eg.plugins.System.Execute changed
Post by Sem;colon »
Hello everyone,
this is just a little modification of the System.Execute plugin.
-It enables you to disable parsing of strings, to be able to use "{" or "}" in run parameters for example.
-It gives you the possibility to add an additional suffix to the event, if you choose to trigger an event when the application is terminated.
Execute.py
(11.63 KiB) Downloaded 282 times
