Chrome based Browser that wants to replace the old Opera) which have different bookmarks/settings/etc.
I created this 2 profiles with 2 seperate shortcuts that have different targets (at shortcut properties)
First shortcut target:
"C:\Program Files (x86)\Vivaldi\Application\vivaldi.exe" --user-data-dir="C:\Users\Admin\AppData\Local\Vivaldi\User Data\PROFILE1"
Second shortcut target:
"C:\Program Files (x86)\Vivaldi\Application\vivaldi.exe" --user-data-dir="C:\Users\Admin\AppData\Local\Vivaldi\User Data\PROFILE2"
PROFILE1 and PROFILE2 are just example names.
I just tell you that, because these shortcuts use the same vivaldi.exe file to launch the browser, but the browser knows he has to load a special profile.
Now I want to find the right window with EventGhost so I can manipulate the window itself (size, position, etc.)
Sure, I tried the 'Drag Finder' but it can't tell apart the 2 profiles (maybe because of the same vivaldi.exe file)...
Any ideas so far?
Find right Window (multiple instances)
- kgschlosser
Re: Find right Window (multiple instances)
question.
Is the name of the profile in the title of the window?
No, the title is always the line between <title></title> tags of that page.
- kgschlosser
hmmm...
you can use Task Monitor Plus along with the Enable action and the disable action to accomplish what you need.
The payload in the event that is generated by TMP (Task Monitor Plus) contains a whole bunch of convenience functions for controlling the window.
You would set up something like this
and whenever you want you can access each of the profiles from PythonScripts.PythonCommand actions.
eg.globals.profile_1
eg.globals.profile_2
after one of the profiles has been opened if you click on the help drop down and click on the python shell item. in there key in
or eg.globals.profile_2 whichever profile you have loaded. either or will contain the same information
This is going to show you all of the available functions. if you want to know more information about a specific function
Here is a list of the functions that are available
macro window control profile 1
event from TMP for vivaldi.exe, or the browser depending on how it comes up
Python command action - eg.globals.profile_1 = eg.event.payload
disable action - disable macro window control profile 1 and return
macro window control profile 2
Python command action - eg.globals.profile_2 = eg.event.payload
disable action - disable macro window control profile 2 and return
macro profile 1
event that causes profile 1 to run
enable action - enable macro window control profile 1 and return
action that runs vivaldi.exe for profile 1
macro profile 2
event that causes profile 2 to run
enable action - enable macro window control profile 2 and return
action that runs vivaldi.exe for profile 2
help(eg.globals.profile_1)
help(eg.globals.profile_1.SOME_FUNCTION_NAME)
IsAlive
IsActive
Animate
SendKeystrokes
Flash
BringToTop
IsVisible
EnableKeyboardMouse
IsKeyboardMouseEnabled
Restore
Minimize
Maximize
SetPosition
SetSize
SetRect
GetRect
GetRectTuple
GetSize
GetSizeTuple
GetPosition
GetPositionTuple
Show
Hide
Destroy
Close
SendMessage
PostMessage
GetParent
Focus
HasFocus
